SONOFF SNZB-02DR2 joins network but no node/sensor created (deCONZ-qt6 2.32.5, ConBee III)
I am running:
  • Debian 12 (Bookworm)
  • deCONZ-qt6 2.32.5
  • ConBee III
I am trying to pair a SONOFF SNZB-02DR2 temperature and humidity sensor.
The sensor enters pairing mode correctly. As soon as deCONZ starts searching for new devices, the pairing LED stops blinking after a few seconds, which indicates that the device has joined the network.
I checked the deCONZ database and found the following:
  • Device entry is created in the devices table
  • Device descriptors are created
  • ZCL values are received
  • MAC address appears as: a4:c1:38:0f:27:38:ff:ff
However:
  • No entry is created in the nodes table
  • No sensor is created
  • Device never appears in Phoscon
I also added “SNZB-02DR2” to:
/usr/share/deCONZ/devices/sonoff/snzb-02_multisensor.json
The ConBee III itself is working correctly:
  • Existing devices work normally
  • Backups can be created
  • REST API is operational
I found PR #8488 (“DDF clone for SONOFF SNZB-02DR2 variant”), which appears to add support for this device.
Question:
Does SNZB-02DR2 require a newer deCONZ-qt6 version than 2.32.5, or is there another step required to complete the interview process?
Thank you.
Hello, as you can see the device in deconz, can you you ask for ModelID and Manufacture name ?
Information are visible in the cluster “Basic” 0x0000
The DDF is only working for the couple SNZB-02DR2/SONOFF (and it’s already present in snzb-02_multisensor.json)
