This stable release is the successor of v2.15.2-beta version.
Changes
- DDF for ORVIBO Zigbee Dry Contact CM10ZW #5985
- DDF for Xiaomi Mijia contact sensor (MCCGQ01LM) #5979
- DDF for Sunricher TERNCY-DC01 contact sensor #5997
- DDF gold status for LK Wiser and Philips Hue devices #5991
- DDF improve Xiaomi GZCGQ01LM, WSDCGQ01LM and WSDCGQ11LM #5990
- Update DDF for the Sinope TH1124ZB #5988
- Add DDF functions to sync time #5982
- Fix battery icon not shown for DDF devices #5989
- DEV poll state machine, harden “none” parse function handling #5995
- Device code improve pairing #5983
- Debug log output to verify that file permissions are correct for config.ini and zll.db.
- DDF logging output moved from INFO to DDF levels.
- Fix old DDF files be part of .deb packages.
- Fix ZCLDB ZCL attribute sets handling and view in Cluster Info Panel.
Note iCasa Pulse 4S switch
There is a open regression #5981. The release contains a few improvements in #5983 and 162ea3 but this needs further testing. Therefore if you have this switch it might be worth to wait for the followup release.
A special thanks to all contributors of the deCONZ GitHub community.
