I’ve got the deCONZ integration installed in Home Assistant Operating System on a Raspberry Pi. Using Phoscon, I was able to pair a Silvercrest Smart Button. However, I want to be able to use button press events in Home Assistant and that doesn’t seem possible at the moment.
It doesn’t help that I’m not that familiar with HA, and therefore don’t know how I should expect the button to show up, but it looks like it’s only showing the button’s battery’s status. I can actually create an automation using one of these two triggers that are provided in HA’s Automation GUI:
“” button pressed
“” button double clicked
…but the Actions associated with the Automation are not carried out when press the button.
When listening for deconz_event
on HA’s event bus, nothing shows up when I press the button.
I’ve tried associating the switch with a light in Phoscon’s user interface. After this, when I press the button, the icon of the light briefly lights up in Phoscon, then turns off again. The actual physical light remains turned off.
Debugging: I’m not sure how to use a native VNC application to be able to copy the debugging log, since copy-pasting doesn’t work from the HA integration. I’m not sure if I could even enable the VNC server, since the Raspberry Pi isn’t running Linux.
My deCONZ version is 2.19.3
I would be very glad to receive tips! Thank you.
Danny
