Sonoff ZBMini use as switch
Hi …
is there any way to capture the ON state of ths ZBMini to switch on another Smart plug ?
Maybe by scripting or modifying DDF ?
I want to switch one some smart plugs by switching on the main light which is controlled by a ZBMini.
Thanks for your Support,
michael
Hello, with scripting yes, but scripting with your home automation application.
You can trigger an event is a device have a state change.
Otherwise a scipt with curl GET command to retrieve the state of the first plug and a curl PUT to send the same state to the second.
@Smanar So I need homething like homeassistant ?
@Cadkey Can you explain ? Make a script to retrieve data from one endpoint (how) and transport it to another entpoint ?
Thanks for your help !
Sorry I’m a newbie :slight_smile:
You can use the deCONZ API:
What is you application ?
If you use only phoscon it’s not possible.
You can make your own code using direclty the API, but if you don’t know code, easier to use home automation application.
