I’m looking for a way to control my hue lights even if deCONZ is down.
I had the idea to install a Sonoff Zbmini in my ceiling near the lamp (got no neutral wire behind my wall switches, so that’s why I want to install it in the ceiling).
Then I want to make sure my Hue light bulb will be powered at all times.
Is it possible to group the Sonoff and the Hue light bulb so that they switch on together when I flip the switch, even if my deconz controller is down?
Needs some tests, I’m not sure if the Zbmini supports group bindings in order to control groups directly.
However if it does we can use the same DDF mechanic as is used by the Kobold to specify the group to control.
I’m not sure if I’m gonna buy it, because I can’t seem to find if the sonoff supports long push actions…Wanted a long pus to start a dim action, but I think I need a dimmer dot that that also supports group binding
In that case, this topic is kind of obsolete. That’s the issue with the cheaper devices: you don’t know unless you have them. Not sure if Manup finds the time to figure it out. I think the new Kobold by Dresden-Elektronik is a better choice in that case
