I needed a dimmerpuck and stumbled upon the Schneider Wiser CCT5010-0002 but i couldn’t find any information on it being compatible with Deconz besides for a couple of forum topics on some Wiser products working through DDF, so i bought it in hope it was compatible with the existing DDFs.
After installation i got happy that Deconz found it and it worked, however there is an inconvenience that i have no ide how to debug.
There is a slight delay sometimes when i turn it on, about 1-10 seconds, this does not happen everytime which makes it even harder to debug.
I’m trying to locate the ddf on github to open an “issue”, however i can’t find it on github and the ddf just identifys as:
“manufacturername”: “Schneider Electric”,
“modelid”: “PUCK/DIMMER/1”,
“product”: “PUCK/DIMMER/1”,
“sleeper”: false,
“status”: “Draft”,
“subdevices”: [
If i look at the event api in deconz everything fires correctly, state changes immediately etc.
I got multiple other dimmers that works flawlessly so i don’t think the issue is the Zigbee network.
