conrpi
1
I’m new to this forum.
I successfully installed the decons pkgs following: ConBee II Installation.
But I use Raspbian Bulleye.
In the menu I see Programming>deCONZ, but it fails to open.
When I run it on the cmd line it fails
pi@raspberrypi:~ $ /usr/bin/deCONZ-autostart.sh
warning unsupported
missing dependency wiringpi
fix with: sudo apt install -f
I’m not able to install wiringpi, as it seems to be deprecated.
And I read that deCONZ is only supported up to Buster.
What is the timeline for the support of deCONZ for bulleye?
or should I start over again using Buster?
Regards
Mimiix
2
As far as i know you don’t need auto-start.sh. What happens if you run sudo systemctl start deconz-gui ?
conrpi
3
This …
works. But the menu entry does not open the GUI
Mimiix
4
@de_employees perhaps we need to remove the dependency of wiring pi here.
@conrpi you probably need to edit the shortcut in that case.
Did you configure the APT repository?
- Configure the APT repository for deCONZStable
$(lsb_release -cs) main' > \
2.Beta* (alternative)
$(lsb_release -cs)-beta main' > \
(stable or beta depends on which deCONZ version you use)
