Good morning,
Last night at 2:22, all Zigbee devices (Firmware: deCONZ_ConBeeIII_0x26550900.bin.GCF) suddenly became undiscoverable. Initially, this affected the directly powered devices like power plugs and lights, and later the temperature sensors and other devices disappeared as well. I am using the ConBee III with Home Assistant in ZHA on a Synology device, running through Docker. Home Assistant recognizes the ConBee stick and indicates that everything is functioning correctly, but only 1 out of 73 devices is being detected (and that one device is the ConBee itself). I have tried restarting Home Assistant and even restored a backup, but the issue persists. Additionally, I am unable to add any new devices via Zigbee.
Here’s what I found in the logfile:
2026-09-17 07:08:04.020 DEBUG (MainThread) [zigpy_deconz.uart] Frame received: 0x0e4d0007002600
2026-09-17 07:08:04.020 DEBUG (MainThread) [zigpy_deconz.api] Received command CommandId.device_state_changed{'status': <Status.SUCCESS: 0>, 'frame_length': 7, 'device_state': DeviceState(network_state=<NetworkState2.CONNECTED: 2>, device_state=<DeviceStateFlags.APSDE_DATA_CONFIRM|APSDE_DATA_REQUEST_FREE_SLOTS_AVAILABLE: 9>), 'reserved': 0} (seq 77)
2026-09-17 07:08:04.020 DEBUG (MainThread) [zigpy_deconz.api] Mismatched response, triggering error in 0.50s
2026-09-17 07:08:04.024 DEBUG (MainThread) [zigpy_deconz.uart] Frame received: 0x124d0009000200260b
2026-09-17 07:08:04.025 DEBUG (MainThread) [zigpy_deconz.api] Received command CommandId.aps_data_request{'status': <Status.SUCCESS: 0>, 'frame_length': 9, 'payload_length': 2, 'device_state': DeviceState(network_state=<NetworkState2.CONNECTED: 2>, device_state=<DeviceStateFlags.APSDE_DATA_CONFIRM|APSDE_DATA_REQUEST_FREE_SLOTS_AVAILABLE: 9>), 'request_id': 11} (seq 77)
2026-09-17 07:08:04.025 DEBUG (MainThread) [zigpy_deconz.api] Clearing existing mismatched response timer
2026-09-17 07:08:04.025 DEBUG (MainThread) [zigpy_deconz.api] Sending CommandId.aps_data_confirm{} (seq=78)
2026-09-17 07:08:04.029 DEBUG (MainThread) [zigpy_deconz.uart] Frame received: 0x044e0013000c002606023b580101a700000000
2026-09-17 07:08:04.030 DEBUG (MainThread) [zigpy_deconz.api] Received command CommandId.aps_data_confirm{'status': <Status.SUCCESS: 0>, 'frame_length': 19, 'payload_length': 12, 'device_state': DeviceState(network_state=<NetworkState2.CONNECTED: 2>,
And now I am out of ideas…
