Everything has been working fine for 3 years.
After a restart all scenes were not working anymore.
All lights (in 4 groups) can be switeched and dimmed correctly using phoscon app, but scenes are not working anymore.
When selecting a scene in phoscon the scene in phoscon app is correctly visulized, thus, all lights visualized as on/off with according value in %.
But nothing happens to the lights.
When klicking on a light (on/off) or changing it’s intensity value the lights are siwtched and intensity is correctly set.
What I have tried so far without any effect:
reboot PI
update Phoscon
deletion of all scenes and cration of new scene
checked several attributes of devices with deconz:
scenes capacity limit not reached
all scenes in deconz deleted
read of attribute allways yields “scene valid = false”
I have been switching all lights by scenes using Busch Jäger switches. Thus at the time beeing my system ist kind of useless because nothing can be switched by physical switches in the rooms.
I have no idea anymore regarding this problem. Any suggestions?
Sounds like a bug in the RaspBee FW to me. I would re install the firmware with GCFFlasher. The network settings are kept in deCONZ but I would recommend making a backup first.
Perhaps re-flashing resolves some hickups in the firmware if this caused the problems.
Everything worked fine for months and all of sudden no scenes can be switched anymore. Similar setup, too. Rasperry Pi 4B, raspbee II, a lot of lights and window covering devices and busch-jäger mains powered switches. Nothing on the software side was changed from me before it happened.
Now I just updated everything on the pi, in home assistant and moved up to deconz 2.24.3. Sadly the problem is still there and my whole setup which depends on scenes is not working anymore.
Restored the last working backup, but it still does not work. In addition (other topic / thread) the whole network looses connection to one device after the other.
Both cases seem to bei related to these “0x0000000000000000 error APSDE-DATA.confirm: 0xD2 on task” errors.as described by the First poster, because they are in my logs, too.
I just had the very same issue - after running for > 12 months without interruption, during short power loss the raspbee II on a Raspberry Pi 4 rebooted and after that all lights were there as usually, but none of the groups nor scenes worked anymore (no switching on/off of groups, ..). Lights were perfectly usable one per one directly.
Re-flashing the firmware (even though the verison stayed the same) was the first thing that helped.
