This switch did run out of battery so I replaced with a new battery of the correct type. It showed Red led if pressing a button when on the old battery.
After battery replacement it keeps showing green light on the switch itself like it did before.
So looks internally ok with the new battery.
However the battery level in deCONZ for this device still shows red.
Where all the others devices (mostly sensors) show green like it should.
Some of the sensors have had a battery replacement in the past and that was reflected ok after a day or so.
So somehow the new battery status is not updated, even after two weeks.
What’s the best step to take here?
I’m new on understand DDE code, looking into the DDE of this switch shows battery Read - 4000 s which looks to me it needs to update this every 1+ hr. which in this case is clearly not done.
