Hi there,
Having a hard time getting a Conbee 2 to work. My idea was to make a Zigbee gateway with a Raspberry pi1 I still had lying around using RaspBEE. As I couldnt make any connections, I decided to test the ConBEE on my W10 laptop with DeCONZ.
Whatever I try, the ConBEE 2 refuses to be connected. It is recognised in W10 as COM3 and found as device in DeConz, but no connection.
Tried several usb ports, extender cable and powered usb extender, nothing works
I remember that I had the Conbee tested and running on my old laptop incl. pairing with a device. After that it was kept in a drawer for later use, meaning now. So I guess its not broken or anything.
Any ideas to get the ConBEE going? Should I try to flash the firmware?
Hello, If the gateway have already worked, I don’t see why it can not working after a while.
It’s not something you can “broke”
Not a driver issue ? how it look on the “device manager” (I m not sure for the name in english, but it’s the part on window setup where you can see all your devices/hardware).
And yes it’s the good device that is detected
/dev/ttyACM1 | 0x1CF1 | 0x0030 | DE2212065 | ConBee II
Path | Serial | Type
COM3 | DE2675961 | ConBee II
PS C:\Users\a\Downloads\GCFFlasher_Win_V4_04_00\GCFFlasher_Win_V4_04_00>
