This beta release is the successor of v2.15.0-beta version.
Changes
- DDF for Sunricher 2/4/8 button switches (also branded as EcoDim, SLC, Namron, ROBB) #5903
Important: If you have one of these switches please check the linked pull request, as there could be breaking changes. - DDF for Xiaomi H1 single rocker switch (neutral wire) WS-EUK03 #5919
- DDF for Xiaomi H1 dual rocker switch (neutral wire) WS-EUK04 #5893
- DDF for Xiaomi temperature/humidity sensor (WSDCGQ01LM) #5914
- DDF for Blitzwolf BW-SHP13 smart plug #5913
- DDF for Blitzwolf BW-SHP15 smart plug #5945
- DDF for Tuya water sensor (_TZ3000_d16y6col) #5924
- DDF for Danfoss Ally thermostat #5793 #5943
- DDF for THIRDREALITY motion sensor Pet Friendly 3rMS16BZ #5941
- DDF for ubisys J1 window covering controller #5894
- DDF cleanup Develco/frient KEPZB-110, add missing items for docs #5907
- DDF add missing files for doorlocks #5906
- DDF add extra consumption/power fields for future usage #5890
- DDF remove path attribute and rename DDF file for Owon THS317-ET #5920
- DDF various updates and additions #5892
- DDF don’t create DeviceJs instance on each “parse” invocation (performance) #5932
- DDF initial support for top level “matchexpr” property #5933
- DDF support sub device “meta” objects #5935
- Add thermostat variant for Centralite Pearl 3 thermostat #5937
- Extend functionality of LK FUGA Wiser switches #5878
- Enable setting config/delay on IAS presence sensor for MOSZB-140 #5895
- Extended 4-button Tuya scene switch support to include TS0044 _TZ3000_wkai4ga5 #5881
- Button handler skip some modelid checks; improve sensor.mode #5936
- Don’t use scientific floating point precision in REST API JSON responses #5942
- Fix to return only available buttons in state/buttonevent introspection #5934
- Fix DDF handling of negative values and values above 2^52 #5910
- Fix negative temperature is 0 in Phoscon App #5884
- Fix initally set value in electrical measurment cluster, if value is 0 #5915
- Fix missing eval in parse functions #5948
- Fix SEGV when REST API is called for non existing sensor id #5885
- Update ArduinoJSON to v6.19.4 #5940
- Fix deCONZ Cluster Info Panel read attributes confirmation handling.
- Fix possible SEGV in processing node links (rare).
- Double performance of drawing node links.
A special thanks to all contributors of the deCONZ GitHub community.
