Switches don‘t work
Hi everyone, since yesterday, none of my switches have been turning on the lights. In the web interface, the light turns on, but in reality, nothing happens. The motion detectors turn on the light after three or four minutes of continuous motion, but I can’t turn it off anymore. When I control them via the HomeBridge bridge using my cell phone, they work normally. I have installed the latest beta version, 2.33.2 headless.
Unfortunately, I don’t know how to access the logs in my setup. Can anyone help me? Maybe then we can find a solution quickly….
Hello,“since yesterday”, it mean it have worked previously ? have you try a power cycle ?
You are using Phoscon automation or HomeBridge ones ?
Rebooting and shutting down the VM had no effect. Neither did rebooting the host. Only shutting down the host for 5 minutes resolved the issue.
I am using Phoscon automation.
I still don’t know how to view the logs.
Can try to unplug the gateway. the power on the USB can stay when you reboot the host, so a reboot, don’t restart the gateway.
For logs, if headless, to use the GUI > Access deCONZ GUI in headless setups · dresden-elektronik/deconz-rest-plugin Wiki · GitHub
Or with command lines > deCONZ command line parameters · dresden-elektronik/deconz-rest-plugin Wiki · GitHub
