Sonoff ZBMiniR2 no status update
I’m using a conbee 3 stick with gateway version 2.28.1
I found the issue #8034 and a linked DDE package https://github.com/dresden-elektronik/deconz-rest-plugin/actions/runs/11896649461/artifacts/2208229929
But the link is marked with an exiration date 2 months ago.
The device is found and could be controlled by the phoscon app, but if I change the state by a switch, the state is not reported to the phoscon app
How can I get it working.
Do you have a link to the github page ?
I m checing the code and there is no DDF for “ZBMINIR2”
Edit:
Have found it DDF for Sonoff ZBMini R2 Extreme (ZBMINIR2) by duffbeer2000 · Pull Request #8034 · dresden-elektronik/deconz-rest-plugin · GitHub
And the bind is here, I don’t see the problem, you have checked direclty in the API ?
Can use Phoscon/help/API information/event.
Or if you have too much event just check the value using Phoscon/help/API information/light/ID
If I click to the Link I get the message " Failed to generate URL to download artifact."
Thank you for this Information.
I have tried the API Information.
Now I see I get the event also by the switch. But it takes up to 30 seconds until it arrives.
Events of other lights I get without any delay.
The switch ist near to my Conbee Stick.
Maybe you could help me to solve this problem
From the DDF there is a “Turbo” mode, you know what is it ?
No, I don’t.
Please try to explain an how do I get the DDF
Hu ? I thought you had it installed.
If you haven’t used something from this page DDF for Sonoff ZBMini R2 Extreme (ZBMINIR2) by duffbeer2000 · Pull Request #8034 · dresden-elektronik/deconz-rest-plugin · GitHub you can’t support this device.
And in all situation you will miss the c++ part
I can’t get it:-(
I’m unable to downoad the DDF because I get an error.
Is it in the betta version?
It is working.
I can connect it to the phoscon App and I’m able to switch it on and off in the app.
Only if I switch it with a hardware switch it takes a lot of time until it will be shown in the app.
No the DDF is not valided, so still in waiting list.
It’s a router, so the legacy can support natively some features, but this one can’t work without the DDF.
How could I get these DDF?
I can’t donwload it from this thread I found them.
I always get an error.
You have the DDF here https://raw.githubusercontent.com/dresden-elektronik/deconz-rest-plugin/dad115b9c9a920bfae8778c320dd8abd5c8f71c4/devices/sonoff/zbminir2_relay.json
But, to have it full working, you have too 3 more files to edit, et recompile the code for the c++ part.
Thank you for your help, but I think I m not able to do this.
I think I have to wait until it ist supported.
Hi could you give this new firmware a try ? It could solve your issue
https://deconz.dresden-elektronik.de/deconz-firmware/deCONZ_ConBeeIII_0x26540900.bin.GCF
I installed the new firmware, but it did not make any difference.
Maybe I have not the right ddf files.
It takes about 15-30 seconds until the hardware switch is recognized and the state changes.
Just wanted to give you a heads up that we found a bug in 54 and you should upgrade to 55:
https://deconz.dresden-elektronik.de/deconz-firmware/deCONZ_ConBeeIII_0x26550900.bin.GCF
I updated to the last version,because this version stopped working every day, but there is still the same problem.
After toggle the external switch it takes up to 20 seconds until this is recognized in the phoscon app.
If I switch it in the phoscon app it works immediatly.
The PR is still in waiting list
How long would this be in waiting list until it is merged?
The change was made half a year ago?
I have the same question, can anybody confirm this is merged to the current release? Many thanks!
No, but there is some information or workaround here DDF for Sonoff ZBMini R2 Extreme (ZBMINIR2) by duffbeer2000 · Pull Request #8034 · dresden-elektronik/deconz-rest-plugin · GitHub
Sorry for my question.
But why could this not be merged into the main branch?
Are there open issues?
Because I could not see any in the discussion.
It works for me but with a very long delay after changing the input switch
