I created a simple schedule to switch a light off after 10 seconds.
I tried both via a group with a scene recall or via a state change of the lamp id.
Both cases did not work.
Running via in a terminal window via the command:
/usr/bin/deCONZ -platform minimal --dbg-aps=0 --dbg-info=1 --dbg-error=2
I saw the following error:
schedule was neither light nor group nor sensor request
This is the JSON I used to create the schedule using a scene via Postman:
"name": "Lamp2Uit",
"description": "Doe lamp 2 uit",
"autodelete":false,
"command": {
"address": "http://<ip address>/api/<key>/groups/5/scenes/2/recall",
"method": "PUT",
"body": { }
"time": "PT00:00:10"
Via Postman executing
directly did work.
I’m running version 2.17.01 / 01/07/2022
firmware 26720700
What is going on here?
