"self made DDF" after update
before the latest update i’m using two ddf Files. with the latest release these devices are included, one ddf files disappear but one (for _TZ3000_gjnozsaz) is still here, but in “Roota”
Add DDF for Tuya smart plugs _TZ3000_gjnozsaz and _TZ3000_zloso4jk #6131
why is it so?
Matze20211
There is 2 folder to put DDF, one is for deconz and updated every time you update deconz, an other it’s for the user, and not impacted by deconz
You are speaking about this one https://github.com/dresden-elektronik/deconz-rest-plugin/blob/master/devices/neo/NAS-WR01B_2.json ?
I m not sure to understand your problem, you miss one DDF ? or asking why deconz have modified them ?
