Host system: Raspberry Pi 4
- Running method: Raspbian
- Firmware version: 266F0700
- deCONZ version: 2.11.05
- Device: ConBee II
- Is there any other USB or serial devices connected to the host system? No
In phoscon webinterface “Scenes” do not work.
I can switch on/off lights in the groups of the mainpage.
But when I go to a scence and activate the scene “light on” I see the yellow light bulb icon on left menu, but the “real” light do not switch on.
When I go to Scenes editor the scenes are shown correct, and I also can switch the real light inside the scenes editor!
In deconz GUI I get this messages in Info, Error, Error_L2 Level all 10 seconds.
10:28:52:470 Skip idle timer callback, too early: elapsed 89 msec
10:28:53:396 apsUseExtPanid is 0xDDDDDDDDDDDDDDDD but should be 0, start reconfiguration
10:28:53:398 tcAddress is 0x0000000000000000 but should be 0x00212EFFFF06546B, start reconfiguration
10:28:53:399 Skip automatic channel change, TODO warn user
10:29:03:394 apsUseExtPanid is 0xDDDDDDDDDDDDDDDD but should be 0, start reconfiguration
10:29:03:395 tcAddress is 0x0000000000000000 but should be 0x00212EFFFF06546B, start reconfiguration
10:29:03:395 Skip automatic channel change, TODO warn user
10:29:13:394 apsUseExtPanid is 0xDDDDDDDDDDDDDDDD but should be 0, start reconfiguration
10:29:13:395 tcAddress is 0x0000000000000000 but should be 0x00212EFFFF06546B, start reconfiguration
10:29:13:396 Skip automatic channel change, TODO warn user
10:29:23:394 apsUseExtPanid is 0xDDDDDDDDDDDDDDDD but should be 0, start reconfiguration
10:29:23:394 tcAddress is 0x0000000000000000 but should be 0x00212EFFFF06546B, start reconfiguration
10:29:23:395 Skip automatic channel change, TODO warn user
10:29:33:393 apsUseExtPanid is 0xDDDDDDDDDDDDDDDD but should be 0, start reconfiguration
10:29:33:394 tcAddress is 0x0000000000000000 but should be 0x00212EFFFF06546B, start reconfiguration
10:29:33:394 Skip automatic channel change, TODO warn user
10:29:42:418 Current channel 11
10:29:42:451 CTRL got nwk update id 0
10:29:42:483 Device TTL 2991 s flags: 0x3
10:29:43:394 apsUseExtPanid is 0xDDDDDDDDDDDDDDDD but should be 0, start reconfiguration
10:29:43:394 tcAddress is 0x0000000000000000 but should be 0x00212EFFFF06546B, start reconfiguration
10:29:43:395 Skip automatic channel change, TODO warn user
10:29:53:394 apsUseExtPanid is 0xDDDDDDDDDDDDDDDD but should be 0, start reconfiguration
10:29:53:396 tcAddress is 0x0000000000000000 but should be 0x00212EFFFF06546B, start reconfiguration
10:29:53:396 Skip automatic channel change, TODO warn user
10:29:57:411 Skip idle timer callback, too early: elapsed 35 msec
10:30:03:394 apsUseExtPanid is 0xDDDDDDDDDDDDDDDD but should be 0, start reconfiguration
10:30:03:395 tcAddress is 0x0000000000000000 but should be 0x00212EFFFF06546B, start reconfiguration
10:30:03:396 Skip automatic channel change, TODO warn user
10:30:07:390 ZCL attribute report 0x7CB03EAA0A0BEFBC for cluster: 0x0006, ep: 0x03, frame control: 0x18, mfcode: 0x0000
10:30:13:394 apsUseExtPanid is 0xDDDDDDDDDDDDDDDD but should be 0, start reconfiguration
10:30:13:395 tcAddress is 0x0000000000000000 but should be 0x00212EFFFF06546B, start reconfiguration
10:30:13:395 Skip automatic channel change, TODO warn user
In kern.log I have this messages:
Jul 25 19:26:59 phoscon kernel: [183836.813961] usb 1-1.3: USB disconnect, device number 103
Jul 25 19:26:59 phoscon kernel: [183837.121284] usb 1-1.3: new full-speed USB device number 104 using xhci_hcd
Jul 25 19:26:59 phoscon kernel: [183837.260337] usb 1-1.3: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
Jul 25 19:26:59 phoscon kernel: [183837.260360] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 25 19:26:59 phoscon kernel: [183837.260378] usb 1-1.3: Product: ConBee II
Jul 25 19:26:59 phoscon kernel: [183837.260396] usb 1-1.3: Manufacturer: dresden elektronik ingenieurtechnik GmbH
Jul 25 19:26:59 phoscon kernel: [183837.260413] usb 1-1.3: SerialNumber: DE2251475
Jul 25 19:26:59 phoscon kernel: [183837.265223] cdc_acm 1-1.3:1.0: ttyACM1: USB ACM device
Jul 25 19:27:02 phoscon kernel: [183840.398562] usb 1-1.3: USB disconnect, device number 104
Jul 25 19:27:03 phoscon kernel: [183840.821337] usb 1-1.3: new full-speed USB device number 105 using xhci_hcd
Jul 25 19:27:03 phoscon kernel: [183840.960395] usb 1-1.3: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
Jul 25 19:27:03 phoscon kernel: [183840.960418] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 25 19:27:03 phoscon kernel: [183840.960436] usb 1-1.3: Product: ConBee II
Jul 25 19:27:03 phoscon kernel: [183840.960454] usb 1-1.3: Manufacturer: dresden elektronik ingenieurtechnik GmbH
Jul 25 19:27:03 phoscon kernel: [183840.960471] usb 1-1.3: SerialNumber: DE2251475
Jul 25 19:27:03 phoscon kernel: [183840.967275] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
Jul 25 20:27:03 phoscon kernel: [187441.324970] usb 1-1.3: USB disconnect, device number 105
Jul 25 20:27:04 phoscon kernel: [187441.628305] usb 1-1.3: new full-speed USB device number 106 using xhci_hcd
Jul 25 20:27:04 phoscon kernel: [187441.780610] usb 1-1.3: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
Jul 25 20:27:04 phoscon kernel: [187441.780633] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 25 20:27:04 phoscon kernel: [187441.780651] usb 1-1.3: Product: ConBee II
Jul 25 20:27:04 phoscon kernel: [187441.780669] usb 1-1.3: Manufacturer: dresden elektronik ingenieurtechnik GmbH
Jul 25 20:27:04 phoscon kernel: [187441.780685] usb 1-1.3: SerialNumber: DE2251475
Jul 25 20:27:04 phoscon kernel: [187441.785383] cdc_acm 1-1.3:1.0: ttyACM1: USB ACM device
Jul 25 20:27:07 phoscon kernel: [187445.165628] usb 1-1.3: USB disconnect, device number 106
Jul 25 20:27:07 phoscon kernel: [187445.468351] usb 1-1.3: new full-speed USB device number 107 using xhci_hcd
Jul 25 20:27:08 phoscon kernel: [187445.607555] usb 1-1.3: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
Jul 25 20:27:08 phoscon kernel: [187445.607575] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 25 20:27:08 phoscon kernel: [187445.607591] usb 1-1.3: Product: ConBee II
Jul 25 20:27:08 phoscon kernel: [187445.607606] usb 1-1.3: Manufacturer: dresden elektronik ingenieurtechnik GmbH
Jul 25 20:27:08 phoscon kernel: [187445.607621] usb 1-1.3: SerialNumber: DE2251475
Jul 25 20:27:08 phoscon kernel: [187445.612517] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
Jul 25 21:27:08 phoscon kernel: [191046.092265] usb 1-1.3: USB disconnect, device number 107
Jul 25 21:27:08 phoscon kernel: [191046.415424] usb 1-1.3: new full-speed USB device number 108 using xhci_hcd
Jul 25 21:27:08 phoscon kernel: [191046.556535] usb 1-1.3: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
Jul 25 21:27:08 phoscon kernel: [191046.556557] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 25 21:27:08 phoscon kernel: [191046.556576] usb 1-1.3: Product: ConBee II
Jul 25 21:27:08 phoscon kernel: [191046.556594] usb 1-1.3: Manufacturer: dresden elektronik ingenieurtechnik GmbH
Jul 25 21:27:08 phoscon kernel: [191046.556611] usb 1-1.3: SerialNumber: DE2251475
Jul 25 21:27:08 phoscon kernel: [191046.561429] cdc_acm 1-1.3:1.0: ttyACM1: USB ACM device
Jul 25 21:27:12 phoscon kernel: [191049.676905] usb 1-1.3: USB disconnect, device number 108
Jul 25 21:27:12 phoscon kernel: [191050.035445] usb 1-1.3: new full-speed USB device number 109 using xhci_hcd
Jul 25 21:27:12 phoscon kernel: [191050.174529] usb 1-1.3: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
Jul 25 21:27:12 phoscon kernel: [191050.174539] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 25 21:27:12 phoscon kernel: [191050.174547] usb 1-1.3: Product: ConBee II
Jul 25 21:27:12 phoscon kernel: [191050.174554] usb 1-1.3: Manufacturer: dresden elektronik ingenieurtechnik GmbH
Jul 25 21:27:12 phoscon kernel: [191050.174561] usb 1-1.3: SerialNumber: DE2251475
Jul 25 21:27:12 phoscon kernel: [191050.177212] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
Jul 25 22:27:11 phoscon kernel: [194649.067318] usb 1-1.3: USB disconnect, device number 109
Jul 25 22:27:11 phoscon kernel: [194649.422163] usb 1-1.3: new full-speed USB device number 110 using xhci_hcd
Jul 25 22:27:11 phoscon kernel: [194649.561335] usb 1-1.3: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
Jul 25 22:27:11 phoscon kernel: [194649.561345] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 25 22:27:11 phoscon kernel: [194649.561352] usb 1-1.3: Product: ConBee II
Jul 25 22:27:11 phoscon kernel: [194649.561359] usb 1-1.3: Manufacturer: dresden elektronik ingenieurtechnik GmbH
Jul 25 22:27:11 phoscon kernel: [194649.561366] usb 1-1.3: SerialNumber: DE2251475
Jul 25 22:27:11 phoscon kernel: [194649.564143] cdc_acm 1-1.3:1.0: ttyACM1: USB ACM device
Jul 25 22:27:15 phoscon kernel: [194652.907698] usb 1-1.3: USB disconnect, device number 110
Jul 25 22:27:15 phoscon kernel: [194653.262261] usb 1-1.3: new full-speed USB device number 111 using xhci_hcd
Jul 25 22:27:15 phoscon kernel: [194653.401329] usb 1-1.3: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
Jul 25 22:27:15 phoscon kernel: [194653.401351] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 25 22:27:15 phoscon kernel: [194653.401369] usb 1-1.3: Product: ConBee II
Jul 25 22:27:15 phoscon kernel: [194653.401387] usb 1-1.3: Manufacturer: dresden elektronik ingenieurtechnik GmbH
Jul 25 22:27:15 phoscon kernel: [194653.401405] usb 1-1.3: SerialNumber: DE2251475
Jul 25 22:27:15 phoscon kernel: [194653.408236] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
Jul 25 23:27:15 phoscon kernel: [198252.810093] usb 1-1.3: USB disconnect, device number 111
Jul 25 23:27:15 phoscon kernel: [198253.118837] usb 1-1.3: new full-speed USB device number 112 using xhci_hcd
Jul 25 23:27:15 phoscon kernel: [198253.267908] usb 1-1.3: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
Jul 25 23:27:15 phoscon kernel: [198253.267926] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 25 23:27:15 phoscon kernel: [198253.267940] usb 1-1.3: Product: ConBee II
Jul 25 23:27:15 phoscon kernel: [198253.267954] usb 1-1.3: Manufacturer: dresden elektronik ingenieurtechnik GmbH
Jul 25 23:27:15 phoscon kernel: [198253.267966] usb 1-1.3: SerialNumber: DE2251475
Jul 25 23:27:15 phoscon kernel: [198253.272707] cdc_acm 1-1.3:1.0: ttyACM1: USB ACM device
Jul 25 23:27:18 phoscon kernel: [198256.138587] usb 1-1.3: USB disconnect, device number 112
Jul 25 23:27:18 phoscon kernel: [198256.538936] usb 1-1.3: new full-speed USB device number 113 using xhci_hcd
Jul 25 23:27:18 phoscon kernel: [198256.678061] usb 1-1.3: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
Jul 25 23:27:18 phoscon kernel: [198256.678082] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 25 23:27:18 phoscon kernel: [198256.678100] usb 1-1.3: Product: ConBee II
Jul 25 23:27:18 phoscon kernel: [198256.678118] usb 1-1.3: Manufacturer: dresden elektronik ingenieurtechnik GmbH
Jul 25 23:27:18 phoscon kernel: [198256.678135] usb 1-1.3: SerialNumber: DE2251475
Jul 25 23:27:18 phoscon kernel: [198256.690940] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
Jul 26 00:27:19 phoscon kernel: [201857.321155] usb 1-1.3: USB disconnect, device number 113
Jul 26 00:27:19 phoscon kernel: [201857.615562] usb 1-1.3: new full-speed USB device number 114 using xhci_hcd
Jul 26 00:27:19 phoscon kernel: [201857.764550] usb 1-1.3: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
Jul 26 00:27:19 phoscon kernel: [201857.764561] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 26 00:27:19 phoscon kernel: [201857.764568] usb 1-1.3: Product: ConBee II
Jul 26 00:27:19 phoscon kernel: [201857.764576] usb 1-1.3: Manufacturer: dresden elektronik ingenieurtechnik GmbH
Jul 26 00:27:19 phoscon kernel: [201857.764582] usb 1-1.3: SerialNumber: DE2251475
Jul 26 00:27:19 phoscon kernel: [201857.767239] cdc_acm 1-1.3:1.0: ttyACM1: USB ACM device
Jul 26 00:27:23 phoscon kernel: [201861.161105] usb 1-1.3: USB disconnect, device number 114
Jul 26 00:27:23 phoscon kernel: [201861.465568] usb 1-1.3: new full-speed USB device number 115 using xhci_hcd
Jul 26 00:27:23 phoscon kernel: [201861.604627] usb 1-1.3: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
Jul 26 00:27:23 phoscon kernel: [201861.604636] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 26 00:27:23 phoscon kernel: [201861.604644] usb 1-1.3: Product: ConBee II
Jul 26 00:27:23 phoscon kernel: [201861.604651] usb 1-1.3: Manufacturer: dresden elektronik ingenieurtechnik GmbH
Jul 26 00:27:23 phoscon kernel: [201861.604657] usb 1-1.3: SerialNumber: DE2251475
Jul 26 00:27:23 phoscon kernel: [201861.607313] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
Jul 26 01:27:22 phoscon kernel: [205460.807764] usb 1-1.3: USB disconnect, device number 115
Jul 26 01:27:23 phoscon kernel: [205461.113000] usb 1-1.3: new full-speed USB device number 116 using xhci_hcd
Jul 26 01:27:23 phoscon kernel: [205461.252219] usb 1-1.3: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
Jul 26 01:27:23 phoscon kernel: [205461.252242] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 26 01:27:23 phoscon kernel: [205461.252260] usb 1-1.3: Product: ConBee II
Jul 26 01:27:23 phoscon kernel: [205461.252278] usb 1-1.3: Manufacturer: dresden elektronik ingenieurtechnik GmbH
Jul 26 01:27:23 phoscon kernel: [205461.252295] usb 1-1.3: SerialNumber: DE2251475
Jul 26 01:27:23 phoscon kernel: [205461.259169] cdc_acm 1-1.3:1.0: ttyACM1: USB ACM device
Jul 26 01:27:26 phoscon kernel: [205464.648536] usb 1-1.3: USB disconnect, device number 116
Jul 26 01:27:27 phoscon kernel: [205464.943112] usb 1-1.3: new full-speed USB device number 117 using xhci_hcd
Jul 26 01:27:27 phoscon kernel: [205465.102172] usb 1-1.3: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
Jul 26 01:27:27 phoscon kernel: [205465.102194] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 26 01:27:27 phoscon kernel: [205465.102213] usb 1-1.3: Product: ConBee II
Jul 26 01:27:27 phoscon kernel: [205465.102230] usb 1-1.3: Manufacturer: dresden elektronik ingenieurtechnik GmbH
Jul 26 01:27:27 phoscon kernel: [205465.102247] usb 1-1.3: SerialNumber: DE2251475
Jul 26 01:27:27 phoscon kernel: [205465.107057] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
Jul 26 02:27:26 phoscon kernel: [209064.550651] usb 1-1.3: USB disconnect, device number 117
Jul 26 02:27:26 phoscon kernel: [209064.859247] usb 1-1.3: new full-speed USB device number 118 using xhci_hcd
Jul 26 02:27:27 phoscon kernel: [209064.998305] usb 1-1.3: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
Jul 26 02:27:27 phoscon kernel: [209064.998315] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 26 02:27:27 phoscon kernel: [209064.998323] usb 1-1.3: Product: ConBee II
Jul 26 02:27:27 phoscon kernel: [209064.998330] usb 1-1.3: Manufacturer: dresden elektronik ingenieurtechnik GmbH
Jul 26 02:27:27 phoscon kernel: [209064.998337] usb 1-1.3: SerialNumber: DE2251475
Jul 26 02:27:27 phoscon kernel: [209065.000992] cdc_acm 1-1.3:1.0: ttyACM1: USB ACM device
Jul 26 02:27:30 phoscon kernel: [209068.391459] usb 1-1.3: USB disconnect, device number 118
Jul 26 02:27:30 phoscon kernel: [209068.699347] usb 1-1.3: new full-speed USB device number 119 using xhci_hcd
Jul 26 02:27:30 phoscon kernel: [209068.838546] usb 1-1.3: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
Jul 26 02:27:30 phoscon kernel: [209068.838568] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 26 02:27:30 phoscon kernel: [209068.838587] usb 1-1.3: Product: ConBee II
Jul 26 02:27:30 phoscon kernel: [209068.838604] usb 1-1.3: Manufacturer: dresden elektronik ingenieurtechnik GmbH
Jul 26 02:27:30 phoscon kernel: [209068.838621] usb 1-1.3: SerialNumber: DE2251475
Jul 26 02:27:30 phoscon kernel: [209068.843430] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
Jul 26 03:27:32 phoscon kernel: [212670.085984] usb 1-1.3: USB disconnect, device number 119
Jul 26 03:27:32 phoscon kernel: [212670.385624] usb 1-1.3: new full-speed USB device number 120 using xhci_hcd
Jul 26 03:27:32 phoscon kernel: [212670.524740] usb 1-1.3: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
Jul 26 03:27:32 phoscon kernel: [212670.524759] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 26 03:27:32 phoscon kernel: [212670.524775] usb 1-1.3: Product: ConBee II
Jul 26 03:27:32 phoscon kernel: [212670.524790] usb 1-1.3: Manufacturer: dresden elektronik ingenieurtechnik GmbH
Jul 26 03:27:32 phoscon kernel: [212670.524805] usb 1-1.3: SerialNumber: DE2251475
Jul 26 03:27:32 phoscon kernel: [212670.535629] cdc_acm 1-1.3:1.0: ttyACM1: USB ACM device
Jul 26 03:27:35 phoscon kernel: [212673.926599] usb 1-1.3: USB disconnect, device number 120
Jul 26 03:27:36 phoscon kernel: [212674.245615] usb 1-1.3: new full-speed USB device number 121 using xhci_hcd
Jul 26 03:27:36 phoscon kernel: [212674.384791] usb 1-1.3: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
Jul 26 03:27:36 phoscon kernel: [212674.384800] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 26 03:27:36 phoscon kernel: [212674.384807] usb 1-1.3: Product: ConBee II
Jul 26 03:27:36 phoscon kernel: [212674.384814] usb 1-1.3: Manufacturer: dresden elektronik ingenieurtechnik GmbH
Jul 26 03:27:36 phoscon kernel: [212674.384821] usb 1-1.3: SerialNumber: DE2251475
Jul 26 03:27:36 phoscon kernel: [212674.387478] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
Jul 26 04:27:37 phoscon kernel: [216275.621153] usb 1-1.3: USB disconnect, device number 121
Jul 26 04:27:37 phoscon kernel: [216275.932459] usb 1-1.3: new full-speed USB device number 122 using xhci_hcd
Jul 26 04:27:38 phoscon kernel: [216276.071507] usb 1-1.3: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
Jul 26 04:27:38 phoscon kernel: [216276.071517] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 26 04:27:38 phoscon kernel: [216276.071525] usb 1-1.3: Product: ConBee II
Jul 26 04:27:38 phoscon kernel: [216276.071532] usb 1-1.3: Manufacturer: dresden elektronik ingenieurtechnik GmbH
Jul 26 04:27:38 phoscon kernel: [216276.071539] usb 1-1.3: SerialNumber: DE2251475
Jul 26 04:27:38 phoscon kernel: [216276.074197] cdc_acm 1-1.3:1.0: ttyACM1: USB ACM device
Jul 26 04:27:41 phoscon kernel: [216279.205667] usb 1-1.3: USB disconnect, device number 122
Jul 26 04:27:41 phoscon kernel: [216279.562551] usb 1-1.3: new full-speed USB device number 123 using xhci_hcd
Jul 26 04:27:41 phoscon kernel: [216279.702075] usb 1-1.3: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
Jul 26 04:27:41 phoscon kernel: [216279.702093] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 26 04:27:41 phoscon kernel: [216279.702107] usb 1-1.3: Product: ConBee II
Jul 26 04:27:41 phoscon kernel: [216279.702120] usb 1-1.3: Manufacturer: dresden elektronik ingenieurtechnik GmbH
Jul 26 04:27:41 phoscon kernel: [216279.702133] usb 1-1.3: SerialNumber: DE2251475
Jul 26 04:27:41 phoscon kernel: [216279.712902] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
Jul 26 05:27:42 phoscon kernel: [219880.900280] usb 1-1.3: USB disconnect, device number 123
Jul 26 05:27:43 phoscon kernel: [219881.199966] usb 1-1.3: new full-speed USB device number 124 using xhci_hcd
Jul 26 05:27:43 phoscon kernel: [219881.338990] usb 1-1.3: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
Jul 26 05:27:43 phoscon kernel: [219881.339000] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 26 05:27:43 phoscon kernel: [219881.339008] usb 1-1.3: Product: ConBee II
Jul 26 05:27:43 phoscon kernel: [219881.339015] usb 1-1.3: Manufacturer: dresden elektronik ingenieurtechnik GmbH
Jul 26 05:27:43 phoscon kernel: [219881.339021] usb 1-1.3: SerialNumber: DE2251475
Jul 26 05:27:43 phoscon kernel: [219881.341678] cdc_acm 1-1.3:1.0: ttyACM1: USB ACM device
Jul 26 05:27:46 phoscon kernel: [219884.740860] usb 1-1.3: USB disconnect, device number 124
Jul 26 05:27:46 phoscon kernel: [219885.050029] usb 1-1.3: new full-speed USB device number 125 using xhci_hcd
Jul 26 05:27:47 phoscon kernel: [219885.189070] usb 1-1.3: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
Jul 26 05:27:47 phoscon kernel: [219885.189080] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 26 05:27:47 phoscon kernel: [219885.189088] usb 1-1.3: Product: ConBee II
Jul 26 05:27:47 phoscon kernel: [219885.189095] usb 1-1.3: Manufacturer: dresden elektronik ingenieurtechnik GmbH
Jul 26 05:27:47 phoscon kernel: [219885.189102] usb 1-1.3: SerialNumber: DE2251475
Jul 26 05:27:47 phoscon kernel: [219885.191756] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
Jul 26 06:27:48 phoscon kernel: [223486.435262] usb 1-1.3: USB disconnect, device number 125
Jul 26 06:27:48 phoscon kernel: [223486.747011] usb 1-1.3: new full-speed USB device number 126 using xhci_hcd
Jul 26 06:27:48 phoscon kernel: [223486.886040] usb 1-1.3: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
Jul 26 06:27:48 phoscon kernel: [223486.886059] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 26 06:27:48 phoscon kernel: [223486.886075] usb 1-1.3: Product: ConBee II
Jul 26 06:27:48 phoscon kernel: [223486.886091] usb 1-1.3: Manufacturer: dresden elektronik ingenieurtechnik GmbH
Jul 26 06:27:48 phoscon kernel: [223486.886105] usb 1-1.3: SerialNumber: DE2251475
Jul 26 06:27:48 phoscon kernel: [223486.890884] cdc_acm 1-1.3:1.0: ttyACM1: USB ACM device
Jul 26 06:27:52 phoscon kernel: [223490.276067] usb 1-1.3: USB disconnect, device number 126
Jul 26 06:27:52 phoscon kernel: [223490.597107] usb 1-1.3: new full-speed USB device number 127 using xhci_hcd
Jul 26 06:27:52 phoscon kernel: [223490.736243] usb 1-1.3: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
Jul 26 06:27:52 phoscon kernel: [223490.736260] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 26 06:27:52 phoscon kernel: [223490.736274] usb 1-1.3: Product: ConBee II
Jul 26 06:27:52 phoscon kernel: [223490.736287] usb 1-1.3: Manufacturer: dresden elektronik ingenieurtechnik GmbH
Jul 26 06:27:52 phoscon kernel: [223490.736300] usb 1-1.3: SerialNumber: DE2251475
Jul 26 06:27:52 phoscon kernel: [223490.741043] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
Jul 26 07:27:53 phoscon kernel: [227091.970685] usb 1-1.3: USB disconnect, device number 127
Jul 26 07:27:54 phoscon kernel: [227092.275648] usb 1-1.3: new full-speed USB device number 3 using xhci_hcd
Jul 26 07:27:54 phoscon kernel: [227092.413090] usb 1-1.3: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
Jul 26 07:27:54 phoscon kernel: [227092.413100] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 26 07:27:54 phoscon kernel: [227092.413108] usb 1-1.3: Product: ConBee II
Jul 26 07:27:54 phoscon kernel: [227092.413115] usb 1-1.3: Manufacturer: dresden elektronik ingenieurtechnik GmbH
Jul 26 07:27:54 phoscon kernel: [227092.413122] usb 1-1.3: SerialNumber: DE2251475
Jul 26 07:27:54 phoscon kernel: [227092.415775] cdc_acm 1-1.3:1.0: ttyACM1: USB ACM device
Jul 26 07:27:57 phoscon kernel: [227095.811263] usb 1-1.3: USB disconnect, device number 3
Jul 26 07:27:57 phoscon kernel: [227096.124053] usb 1-1.3: new full-speed USB device number 4 using xhci_hcd
Jul 26 07:27:58 phoscon kernel: [227096.275353] usb 1-1.3: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
Jul 26 07:27:58 phoscon kernel: [227096.275377] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 26 07:27:58 phoscon kernel: [227096.275396] usb 1-1.3: Product: ConBee II
Jul 26 07:27:58 phoscon kernel: [227096.275413] usb 1-1.3: Manufacturer: dresden elektronik ingenieurtechnik GmbH
Jul 26 07:27:58 phoscon kernel: [227096.275430] usb 1-1.3: SerialNumber: DE2251475
Jul 26 07:27:58 phoscon kernel: [227096.280129] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
Jul 26 08:27:59 phoscon kernel: [230697.505750] usb 1-1.3: USB disconnect, device number 4
Jul 26 08:27:59 phoscon kernel: [230697.821090] usb 1-1.3: new full-speed USB device number 5 using xhci_hcd
Jul 26 08:27:59 phoscon kernel: [230697.960139] usb 1-1.3: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
Jul 26 08:27:59 phoscon kernel: [230697.960149] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 26 08:27:59 phoscon kernel: [230697.960165] usb 1-1.3: Product: ConBee II
Jul 26 08:27:59 phoscon kernel: [230697.960183] usb 1-1.3: Manufacturer: dresden elektronik ingenieurtechnik GmbH
Jul 26 08:27:59 phoscon kernel: [230697.960195] usb 1-1.3: SerialNumber: DE2251475
Jul 26 08:27:59 phoscon kernel: [230697.962840] cdc_acm 1-1.3:1.0: ttyACM1: USB ACM device
Jul 26 08:28:02 phoscon kernel: [230701.090425] usb 1-1.3: USB disconnect, device number 5
Jul 26 08:28:03 phoscon kernel: [230701.501186] usb 1-1.3: new full-speed USB device number 6 using xhci_hcd
Jul 26 08:28:03 phoscon kernel: [230701.660224] usb 1-1.3: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
Jul 26 08:28:03 phoscon kernel: [230701.660242] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 26 08:28:03 phoscon kernel: [230701.660256] usb 1-1.3: Product: ConBee II
Jul 26 08:28:03 phoscon kernel: [230701.660269] usb 1-1.3: Manufacturer: dresden elektronik ingenieurtechnik GmbH
Jul 26 08:28:03 phoscon kernel: [230701.660282] usb 1-1.3: SerialNumber: DE2251475
Jul 26 08:28:03 phoscon kernel: [230701.671022] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
Jul 26 09:28:03 phoscon kernel: [234302.272899] usb 1-1.3: USB disconnect, device number 6
Jul 26 09:28:04 phoscon kernel: [234302.598011] usb 1-1.3: new full-speed USB device number 7 using xhci_hcd
Jul 26 09:28:04 phoscon kernel: [234302.747098] usb 1-1.3: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
Jul 26 09:28:04 phoscon kernel: [234302.747108] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 26 09:28:04 phoscon kernel: [234302.747116] usb 1-1.3: Product: ConBee II
Jul 26 09:28:04 phoscon kernel: [234302.747123] usb 1-1.3: Manufacturer: dresden elektronik ingenieurtechnik GmbH
Jul 26 09:28:04 phoscon kernel: [234302.747130] usb 1-1.3: SerialNumber: DE2251475
Jul 26 09:28:04 phoscon kernel: [234302.751805] cdc_acm 1-1.3:1.0: ttyACM1: USB ACM device
Jul 26 09:28:07 phoscon kernel: [234306.113518] usb 1-1.3: USB disconnect, device number 7
Jul 26 09:28:08 phoscon kernel: [234306.428144] usb 1-1.3: new full-speed USB device number 8 using xhci_hcd
Jul 26 09:28:08 phoscon kernel: [234306.577214] usb 1-1.3: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
Jul 26 09:28:08 phoscon kernel: [234306.577236] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 26 09:28:08 phoscon kernel: [234306.577254] usb 1-1.3: Product: ConBee II
Jul 26 09:28:08 phoscon kernel: [234306.577272] usb 1-1.3: Manufacturer: dresden elektronik ingenieurtechnik GmbH
Jul 26 09:28:08 phoscon kernel: [234306.577289] usb 1-1.3: SerialNumber: DE2251475
Jul 26 09:28:08 phoscon kernel: [234306.582099] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
Jul 26 10:19:16 phoscon kernel: [237374.479712] usb 1-1.3: USB disconnect, device number 8
Jul 26 10:19:16 phoscon kernel: [237374.776559] usb 1-1.3: new full-speed USB device number 9 using xhci_hcd
Jul 26 10:19:16 phoscon kernel: [237374.915622] usb 1-1.3: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
Jul 26 10:19:16 phoscon kernel: [237374.915631] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 26 10:19:16 phoscon kernel: [237374.915639] usb 1-1.3: Product: ConBee II
Jul 26 10:19:16 phoscon kernel: [237374.915646] usb 1-1.3: Manufacturer: dresden elektronik ingenieurtechnik GmbH
Jul 26 10:19:16 phoscon kernel: [237374.915653] usb 1-1.3: SerialNumber: DE2251475
Jul 26 10:19:16 phoscon kernel: [237374.918317] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
Jul 26 10:19:29 phoscon kernel: [237387.793686] usb 1-1.3: USB disconnect, device number 9
Jul 26 10:19:29 phoscon kernel: [237388.086823] usb 1-1.3: new full-speed USB device number 10 using xhci_hcd
Jul 26 10:19:29 phoscon kernel: [237388.236007] usb 1-1.3: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
Jul 26 10:19:29 phoscon kernel: [237388.236016] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 26 10:19:29 phoscon kernel: [237388.236024] usb 1-1.3: Product: ConBee II
Jul 26 10:19:29 phoscon kernel: [237388.236031] usb 1-1.3: Manufacturer: dresden elektronik ingenieurtechnik GmbH
Jul 26 10:19:29 phoscon kernel: [237388.236038] usb 1-1.3: SerialNumber: DE2251475
Jul 26 10:19:29 phoscon kernel: [237388.242736] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
Jul 26 10:19:33 phoscon kernel: [237391.634397] usb 1-1.3: USB disconnect, device number 10
Jul 26 10:19:33 phoscon kernel: [237391.946949] usb 1-1.3: new full-speed USB device number 11 using xhci_hcd
Jul 26 10:19:33 phoscon kernel: [237392.085970] usb 1-1.3: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
Jul 26 10:19:33 phoscon kernel: [237392.085981] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 26 10:19:33 phoscon kernel: [237392.085989] usb 1-1.3: Product: ConBee II
Jul 26 10:19:33 phoscon kernel: [237392.085996] usb 1-1.3: Manufacturer: dresden elektronik ingenieurtechnik GmbH
Jul 26 10:19:33 phoscon kernel: [237392.086003] usb 1-1.3: SerialNumber: DE2251475
Jul 26 10:19:33 phoscon kernel: [237392.088677] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
