I use deCONZ and Phoscon along with Node Red for home automation. I am running everything on Windows 10. I have encountering a problem for the second time that mysteriously resolved itself the first time. Suddenly, after starting up deCONZ and then opening the Phoscon App from the deCONZ interface as I normally do, I am unable to log into Phoscon. Instead of the normal login screen, I get a “Set login password” screen stating that a new login password must be set to increase security. So, I try to enter a new password having at least 8 characters as instructed and I am unsuccessful in logging in. I get a “Login failed” with the new password.
I cleared the cache thinking that might help. But I still have the problem. I also used a new tab and retyped the Phoscon login hoping it would bring me to the usual login screen. I was unsuccessful.
The last time this happened I left things for a while, came back and was able to log into Phoscon normally. So, this is rather confusing. At this point my home automation system is crippled.
Hi, I did what you suggested and see the device and logs but I do not know what to do from here. I clicked the “Phoscon App” button in the deCONZ interface but again had the same problem where it wants to set a new login password but won’t take the a new password.
Please advise.
Thanks
If you enable logging in deconz/help/debug view with flags “info” “info_l2” “error” and “error_l2” and try to logging again, I hope to see usefull information about the problem in deconz log.
