In one of our installations, the light switches stop/restart working whenever we reload the Phoscon web app (index.html).
I’ve switched on --dbg-prot=1 to investigate. Whenever I reload the page, I start seeing a lot of the following lines:
send cmd seq: 233, CMD_STATUS failed, ret: -1
and the system stops working, i.e. light switches don’t work.
After reloading the page again, the system works again. I.e., reloading the page “toggles” the functioning of the system (at least 9/10 times).
The same also happens when editing the switches of a group (group-switches.html), for example, and then returning to the main page (index.html), presumably because this loads/starts the index.html page again.
Version: 2.21.01 / 9/19/2022
Firmware: 26690700
IP: 192.168.0.3
Device: Raspberry Pi 4, with a RaspBee II attached to the GPIO
OS: Debian 11.6 (bullseye)
DeCONZ source: deb http:/phoscon.de/apt/deconz bullseye-beta main
I’ve uploaded two excerpts of the log here:
- Version: 2.21.01 / 9/19/2022Firmware: 26690700IP: 192.168.0.3Device: Raspb - Pastebin.com
Addendum A:
The error first occurs in version 2.20.00. It does not occur in 2.19.03.
Addendum B:
When deCONZ is in error mode (i.e. CMD_STATUS failed being displayed on the command line), it needs to be quit with kill -9. Simple Ctrl-C or kill does not work. When it works in normal mode, it can simply be quit using Ctrl-C or kill.
