(If it is not the right category for this topic, please let me know where is best to ask the question)
Context: I’m trying to add a new device to the rest API (T0601 Essentials).
I’m currently using deconz Docker container (marthoc/docker-deconz) with no issues
I compiled the modified libde_rest_plugin.so according to the instructions, but when I replace it inside marthoc/docker-deconz container, the modified plugin is not loaded. So i tried to recompile the plugin without modifiying the source code, but the issue is still there.
- Cloned deconz-rest-plugins repo
- Selected v2.12.6 tag
- Created the libde_rest_plugin.so plugin using a containerized debian buster setup, to duplicate exactly the needed environment, following the readme
- Built a docker-deconz image replacing the original libde_rest_plugin.so with the one just compiled.
- Runnig the docker-deconz container, the logs are the following: (note the absence of libde_rest_plugin.so)
deconz | 13:34:33:910 ZCLDB init file /root/.local/share/dresden-elektronik/deCONZ/zcldb.txt
deconz | 13:34:34:212 found node plugin: libde_signal_plugin.so - Signal Monitor Plugin
deconz | 13:34:35:063 found node plugin: libstd_otau_plugin.so - STD OTAU Plugin
deconz | 13:34:37:883 Device firmware version 0x26720700 ConBee II
Expected behavior
In logs, I expected to see this (The normal behavior)
deconz | 13:23:22:606 found node plugin: libde_rest_plugin.so - REST API Plugin
deconz | 13:23:22:608 found node plugin: libde_signal_plugin.so - Signal Monitor Plugin
deconz | 13:23:23:456 found node plugin: libstd_otau_plugin.so - STD OTAU Plugin
Environment
deconz | [marthoc/deconz] Current deCONZ version: 2.12.06
- Host system: NAS
- Running method: Marthoc Docker container
- Firmware version: (26720700)
- deCONZ version: (2.12.06)
- Device: ConBee II
- Is there any other USB or serial devices connected to the host system? No
deCONZ Logs
deconz | [marthoc/deconz] NOVNC port: 6080
deconz | QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
deconz | libpng warning: iCCP: known incorrect sRGB profile
deconz | 13:34:33:556 HTTP Server listen on address 0.0.0.0, port: 80, root: /usr/share/deCONZ/webapp/
Additional context
If I rebuild the docker-deconz image, exactly as I described above but simply not replacing the libde_rest_plugin.so file, the plugin is detected. I made sure that the file was executable and running ldd shows no issues. I tried to set up debug_info to 2, but in logs I saw no indication of why the plugin was not found/loaded. Being able to see the reason would be great
