Ok, so my bad sorry, this device is not powered, so its realy a switch.
I have found the DDF for this device https://github.com/dresden-elektronik/deconz-rest-plugin/blob/master/devices/tuya/_TZ3000_rco1yzb1_switch.json
And this DDF don’t have group part, can you try this one
"manufacturername": "_TZ3000_rco1yzb1",
"modelid": "TS004F",
"product": "TS004F",
"sleeper": true,
"status": "Gold",
"type": "$TYPE_SWITCH",
"restapi": "/sensors",
"0x01",
"0x0006"
"name": "attr/swversion"
"name": "config/on"
"name": "config/reachable"
"name": "config/group",
"default": "auto"
"name": "state/buttonevent"
"name": "config/battery",
"awake": true,
"at": "0x0021",
"cl": "0x0001",
"eval": "Item.val = Attr.val / 2;",
"fn": "zcl"
"name": "state/lastupdated"
"bindings": [
"cl": "0x0001",
"at": "0x0021",
"dt": "0x20",
"min": 60,
"max": 3600,
"change": "0x00000001"
"bind": "groupcast",
"cl": "0x0006",
"config.group": 0
"cl": "0x0008",
"config.group": 0
You can replace it, edit it, or create a new one in the user folder then restart deconz.
