Starting deCONZ without GUI on Windows
So I’m trying to startup deCONZ in headless mode (ie without GUI)
Looking at https://github.com/dresden-elektronik/deconz-rest-plugin/wiki/deCONZ-command-line-parameters#available-debug-parameters it gives me the information
platform minimal
In case you want to start headless, use this parameter.
Example: /usr/bin/deCONZ --platform minimal --auto-connect=1
The example is for unix, so adapting it for Windows 10 machine I created a shortcut to the “deCONZ.exe” executable and added parameter to the Target line.
“C:\More Programs\deCONZ\bin\deCONZ.exe” --platform minimal --auto-connect=1
When click my shortcut I get a deCONZ error dialog with the message
“This application failed to start because no Qt platform plugin could be initalized. Reinstalling the applications may fix this problem. Available platform plugins are: windows.”
The error message also appears if I use an alternate Target Line
“C:\More Programs\deCONZ\bin\deCONZ.exe” -platform minimal -auto-connect=1
Any ideas on what might be wrong or other suggestions to run deCONZ headless on Windows ?
I can just add a little more info
  • ‘deCONZ with GUI’ operates ok on my windows machine,
  • the program’s bin folder contains seven 7 dll’s starting Qt5***** including Qt5Core.dll and Qt5Gui.dll.
  • this bin folder is where the shortcut Starts In.
“Example: /usr/bin/deCONZ --platform minimal --auto-connect=1”
seems like you took an “-” to much and thats why it doesn´t work.
Replying to Guatama:
I had already tried
but it didn’t work (gave same error)
Using
“C:\More Programs\deCONZ\bin\deCONZ.exe” -platform minimal --auto-connect=1
as you suggested likewise gave the same error message
Using “C:\More Programs\deCONZ\bin\deCONZ.exe” --auto-connect=1
works fine but of course it’s open deCONZ with the GUI
the problem occurs when I try to use -platform minimal or --platform minimal
David
Using
“C:\More Programs\deCONZ\bin\deCONZ.exe” --platform anyoldtext --auto-connect=1
produces the 'no Qt platform error
but using
“C:\More Programs\deCONZ\bin\deCONZ.exe” --anyoldparam anyoldtext --auto-connect=1
doesn’t give the no Qt error and opens deCONZ with GUI ok
So deCONZ (on Windows) doesn’t like --platform followed by a space
Working with this I tried some other variations that I thought might possibly work
“C:\More Programs\deCONZ\bin\deCONZ.exe” --platform=minimal --auto-connect=1
“C:\More Programs\deCONZ\bin\deCONZ.exe” --platform-minimal=1 --auto-connect=1
“C:\More Programs\deCONZ\bin\deCONZ.exe” --minimal --auto-connect=1
“C:\More Programs\deCONZ\bin\deCONZ.exe” --minimal=1 --auto-connect=1
These don’t produce the no Qt platform plugin error, but they all open deCONZ with the GUI
(ie still not headless).
But the headless mode is possible on windows ?
I was unclear Smanar if you’re
a) making a statement “the headless mode is possible on windows”
or b) questioning whether the headless mode is actually possible at all on windows
So far I haven’t been able to get headless mode to work on Windows. Does anyone have a foolproof method of successfully starting deCONZ in headless mode on a Windows machine ?
In my mind it’s not possible on windows, but from my memory there is an issue somewhere to start it minimised.
I have consulted with Manup.
The parameter was first wrong ( --platform minimal instead of -platform minimal), this was corrected directly.
The problem is actually the missing Qt platform plugin. This will be integrated in the next version of us.
