Hello.
Im wondering if it is possible to combine devices mentioned in topic to work together properly - Raspberry Pi 4 + POE HAT + Raspbee 2. Also, will Raspberry Pi 4 with 2 GB ram will be sufficient?
Hello.
I haven’t checked it myself but from what I read the POE hat is only using I2C, the RaspBee needs just the UART VCC and GND pins. 2 GB should be plenty enough ![]()
My rpi3 is running with 590Mb memory reserved.
Just for the records and not that it matters: I had deconz run on a RPi Zero for years with lots of other stuff. Now migrated to a Zero2.
