So you can try this DDF
"manufacturername": ["eWeLink","SONOFF"],
"modelid": ["TH01","SNZB-02D"],
"vendor": "SONOFF",
"product": "SNZB-02",
"sleeper": true,
"status": "Gold",
"subdevices": [
"type": "$TYPE_TEMPERATURE_SENSOR",
"restapi": "/sensors",
"uuid": [
"$address.ext",
"0x01",
"0x0402"
"fingerprint": {
"profile": "0x0104",
"device": "0x0302",
"endpoint": "0x01",
"in": [
"0x0000",
"0x0001",
"0x0402"
"name": "attr/id"
"name": "attr/lastannounced"
"name": "attr/name"
"name": "attr/swversion"
"name": "config/battery",
"awake": true,
"refresh.interval": 9000,
"read": {
"at": "0x0021",
"cl": "0x0001",
"fn": "zcl"
"at": "0x0021",
"cl": "0x0001",
"eval": "Item.val = Attr.val / 2"
"default": 0
"name": "config/offset",
"default": 0
"name": "config/on"
"name": "config/reachable"
"name": "state/lastupdated"
"name": "state/temperature",
"awake": true,
"at": "0x0000",
"cl": "0x0402",
"eval": "Item.val = Attr.val + R.item('config/offset').val",
"fn": "zcl"
"default": 0
"type": "$TYPE_HUMIDITY_SENSOR",
"uuid": [
"$address.ext",
"0x01",
"0x0405"
"fingerprint": {
"device": "0x0302",
"endpoint": "0x01",
"in": [
"0x0000",
"0x0001",
"0x0405"
"name": "attr/id"
"name": "attr/name"
"awake": true,
"read": {
"at": "0x0021",
"cl": "0x0001",
"fn": "zcl"
"at": "0x0021",
"cl": "0x0001",
"default": 0
"default": 0
"name": "config/on"
"name": "state/humidity",
"awake": true,
"at": "0x0000",
"cl": "0x0405",
"fn": "zcl"
"default": 0
"bindings": [
"dst.ep": 1,
"cl": "0x0001",
"at": "0x0021",
"dt": "0x20",
"min": 3600,
"max": 7200
"cl": "0x0405",
"at": "0x0000",
"dt": "0x21",
"min": 10,
"max": 3600,
"change": "0x00000064"
"cl": "0x0402",
"at": "0x0000",
"dt": "0x29",
"min": 5,
"max": 1800,
"change": "0x00000014"
On raspbian it’s easy, you can put the DDF on (only 1 solution, the one you prefer):
/home/<DECONZUSER>/.local/share/dresden-elektronik/deCONZ/devices/sonoffthis file will be prioritary and persistent on the official one -
/usr/share/deCONZ/devices/sonoffhere you need to edit the official one, there is already a DDF for this device calledsnzb-02-multisensor.json, at next deconz update the file will be replaced again.
After DDF replacement/modification, need to restart deconz, reset the device and re-include it.
