Set default txpower Conbee III
I want to increase the default transmission power of Conbee III running Thread firmware from 5 dBm to 10 dBm. Publishing the source modifications mentions here would also be helpful.
I did a little research, there is no good solution here without modifying the add-on.
Assuming you’re using the HA add-on? In that case the power is set by the Home Assistant OpenThread Border Router add-on, not the firmware. From host side it requests 6 dBm at every startup, and there’s no setting for it in the add-on options. You can change it only from a shell on the Home Assistant host:
docker exec -it addon_core_openthread_border_router ot-ctl txpower 10
But this is not persistent and would be reconfigured next time add-on starts. Also good to know the shown 5 dBm are actually 5.8 dBm just shown clipped according to my quick research.
