RodRet not pairing with Conbee 2
I have several Ikea lamps and switches in my setup.
Today i buy the little Rodret on/of switch.
But i cant get it to pair with my conbee 2.
The Stick is on Version 2.30.2 and the switch is on 1.0.57 both last versions.
I have an old ikea Gateway for testing, there the switch is connecting without problem.
Any Idee??
Hello, take a look on the GUI to see if it’s not a new model ID.
ok, where in the gui do i have to look? The pairing failed so i cant see any ID of the switch. AT the backplate of the Switch ist “Type: E2201”.
I was looking for some kind of log in the webgui from deconz/Phoscon.
btw. the conbee2 runs on a linux ubuntu server.
A device can be in the zigbee network but not in the API.
So you need to see to see it in the GUI, you need to see the node, if you can’t see the device in the GUI, the pairing procedure is probably bad.
Found this on Github, it helped, now it worked.
Nice, so it was a new model.
