I‘m trying to pair two Moes TRVs TS0601 _TZE200_cpmgn2cf, which are officially supported now with deconz.
I‘m on the actual firmware (26780700) and deconz-Version (2.19.01) on my Conbee II.
Im using HA on a RPI4.
While I had no problems wirh deconz so far the last year, I can‘t figure out to work with these TRVs.
I‘m not sure, where I‘m missing the point, as I never worked with TRVs until now.
I set phoscon to pairing mode (new sensor), I set the TRV into pairing mode. Phoscon says success, deconz shows a „Home Automation Smart plug“. I try the pairing again (as found in some threads with these TRVs), I try to read the basic cluster, but nothing changes anymore. The TRV doesn‘t show up in Phoscon (normal?), nor does it in the Deconz-Integration in HA.
Can anyone help me out?
Thanks,
Wolfgang
Here is a photo from the Basic descriptor of the two TRVs.
Another identifier, _TZE200_cpmgn2cf, added as a TRV of type TS0601 to the product mapping.
Since before, I have another identical device, but that one is advertising itself as _TZE200_cwnjrr72
Can I contribute in any way, that also the _TZE200_cpmgn2cf will be added/supported?
Or is it possible for me to load a ddf-file (if someone has an appropriate one) to support these devices?
I think it’s fast to add it in c++ code.
But the next deconz step will be probably TRV, and I hope with the support for DDF for Tuya one (ATM not possible to include Tuya TRV)
If you have a real OS, not a docker or HA, I can explain how to do to recompile code just for you.
Else I think it’s better to wait for manup decision about the next deconz step.
No I‘m not sure.
I just saw they are using Moes Tuya Zigbee TRVs, but I don‘t know how many versions these sell.
When I looked into the ddf-files of my installation, there are no files assiciated to moes TRVs. Else I would have tried to adapt one of those to my modelname and to look what happens…
I just got this device (_TZE200_cpmgn2cf) and I would go down the self compiling road if that’s still necessary.
I’m not sure which branch i should check out though.
Still no new for support using DDF.
But if you want to compile the code, you just need to take the last official.
In file de_web_plugin.cpp, around line 5866 just add
Since this device is not supported in Phoscon and since there’s little hope that this changes in the near future, I’ve put together a small bash script for controlling this TRV (and probably other TRVs).
You can find it here https://gist.github.com/llugo/562e080c8ff9e051e67f4fc510f64f56.
I’d be glad if someone had a look at it or even could suggest improvements.
