Apparently, the sensor is not compatible with the ConBee II. I’m not able to pair it with the Zigbee Stick. The log says something about “No Tuya productId entry found for manufacturername: _TZ3210_ttkgurpb”. I’ve tried to pair the thing about 50 times now without success.
Maybe it’s not supported or what am I doing wrong?
I managed to keep the device in pairing mode with the above procedure (short presss every 2 seconds) for the whole 3 minutes but the Conbee II was not able to pair with the sensor. Here a screen shot:
You are sure it s a xiaomi one ? The mac adress don’t look like a Xiaomi one.
You can select the second circle to expand cluster (on the node title) and check for model id/manufacture name (Cluster 0x0000, press button “read”, if the device is sleeeping short press on the device in same time)
Well I bought a “Xiaomi” but the box says “Tuya”. I’m unfamiliar with both - it’s not my daily business, anyway
I captured the popu menu from the second circle:
Ok So I presume your device is not a Xiaomi but the _TZ3210_ttkgurpb
And this one is probably not whitelisted, If you have a deconz version that support DDF, this device can be added using them, I don’t see something special on your capture.
That sounds promising How do I find out whether or not I have a version that supports them? And if so, are there any resources available describing how to create a DDF?
