TS110E dimmer reporting wrong state
Hello there!
I recently added to my zigbee network a TS110E dimmer ( _TZ3210_k1msuvg6 ), and I observe a strange behaviour. If i turn on the light, after about 6 minutes (every single time) the light stays on, but the device reports the off state (OnOff attribute is “false” and the light appears off in the Phoscon App and Home Assistant).
Furthermore, I have noticed that doing a read of the OnOff attribute sets it to “false”, even if it was “true”, before doing the read. Nevertheless, the light stays on.
Is there something I can do?
I should say also that I have a previously bought version of the same dimmer ( _TZ3210_zxbtub8r ) which works without issues.
GitHub issue: TS110E dimmer _TZ3210_k1msuvg6 · Issue #7185 · dresden-elektronik/deconz-rest-plugin · GitHub
Thank you very much for any help!
Looks like _TZ3210_k1msuvg6 is not supported so you need to open a request on GitHub.
Done, thank you!
