[solved]SONOFF 01MINIZB don't update it's status when switched manually
Hello together,
i’ve installed a SONOFF 01MINIZB on the guest-wc and my plan was to trigger some other actions when the lights turn on. But unfortunately the zbmini won’t update it’s status when it’s switched by the connected conventional wall mount lightswitch. Did I miss something or is this a bug?
I’ve also tested this with the Philips HUE Bridge. There the status is updated as expected.
I’m running Phoscon on a RaspberryPi 3 with the Conbee II USB-Stick.
Version 2.05.74 / 25.2.2020
Firmware 26490700
Thanks
Hello it’s the “Mini Relay No Neutral (ZBMINI-L/ZBMINIL2)” ?
Can you show the model ID/ Manufacture Name ?
You are on a very old version. You should update deconz.
lol, I got fooled by the Phoscon Webview that says, that everything is up-to-date.
I never touched the running RasPi, so I had to update from strech to bullseye to be able to update deconz. Now everything ist working like a charme and I can explore all the new fancy features of the up-to-date deconz version oO
thanks mate
