I’m struggling to find documentation on next steps –
I currently have the pi plugged into a monitor, and can login to the account.
I am comfortable connecting to network, and can setup SSH.
What are the basic “getting started” directions to use?
As far as I know, the Pi will run Deconz, and then another computer will be used to get into the web ui?
Does deconz have to be started? Is there a command to verify status? I’m assuming that once it’s on the network and I have the IP address, it should be up and running?
But you are using the pi for other thing ? why you need more performance ?
With a pi 1 perhaps, I haven’t tested, but a pi 3 … There is no performances issues, we are in 2022, even my TV have a desktop.
I have a pi 3 with deconz, my home automation application, some sound servers, and a desktop.
Render a desktop is not hard for current hardware.
I’m using a Pi 3B+ with Docker. With it I’m running: deconz, zwave2mqtt, mqtt, and adguardhome.
All those and the thing still has some processor power and RAM to spare. It’s capable of running many things at once so should easily handle deconz all by itself. I run the “headless” version like you.
