Option 1: To get debug logs in a GUI installation, open deCONZ and click Help . After that, click Debug View . The following debug levels need to be enabled for proper logging: INFO , INFO_L2 , ERROR , ERROR_L2 , APS , APS_L2 .
Option 2: To get debug logs in a headless installation / ssh session, use the following commands:
When done, exit the process with CTRL+C . You can now start the systemctl service again. Your logs will be printed in the console, as well as saved to a file named debug.txt in the current directory. Be sure to capture at least a few minutes worth of logs. When sharing these logs, DO NOT attempt to paste them into a channel. Instead use a pastebin service such as this or this. When done, don’t forget to disable logging. This is especially important when running off an SD card, as the debug logging will cause unnessecary writes, and might shorten the life of your media.
The same thing happens to me with my heiman smoke detector devices.
I have tested the smoke detector with the zigbee adapter from iobroker with the same conbee. There the problem does not occur. Several data points are updated there more than hourly.
