New to this - so go easy
Have a conbee 2 on windows.
Fantem ZB003-X multi sensor ( shown in blackadders as compatible ).
Can’t get phoscon to find it. TBH no matter what combination of “press action button” on the sensor I do the led flashes still remain the same. ( Tried a different unit and still no joy ).
Any advice welcome!
Mimiix
April 19, 2023, 8:16pm
2
Does it show in deconz?
If it doesnt can you make logs while pairing?
Also, Blackadder is not the official list. Does Blackadder shows what GitHub issue added it ?
I managed to get it to add. Deconz shows it ; but labels it as a ‘switch’ …
Mimiix
April 20, 2023, 3:14pm
4
Can you read the basic cluster and provide a screenshot?
Thanks for your help. here you go…
Smanar
April 20, 2023, 3:41pm
6
Strange.
I don’t found this device on legacy code, but as the name is “Switch X” and not “0xXXXX” mean the device is reconised.
Perhaps something generic in code …
Edit:
opened 03:51PM - 03 Mar 21 UTC
closed 03:24PM - 11 May 21 UTC
## Device
- Product name: Tuya ZigBee Multi-Sensor 4 in 1 Smart PIR Motion Fe… uchtigkeit Licht Temperatur Sensor
- Manufacturer: _TZ3210_zmy9hjay
- Model identifier: TS0202
- Sensor
- Other: PIR, Temperature, Humidity, Luminance 4in1 sensor
- Link to [product page](https://de.aliexpress.com/item/1005001878974427.html?spm=a2g0s.9042311.0.0.255f4c4dj8zNLu)
## Screenshots
______
Thank you very much for your help.
The previous one was a “_TZ3210_zmy9hjay” so you have a clone, better to make a device request as now need to use a DDF to support it.
The legacy code support only thoses one
{"_TZ3210_rxqls8v0", "TS0202", "Fantem", "Tuya_SEN Multi-sensor"},
{"_TZ3210_zmy9hjay", "TS0202", "Fantem", "Tuya_SEN Multi-sensor"},
Thanks. New to this as I say.
How do I make a device request?; What is a DDF!?
Mimiix
April 20, 2023, 4:17pm
8
Looks like its not supported after checking the github for the manufacturer name.
Blackadder links to https://github.com/dresden-elektronik/deconz-rest-plugin/issues/4511 but in this case, The manufacturer changed the chip inside the device thus not supported by deconz.
Please open a new request here:
