I have bough some Moes Smart Buttons, but I haven’t been able to get them to work. These are one button devices with very little documentation.
I have been able to connect it to phoscon and it appears as a button, I have added it to a group but it is not doing anything with my lights. I can see some event logs in phoscon eg
Hello, you can catch with your third app “state/buttonevent” event.
The one on your sample is a “attr” one, useless for you, if you haven’t one, waht is your deconz version ?
I m looking the issue on deconz github, it seem this device haven’t group support in the DDF, can you share the complete device json ? Visible in Phoscon/help/API Information/sensors/X
Do you have access to the GUI ?
If yes, select the noe device, make a right clic then “edit DDF” you will see the DDF used by this device, if not perhaps the problem will be visible.
You haven’t a “custom” DDF for this device ? (even made by error playing with the editor)
Do you have the GUI ?
Take a look in deconz/help/debug view , with flag “info”, “info_l2” (“DDF”), and press the button, you need to see something about “buttonmap”.
Testing is quite challenging. When playing aroung with bindings, I managed to put the button in some kind of state, that prevented the mode switch by 3x pressing the button.
Even after re-pairing this state remained.
Only after I brute-force played around with the unbinding in the GUI I managed to revert it backt to its initial behaviour.
I wonder if this is my issue. I will try playing around to see if I can somehow trick it into changing modes.
The only information I found if pressing 3 time fastly the button, removing the batterie can reset it, but IDK what is the defaut mode.
There is no information to switch mode on the documentation ?
