What if you start deconz now? Can you select raspbee and connect
No, I even used pkill to stop everything Deconz but still the same
Can you share some new logs?
Well now I can connect. I did
systemctl disable deconz
systemctl disable deconz-gui
rebooted the raspi and manually started deconz. So what should I do to autostart deconz? just one of both?
For the gui, systemctl enable deconz-gui
For the headless, you need deconz.
You cant run both at the same time
Ok, but right now I can’t open the phoscon web app
I got it working right now. But I have to autostart the headless deconz only, when I use the gui the web app is not working, the page is not found. But I can live with that since I never used the gui.
Thank you very much for helping me with that!
Perhaps on another port?
with the headless deconz it’s on 80. As I said I never used or ever knew what to do with the gui. Most importing thing to me is that now everything is up and working again. Just have to migrate the new homebridge now which might take a while.
