Hi hi,
I have a few Tuya Motion Sensors that I have seen here and in github already.
For some reason, Home Assistant doesn’t show if any motion is detected.
Since a DDF was already developed for _TZ3000_msl6wxk9, I hoped it would work with that, but so far no joy.
I can see the status change in deCONZ when motion is detected, I have that id in the binding too, but HA doesn’t seem to pick it up.
The sensor is available, but the status remains unchanged at “clear”.
Any thoughts on where I should be looking to see if anything is communicated properly between deCONZ and HA?
My DDF is:
"manufacturername": "_TZ3000_msl6wxk9",
"modelid": "TS0202",
"product": "TS0202",
"sleeper": true,
"status": "Silver",
"path": "/devices/_TZ3000_msl6wxk9_ts0202_take2.json",
"restapi": "/sensors",
"0x01",
"0x0500"
"fingerprint": {
"profile": "0x0104",
"device": "0x0107",
"endpoint": "0x01",
"in": [
"0x0000",
"0x0001",
"0x0500"
"name": "attr/swversion"
"name": "config/battery",
"awake": true,
"read": {
"at": "0x0021",
"cl": "0x0001",
"fn": "zcl"
"at": "0x0021",
"cl": "0x0001",
"eval": "Item.val = Attr.val / 2",
"fn": "zcl"
"name": "config/duration"
"name": "config/enrolled",
"public": false,
"description": "State of IAS enrollment process."
"name": "config/on"
"name": "config/reachable"
"name": "state/battery",
"refresh.interval": 3600
"name": "state/lastupdated"
"name": "state/lowbattery",
"description": "True when the device battery runs low."
"name": "state/presence",
"awake": true,
"fn": "ias:zonestatus",
"mask": [
"alarm1",
"alarm2"
"name": "state/tampered",
"description": "True when the device tampered alarm was triggered."
"bindings": [
"cl": "0x0001",
"at": "0x0021",
"dt": "0x20",
"min": 0,
"max": 0
"cl": "0x0500",
"at": "0x0002",
"dt": "0x19",
"min": 0,
"max": 0
