Hi there,
I did a bit of searching already but couldn’t really find someone with the same issue as me.
Today I set up my Tradfri Motion Sensor to turn on the shed light as one walks in.
All good and great, with the phoscon web interface it’s easy to set up and set a 2min timer.
But… somehow the motion sensor also turns on a light in the house, which I don’t want.
I’ve seen this explanation: TRADFRI Motion sensor dark function · Issue #3247 · dresden-elektronik/deconz-rest-plugin · GitHub
Basically it’s a controller, so it can send direct commands. But how do I remove the extra light from turning on now? If it sends direct commands to the shed light I’d be happy.
I tried using the bind menu in the deConz app, but that keeps popping up with timeout failure.
Thanks
