Hello All,
I’m not the most advanced user, so probably I’m missing something crucial here. I have a raspberry installation with a Conbee 2 stick and can’t link my IKEA STYBAR switch I just bought today
From the web interface it reads:
Version 2.05.74 / 25-2-2020
Firmware 26780700
The firmware I updated via my windows pc using GFFlasher, so I believe this should be the latest firmware. However, the version still shows something from 2020, are these not related? This is may be the Phoscon app version?
I see that the latest version is 2.17.1, but on the web app it reads “This version is up to date”.
So I’m confused if the issues I’m seeing here are related to an outdated firmware/software version, or something else.
I tried pressing the link button 5 times fast (led blinks than stays on for a while and goes off again), while on the webinterface the “OTHER” option is used to link it. Nothing is found after the 3 min timeout. I tried about 20-30 times, no success. I’ve added many AQARA switches with the same method with 0 problems. I’m completely stuck at this point and no idea what to try next…
When I connect to my Conbee stick I do this by entering the raspberry IP adress in a webbrowser. If I use Phoscon App
I get a webpage to which I can’t log in. It also shows a different logo (not the USB stick logo but more like a pocket drive logo). When I try to reset the password It reads that I need to do this within 10 minutes from power cycling which I tried multiple times with 0 success.
