I’m trying to setup a new RaspBee II device on a Raspberry PI 4 B with Openhabian (Raspbian-based, headless) OS. But it does not pair with any (mostly Xiaomi Mi) sensor. Log file attached.
How can I further debug ?
- Followed the installation instructions from de phoscon website
- Output of
ps aux | grep "deCONZ\|deconz"
command
root 351 0.1 0.0 8144 2844 ? Ss 18:29 0:00 /bin/bash /usr/bin/deCONZ-update2.sh
root 422 0.4 0.0 8540 3168 ? Ss 18:29 0:00 /bin/bash /usr/bin/deCONZ-WIFI2.sh
openhab+ 441 3.6 1.0 128376 40668 ? Ssl 18:29 0:01 /usr/bin/deCONZ -platform minimal --http-port=80
openhab+ 2291 0.0 0.0 7684 552 pts/0 S+ 18:29 0:00 grep --color=auto deCONZ\|deconz
- Reported gateway details
- Attempted to connect these sensors
- Xiaomi Mi GZCGQ01LM Light sensor
- 2 different Xiaomi Mi MCCGQ01LM door/window sensors
- Xiaomi MI RTCG01LMQ presence detection sensor
- Xiaomi MI RTCG11LMQ presence detection sensor
- Attempted to connect these switches
- SONOFF SNZB-1
- Xiaomi MI WXKG01LMO
- Other things tried
- Changed the batteries on all sensors
- Attempted the same with a ConbeeII stick instead of the Raspbee device
- Log (including pairing attempts)
18:33:53:146 HTTP Server listen on address 0.0.0.0, port: 80, root: /usr/share/deCONZ/webapp/
18:33:53:283 COM: /dev/ttyUSB0 : RFXtrx433 (0x0403/0x6001)
18:33:53:283 COM: /dev/ttyAMA0 : (0x0000/0x0000)
18:33:53:283 dev /dev/ttyAMA0 (/dev/ttyAMA0)
18:33:53:283 COM: /dev/ttyS0 : (0x0000/0x0000)
18:33:53:283 ZCLDB init file /home/openhabian/.local/share/dresden-elektronik/deCONZ/zcldb.txt
18:33:53:457 DDF: bindings:
18:33:53:457 DDF: manufacturername: innr
18:33:53:457 DDF: modelid: SP 120
18:33:53:457 DDF: path: /devices/innr/sp_120.json
18:33:53:457 DDF: product: SP 120
18:33:53:457 DDF: schema: devcap1.schema.json
18:33:53:457 DDF: sleeper:
18:33:53:457 DDF: status: Silver
18:33:53:457 DDF: subdevices:
18:33:53:457 DDF: loaded resource item descriptor: attr/id
18:33:53:457 DDF: loaded resource item descriptor: attr/lastannounced
18:33:53:457 DDF: loaded resource item descriptor: attr/lastseen
18:33:53:457 DDF: loaded resource item descriptor: attr/manufacturername
18:33:53:457 DDF: loaded resource item descriptor: attr/modelid
18:33:53:457 DDF: loaded resource item descriptor: attr/name
18:33:53:457 DDF: loaded resource item descriptor: attr/swversion
18:33:53:457 DDF: loaded resource item descriptor: attr/type
18:33:53:457 DDF: loaded resource item descriptor: attr/uniqueid
18:33:53:457 DDF: loaded resource item descriptor: state/alert
18:33:53:457 DDF: loaded resource item descriptor: state/on
18:33:53:457 DDF: loaded resource item descriptor: state/reachable
18:33:53:457 DDF: loaded resource item descriptor: config/on
18:33:53:458 DDF: loaded resource item descriptor: config/reachable
18:33:53:458 DDF: loaded resource item descriptor: state/consumption
18:33:53:458 DDF: loaded resource item descriptor: state/lastupdated
18:33:53:458 DDF: loaded resource item descriptor: attr/id
18:33:53:458 DDF: loaded resource item descriptor: attr/lastannounced
18:33:53:458 DDF: loaded resource item descriptor: attr/lastseen
18:33:53:458 DDF: loaded resource item descriptor: attr/manufacturername
18:33:53:458 DDF: loaded resource item descriptor: attr/modelid
18:33:53:458 DDF: loaded resource item descriptor: attr/name
18:33:53:458 DDF: loaded resource item descriptor: attr/swversion
18:33:53:458 DDF: loaded resource item descriptor: attr/type
18:33:53:458 DDF: loaded resource item descriptor: attr/uniqueid
18:33:53:458 DDF: loaded resource item descriptor: config/on
18:33:53:458 DDF: loaded resource item descriptor: state/current
18:33:53:458 DDF: loaded resource item descriptor: state/power
18:33:53:458 DDF: loaded resource item descriptor: state/voltage
18:33:53:458 DDF: manufacturername:
18:33:53:458 DDF: modelid:
18:33:53:458 DDF: product: FLS-PP lp
18:33:53:458 DDF: schema: devcap1.schema.json
18:33:53:458 DDF: sleeper:
18:33:53:459 DDF: status: Silver
18:33:53:459 DDF: subdevices:
18:33:53:459 DDF: loaded resource item descriptor
**removed for brevity**
18:33:53:500 DDF: loaded resource item descriptor: config/battery
18:33:53:500 DDF: loaded resource item descriptor: config/on
18:33:53:500 DDF: loaded resource item descriptor: config/reachable
18:33:53:500 DDF: loaded resource item descriptor: state/lastupdated
18:33:53:500 DDF: loaded resource item descriptor: state/buttonevent
18:33:53:500 DDF: loaded resource item descriptor: state/eventduration
18:33:53:520 parent process -bash
18:33:53:520 gw run mode: normal
18:33:53:520 GW sd-card image version file does not exist: /home/openhabian/.local/share/dresden-elektronik/deCONZ/gw-version
18:33:53:520 sd-card cid: 035344535530384780ffffffff00e600
18:33:53:521 DB sqlite version 3.27.2
18:33:53:523 DB PRAGMA page_count: 46
18:33:53:523 DB PRAGMA page_size: 4096
18:33:53:523 DB PRAGMA freelist_count: 0
18:33:53:523 DB file size 188416 bytes, free pages 0
18:33:53:523 DB PRAGMA user_version: 9
18:33:53:523 DB cleanup
18:33:53:523 DB create temporary views
18:33:53:524 DB view [0] created
18:33:53:524 DB view [1] created
18:33:53:524 DB view [2] created
18:33:53:524 DB view [3] created
18:33:53:525 sql exec SELECT apikey,devicetype,createdate,lastusedate,useragent FROM auth
18:33:53:526 sql exec SELECT key FROM config2
18:33:53:527 sql exec SELECT key,value FROM config2
18:33:53:527 Load config UTC: 2021-12-26T17:29:19 from db.
18:33:53:527 Load config announceinterval: 45 from db.
18:33:53:527 Load config announceurl: https://phoscon.de/discover from db.
18:33:53:527 Load config apiversion: 2.13.04 from db.
18:33:53:527 Load config bridgeid: 00212EFFFF08B871 from db.
18:33:53:527 Load config datastoreversion: 93 from db.
18:33:53:527 Load config dhcp: true from db.
18:33:53:527 Load config disablePermitJoinAutoOff: false from db.
18:33:53:527 Load config discovery: false from db.
18:33:53:527 Load config factorynew: false from db.
18:33:53:527 Load config fwneedupdate: false from db.
18:33:53:527 Load config fwupdatestate: idle from db.
18:33:53:527 Load config fwversion: 0x26690700 from db.
18:33:53:527 Load config gateway: 127.0.0.1 from db.
18:33:53:527 Load config group0: 65520 from db.
18:33:53:527 Load config groupdelay: 50 from db.
18:33:53:527 Load config gwpassword: $1$8282jdkm$mk8ipTFEkrhungZTTClLh0 from db.
18:33:53:527 Load config gwusername: delight from db.
18:33:53:527 Load config homebridge: not-managed from db.
18:33:53:527 Load config homebridge-pin: from db.
18:33:53:527 Load config homebridgepin: from db.
18:33:53:527 Load config homebridgeupdate: false from db.
18:33:53:527 Load config homebridgeupdateversion: from db.
18:33:53:527 Load config homebridgeversion: from db.
18:33:53:527 Load config ipaddress: 192.168.0.200 from db.
18:33:53:527 Load config lightlastseeninterval: 60 from db.
18:33:53:527 Load config linkbutton: false from db.
18:33:53:527 Load config localtime: 2021-12-26T18:29:19 from db.
18:33:53:527 Load config mac: 38:60:77:7c:53:18 from db.
18:33:53:527 Load config modelid: deCONZ from db.
18:33:53:527 Load config name: Phoscon-GW from db.
18:33:53:527 Load config netmask: 255.0.0.0 from db.
18:33:53:527 Load config networkopenduration: 180 from db.
18:33:53:527 Load config otauactive: false from db.
18:33:53:527 Load config otaustate: off from db.
18:33:53:527 Load config panid: 0 from db.
18:33:53:527 Load config permitjoin: 0 from db.
18:33:53:527 Load config permitjoinfull: 0 from db.
18:33:53:527 Load config port: 80 from db.
18:33:53:527 Load config portalservices: false from db.
18:33:53:527 Load config proxyaddress: none from db.
18:33:53:527 Load config proxyport: 0 from db.
18:33:53:527 Load config rfconnect: 1 from db.
18:33:53:527 Load config rfconnected: false from db.
18:33:53:528 Load config rgbwdisplay: 1 from db.
18:33:53:528 Load config runmode: systemd/headless from db.
18:33:53:528 Load config starterkitid: from db.
18:33:53:528 Load config swcommit: 8204f08632d42e22905a77e111acc552b7770f25 from db.
18:33:53:528 Load config swupdatestate: noupdates from db.
18:33:53:528 Load config swversion: 2.13.04 from db.
18:33:53:528 Load config system: linux-gw from db.
18:33:53:528 Load config timeformat: 12h from db.
18:33:53:528 Load config timezone: Etc/GMT from db.
18:33:53:528 Load config updatechannel: stable from db.
18:33:53:528 Load config uuid: b82e422b-ecae-4d99-b0be-841458a3b18a from db.
18:33:53:528 Load config websocketnotifyall: true from db.
18:33:53:528 Load config websocketport: 8088 from db.
18:33:53:528 Load config wifi: not-available from db.
18:33:53:528 Load config wifibackupname: from db.
18:33:53:528 Load config wifibackuppw: from db.
18:33:53:528 Load config wifibackuppwenc: from db.
18:33:53:528 Load config wifichannel: 1 from db.
18:33:53:528 Load config wificlientname: from db.
18:33:53:528 Load config wificlientpw: from db.
18:33:53:528 Load config wifiip: 192.168.8.1 from db.
18:33:53:528 Load config wifilastupdated: 0 from db.
18:33:53:528 Load config wifimgmt: 0 from db.
18:33:53:528 Load config wifiname: from db.
18:33:53:528 Load config wifipageactive: false from db.
18:33:53:528 Load config wifipw: from db.
18:33:53:528 Load config wifipwenc: from db.
18:33:53:528 Load config wifitype: accesspoint from db.
18:33:53:528 Load config workingname: from db.
18:33:53:528 Load config workingpw: from db.
18:33:53:528 Load config workingpwenc: from db.
18:33:53:528 Load config workingtype: from db.
18:33:53:528 Load config zclvaluemaxage: 0 from db.
18:33:53:528 Load config zigbeechannel: 15 from db.
18:33:53:528 sql exec SELECT key,value FROM userparameter
18:33:53:528 sql exec SELECT * FROM groups
18:33:53:529 Sqlite group: gid = 0xFFF0
18:33:53:529 Sqlite group: name = All
18:33:53:529 Sqlite group: state = normal
18:33:53:529 Sqlite group: hidden = false
18:33:53:529 Sqlite group: type = LightGroup
18:33:53:529 Sqlite group: class = Other
18:33:53:529 DB found group All 0xFFF0
18:33:53:529 sql exec SELECT * FROM resourcelinks
18:33:53:529 sql exec SELECT * FROM scenes
18:33:53:529 sql exec SELECT * FROM rules
18:33:53:529 sql exec SELECT * FROM schedules
18:33:53:529 sql exec SELECT * FROM sensors
18:33:53:530 Sqlite sensors: sid = 1
18:33:53:530 Sqlite sensors: name = Daylight
18:33:53:530 Sqlite sensors: type = Daylight
18:33:53:530 Sqlite sensors: modelid = PHDL00
18:33:53:530 Sqlite sensors: manufacturername = Philips
18:33:53:530 Sqlite sensors: uniqueid = 00:21:2e:ff:ff:08:b8:71-01
18:33:53:530 Sqlite sensors: swversion = 1.0
18:33:53:530 Sqlite sensors: state = {"dark":true,"daylight":false,"lastupdated":"2021-12-26T17:33:04.656","status":220,"sunrise":"2021-12-26T07:50:04","sunset":"2021-12-26T15:47:23"}
18:33:53:530 Sqlite sensors: config = {"configured":true,"lat":"50.828","long":"3.2649","on":true,"sunriseoffset":30,"sunsetoffset":-30}
18:33:53:530 Sqlite sensors: deletedState = normal
18:33:53:530 Sqlite sensors: mode = 1
18:33:53:530 DB found sensor Daylight 1
18:33:53:531 sql exec SELECT * FROM gateways
17:33:53:533 Daylight now: nauticalDusk, status: 220, daylight: 0, dark: 1
17:33:53:533 Started websocket server on 0.0.0.0, port: 8088
17:33:53:534 <?xml version="1.0" encoding="UTF-8" ?>
17:33:53:534 <root xmlns="urn:schemas-upnp-org:device-1-0">
17:33:53:534 <specVersion>
17:33:53:534 <major>1</major>
17:33:53:534 <minor>0</minor>
17:33:53:534 </specVersion>
17:33:53:534 <URLBase>http://192.168.0.200:80/</URLBase>
17:33:53:534 <device>
17:33:53:534 <deviceType>urn:schemas-upnp-org:device:Basic:1</deviceType>
17:33:53:534 <friendlyName>Phoscon-GW (192.168.0.200)</friendlyName>
17:33:53:534 <manufacturer>Royal Philips Electronics</manufacturer>
17:33:53:534 <manufacturerURL>http://www.dresden-elektronik.de</manufacturerURL>
17:33:53:534 <modelDescription>Philips hue compatible Personal Wireless Lighting</modelDescription>
17:33:53:534 <modelName>Philips hue bridge 2015</modelName>
17:33:53:534 <modelNumber>BSB002</modelNumber>
17:33:53:534 <modelURL>http://www.dresden-elektronik.de</modelURL>
17:33:53:534 <serialNumber>00212E08B871</serialNumber>
17:33:53:534 <UDN>uuid:b82e422b-ecae-4d99-b0be-841458a3b18a</UDN>
17:33:53:534 <presentationURL>index.html</presentationURL>
17:33:53:534 <iconList>
17:33:53:534 <icon>
17:33:53:534 <mimetype>image/png</mimetype>
17:33:53:534 <height>48</height>
17:33:53:534 <width>48</width>
17:33:53:534 <depth>24</depth>
17:33:53:534 <url>hue_logo_0.png</url>
17:33:53:534 </icon>
17:33:53:534 </iconList>
17:33:53:534 </device>
17:33:53:534 </root>
17:33:53:535 <modelNumber>BSB002</modelNumber>
17:33:53:535 <modelURL>http://www.dresden-elektronik.de</modelURL>
17:33:53:535 <serialNumber>00212E08B871</serialNumber>
17:33:53:535 <UDN>uuid:b82e422b-ecae-4d99-b0be-841458a3b18a</UDN>
17:33:53:535 <presentationURL>index.html</presentationURL>
17:33:53:535 <iconList>
17:33:53:535 <icon>
17:33:53:535 <mimetype>image/png</mimetype>
17:33:53:535 <height>48</height>
17:33:53:535 <width>48</width>
17:33:53:535 <depth>24</depth>
17:33:53:535 <url>hue_logo_0.png</url>
17:33:53:535 </icon>
17:33:53:535 </iconList>
17:33:53:535 </device>
17:33:53:535 </root>
17:33:53:536 [INFO] - Found file containing button maps. Parsing data...
17:33:53:548 [INFO] - Button maps loaded.
17:33:53:549 found node plugin: libde_rest_plugin.so - REST API Plugin
17:33:53:550 found node plugin: libde_signal_plugin.so - Signal Monitor Plugin
17:33:53:551 Otau image path does not exist: /home/openhabian/otau
17:33:53:561 found node plugin: libstd_otau_plugin.so - STD OTAU Plugin
17:33:53:563 Node: id: 1, 00:21:2e:ff:ff:08:b8:71 (0x00212EFFFF08B871) scene: 0.000000, 0.000000
17:33:53:566 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 3, node: 0x0000
17:33:53:570 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 7, node: 0x0000
17:33:53:570 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 5, node: 0x0000
17:33:53:571 sql exec SELECT * FROM nodes WHERE mac='00:21:2e:ff:ff:08:b8:71-01' COLLATE NOCASE AND state != 'deleted'
17:33:53:571 sql exec SELECT * FROM nodes WHERE mac='0x00212effff08b871' COLLATE NOCASE AND state != 'deleted'
17:33:53:572 DB pushZdpDescriptorDb()
17:33:53:572 DB save zll database items 0x00000880
17:33:53:572 DB sql exec REPLACE INTO sensors (sid, name, type, modelid, manufacturername, uniqueid, swversion, state, config, fingerprint, deletedState, mode, lastseen, lastannounced) VALUES ('1', 'Daylight', 'Daylight', 'PHDL00', 'Philips', '00:21:2e:ff:ff:08:b8:71-01', '1.0', '{"dark":true,"daylight":false,"lastupdated":"2021-12-26T17:33:53.533","status":220,"sunrise":"2021-12-26T07:50:04","sunset":"2021-12-26T15:47:23"}', '{"configured":true,"lat":"50.828","long":"3.2649","on":true,"sunriseoffset":30,"sunsetoffset":-30}', '', 'normal', '1', '', '')
17:33:53:573 DB sql exec UPDATE devices SET nwk = 0 WHERE mac = '00:21:2e:ff:ff:08:b8:71';INSERT INTO devices (mac,nwk,timestamp) SELECT '00:21:2e:ff:ff:08:b8:71', 0, strftime('%s','now') WHERE (SELECT changes() = 0);
17:33:53:577 DB saved in 5 ms
17:33:53:577 sql exec SELECT * FROM nodes WHERE mac='00:21:2e:ff:ff:08:b8:71-01' COLLATE NOCASE AND state != 'deleted'
17:33:53:577 sql exec SELECT * FROM nodes WHERE mac='0x00212effff08b871' COLLATE NOCASE AND state != 'deleted'
17:33:53:578 DB pushZdpDescriptorDb()
17:33:53:578 sql exec SELECT * FROM nodes WHERE mac='00:21:2e:ff:ff:08:b8:71-01' COLLATE NOCASE AND state != 'deleted'
17:33:53:578 sql exec SELECT * FROM nodes WHERE mac='0x00212effff08b871' COLLATE NOCASE AND state != 'deleted'
17:33:53:624 dlg action: Read binding table
17:33:54:485 UPNP socket not bound, state: 0
17:33:54:498 Skip idle timer callback, too early: elapsed 949 msec
17:33:54:670 COM: /dev/ttyUSB0 : RFXtrx433 (0x0403/0x6001)
17:33:54:670 COM: /dev/ttyAMA0 : (0x0000/0x0000)
17:33:54:671 dev /dev/ttyAMA0 (/dev/ttyAMA0)
17:33:54:671 COM: /dev/ttyS0 : (0x0000/0x0000)
17:33:54:675 auto connect com /dev/ttyAMA0
17:33:56:250 Serial com connected
17:33:56:263 Master: read param with arg 0x18
17:33:56:263 Master: read param with arg 0x13
17:33:56:327 Device firmware version 0x26690700 RaspBee II
17:33:56:337 unlocked max nodes: 512
17:33:56:337 has feature: max nodes (0x11), status: 0x00
17:33:56:344 has feature: std security (0x01), status: 0x04
17:33:56:352 has feature: link security (0x02), status: 0x00
17:33:56:360 has feature: high security (0x03), status: 0x04
17:33:56:368 has feature: ethernet (0x04), status: 0x04
17:33:56:375 has feature: mass storage device (MSD) (0x05), status: 0x04
17:33:56:383 has feature: device firmware upgrade (DFU) (0x06), status: 0x04
17:33:56:391 has feature: ZigBee Light Link (ZLL) (0x07), status: 0x04
17:33:56:398 has feature: interpan (0x08), status: 0x04
17:33:56:398 Skip idle timer callback, too early: elapsed 949 msec
17:33:56:406 has feature: button 1 (0x09), status: 0x04
17:33:56:414 has feature: button 1 (0x0A), status: 0x04
17:33:56:421 has feature: LED 1 (0x0B), status: 0x00
17:33:56:429 has feature: LED 2 (0x0C), status: 0x00
17:33:56:436 has feature: LED 3 (0x0D), status: 0x04
17:33:56:444 has feature: LED 4 (0x0E), status: 0x04
17:33:56:452 has feature: LED 5 (0x0F), status: 0x04
17:33:56:460 has feature: LED RGB (0x10), status: 0x04
17:33:56:467 has feature: max nodes (0x11), status: 0x04
17:33:56:475 Device protocol version: 0x010E
17:33:56:494 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 2, node: 0x0000
17:33:56:539 Master: read param with arg 0x19
17:33:56:579 Current channel 15
17:33:56:610 CTRL ANT_CTRL 0x03
17:33:56:618 CTRL read param resp id: 0x28, status: 0x04
17:33:56:647 APS-DATA.request id: 4, addrmode: 0x03, addr: 0x00212effff08b871, profile: 0x0000, cluster: 0x0031, ep: 0x00 -> 0x00 queue: 0 len: 2 tx.options 0x00
17:33:56:647 asdu (length: 2): 0000
17:33:56:690 Device protocol version: 0x010E
17:33:56:698 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 1, node: 0x0000
17:33:56:707 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 2, node: 0x0000
17:33:56:752 Master: read param with arg 0x19
17:33:56:824 CTRL ANT_CTRL 0x03
17:33:56:831 CTRL read param resp id: 0x28, status: 0x04
17:33:56:958 APS-DATA.confirm id: 4, status: 0x00 SUCCESS
17:33:56:958 APS-DATA.confirm request id: 4 -> confirmed, timeout 0
17:33:56:975 APS-DATA.indication srcAddr: 0x0000, srcEp: 0x00 dstAddrMode: 2, profile: 0x0000, cluster: 0x8031, lqi: 221, rssi: 30
17:33:56:975 asdu: 0000000000
17:33:56:975 APS-DATA.indication request id: 4 -> finished
17:33:56:975 APS-DATA.request id: 4 erase from queue
17:33:56:975 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 8, node: 0x0000
17:33:57:047 APS-DATA.request id: 7, addrmode: 0x02, addr: 0x0000, profile: 0x0000, cluster: 0x0004, ep: 0x00 -> 0x00 queue: 0 len: 4 tx.options 0x00
17:33:57:047 asdu (length: 4): 020000f2
17:33:57:047 Delay APS request id: 7 delayed, 20 ms till send
17:33:57:100 Delay APS request id: 7 delayed, 20 ms till send
17:33:57:152 Delay APS request id: 7 delayed, 20 ms till send
17:33:57:205 Delay APS request id: 7 delayed, 20 ms till send
17:33:57:257 Delay APS request id: 7 delayed, 20 ms till send
17:33:57:336 APS-DATA.confirm id: 7, status: 0x00 SUCCESS
17:33:57:336 APS-DATA.confirm request id: 7 -> confirmed, timeout 0
17:33:57:356 APS-DATA.indication srcAddr: 0x0000, srcEp: 0x00 dstAddrMode: 2, profile: 0x0000, cluster: 0x8004, lqi: 221, rssi: 30
17:33:57:356 asdu: 020000000af2e0a164000100012100
17:33:57:356 APS-DATA.indication request id: 7 -> finished
17:33:57:356 APS-DATA.request id: 7 erase from queue
17:33:57:356 sql exec SELECT * FROM nodes WHERE mac='00:21:2e:ff:ff:08:b8:71-01' COLLATE NOCASE AND state != 'deleted'
17:33:57:357 sql exec SELECT * FROM nodes WHERE mac='0x00212effff08b871' COLLATE NOCASE AND state != 'deleted'
17:33:57:358 DB pushZdpDescriptorDb()
17:33:57:367 APS-DATA.request id: 9, addrmode: 0x02, addr: 0x0000, profile: 0x0000, cluster: 0x0004, ep: 0x00 -> 0x00 queue: 0 len: 4 tx.options 0x00
17:33:57:367 asdu (length: 4): 03000001
17:33:57:367 Delay APS request id: 9 delayed, 20 ms till send
17:33:57:385 Delay APS request id: 9 delayed, 20 ms till send
17:33:57:434 Delay APS request id: 9 delayed, 20 ms till send
17:33:57:482 Delay APS request id: 9 delayed, 20 ms till send
17:33:57:530 Delay APS request id: 9 delayed, 20 ms till send
17:33:57:578 Delay APS request id: 9 delayed, 20 ms till send
17:33:57:626 Delay APS request id: 9 delayed, 20 ms till send
17:33:57:674 Delay APS request id: 9 delayed, 20 ms till send
17:33:57:721 Delay APS request id: 9 delayed, 20 ms till send
17:33:57:796 APS-DATA.confirm id: 9, status: 0x00 SUCCESS
17:33:57:796 APS-DATA.confirm request id: 9 -> confirmed, timeout 0
17:33:57:819 APS-DATA.indication srcAddr: 0x0000, srcEp: 0x00 dstAddrMode: 2, profile: 0x0000, cluster: 0x8004, lqi: 221, rssi: 30
17:33:57:819 asdu: 030000001a01040105000105000006000a0019000105040100200000050205
17:33:57:819 APS-DATA.indication request id: 9 -> finished
17:33:57:819 APS-DATA.request id: 9 erase from queue
17:33:57:820 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 5, node: 0x0000
17:33:57:820 sql exec SELECT * FROM nodes WHERE mac='00:21:2e:ff:ff:08:b8:71-01' COLLATE NOCASE AND state != 'deleted'
17:33:57:820 sql exec SELECT * FROM nodes WHERE mac='0x00212effff08b871' COLLATE NOCASE AND state != 'deleted'
17:33:57:821 DB pushZdpDescriptorDb()
17:33:57:927 APS-DATA.request id: 11, addrmode: 0x02, addr: 0x0000, profile: 0x0000, cluster: 0x0002, ep: 0x00 -> 0x00 queue: 0 len: 3 tx.options 0x00
17:33:57:927 asdu (length: 3): 040000
17:33:57:927 Delay APS request id: 11 delayed, 20 ms till send
17:33:57:974 Delay APS request id: 11 delayed, 20 ms till send
17:33:58:023 Delay APS request id: 11 delayed, 20 ms till send
17:33:58:071 Delay APS request id: 11 delayed, 20 ms till send
17:33:58:119 Delay APS request id: 11 delayed, 20 ms till send
17:33:58:167 Delay APS request id: 11 delayed, 20 ms till send
17:33:58:217 Delay APS request id: 11 delayed, 20 ms till send
17:33:58:293 APS-DATA.confirm id: 11, status: 0x00 SUCCESS
17:33:58:293 APS-DATA.confirm request id: 11 -> confirmed, timeout 0
17:33:58:313 APS-DATA.indication srcAddr: 0x0000, srcEp: 0x00 dstAddrMode: 2, profile: 0x0000, cluster: 0x8002, lqi: 221, rssi: 30
17:33:58:313 asdu: 0400000010400f3511472b0040002b0000
17:33:58:313 APS-DATA.indication request id: 11 -> finished
17:33:58:313 APS-DATA.request id: 11 erase from queue
17:33:58:313 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 3, node: 0x0000
17:33:58:313 DB pushZdpDescriptorDb()
17:33:58:313 APS-DATA.request id: 13, addrmode: 0x02, addr: 0x0000, profile: 0x0000, cluster: 0x0005, ep: 0x00 -> 0x00 queue: 0 len: 3 tx.options 0x00
17:33:58:313 asdu (length: 3): e70000
17:33:58:340 APS-DATA.confirm id: 13, status: 0x00 SUCCESS
17:33:58:340 APS-DATA.confirm request id: 13 -> confirmed, timeout 0
17:33:58:357 APS-DATA.indication srcAddr: 0x0000, srcEp: 0x00 dstAddrMode: 2, profile: 0x0000, cluster: 0x8005, lqi: 221, rssi: 30
17:33:58:357 asdu: e70000000201f2
17:33:58:358 APS-DATA.indication request id: 13 -> finished
17:33:58:358 APS-DATA.request id: 13 erase from queue
17:33:58:358 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 7, node: 0x0000
17:33:58:407 APS-DATA.request id: 15, addrmode: 0x02, addr: 0x0000, profile: 0x0000, cluster: 0x0004, ep: 0x00 -> 0x00 queue: 0 len: 4 tx.options 0x00
17:33:58:407 asdu (length: 4): 050000f2
17:33:58:407 Delay APS request id: 15 delayed, 20 ms till send
17:33:58:458 Delay APS request id: 15 delayed, 20 ms till send
17:33:58:511 Delay APS request id: 15 delayed, 20 ms till send
17:33:58:562 Delay APS request id: 15 delayed, 20 ms till send
17:33:58:623 New websocket 192.168.0.123:53884 (state: 3)
17:33:58:624 Delay APS request id: 15 delayed, 20 ms till send
17:33:58:672 Delay APS request id: 15 delayed, 20 ms till send
17:33:58:720 Delay APS request id: 15 delayed, 20 ms till send
17:33:58:786 GW update firmware found: /usr/share/deCONZ/firmware/deCONZ_ConBeeII_0x26660700.bin.GCF
17:33:58:786 GW firmware version: 0x26690700
17:33:58:793 APS-DATA.confirm id: 15, status: 0x00 SUCCESS
17:33:58:793 APS-DATA.confirm request id: 15 -> confirmed, timeout 0
17:33:58:813 APS-DATA.indication srcAddr: 0x0000, srcEp: 0x00 dstAddrMode: 2, profile: 0x0000, cluster: 0x8004, lqi: 221, rssi: 30
17:33:58:813 asdu: 050000000af2e0a164000100012100
17:33:58:813 APS-DATA.indication request id: 15 -> finished
17:33:58:813 APS-DATA.request id: 15 erase from queue
17:33:58:813 sql exec SELECT * FROM nodes WHERE mac='00:21:2e:ff:ff:08:b8:71-01' COLLATE NOCASE AND state != 'deleted'
17:33:58:813 sql exec SELECT * FROM nodes WHERE mac='0x00212effff08b871' COLLATE NOCASE AND state != 'deleted'
17:33:58:814 DB pushZdpDescriptorDb()
17:33:58:887 APS-DATA.request id: 17, addrmode: 0x02, addr: 0x0000, profile: 0x0000, cluster: 0x0004, ep: 0x00 -> 0x00 queue: 0 len: 4 tx.options 0x00
17:33:58:887 asdu (length: 4): 06000001
17:33:58:887 Delay APS request id: 17 delayed, 20 ms till send
17:33:58:934 Delay APS request id: 17 delayed, 20 ms till send
17:33:58:983 Delay APS request id: 17 delayed, 20 ms till send
17:33:59:031 Delay APS request id: 17 delayed, 20 ms till send
17:33:59:050 Announced to internet https://phoscon.de/discover
17:33:59:050 discovery server date: Sun, 26 Dec 2021 17:33:59 GMT
17:33:59:050 local time seems to be ok
17:33:59:079 Delay APS request id: 17 delayed, 20 ms till send
17:33:59:127 Delay APS request id: 17 delayed, 20 ms till send
17:33:59:174 Delay APS request id: 17 delayed, 20 ms till send
17:33:59:254 APS-DATA.confirm id: 17, status: 0x00 SUCCESS
17:33:59:254 APS-DATA.confirm request id: 17 -> confirmed, timeout 0
17:33:59:278 APS-DATA.indication srcAddr: 0x0000, srcEp: 0x00 dstAddrMode: 2, profile: 0x0000, cluster: 0x8004, lqi: 221, rssi: 30
17:33:59:278 asdu: 060000001a01040105000105000006000a0019000105040100200000050205
17:33:59:278 APS-DATA.indication request id: 17 -> finished
17:33:59:278 APS-DATA.request id: 17 erase from queue
17:33:59:279 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 5, node: 0x0000
17:33:59:279 sql exec SELECT * FROM nodes WHERE mac='00:21:2e:ff:ff:08:b8:71-01' COLLATE NOCASE AND state != 'deleted'
17:33:59:280 sql exec SELECT * FROM nodes WHERE mac='0x00212effff08b871' COLLATE NOCASE AND state != 'deleted'
17:33:59:281 DB pushZdpDescriptorDb()
17:33:59:527 APS-DATA.request id: 19, addrmode: 0x03, addr: 0x00212effff08b871, profile: 0x0000, cluster: 0x0031, ep: 0x00 -> 0x00 queue: 0 len: 2 tx.options 0x00
17:33:59:527 asdu (length: 2): 0700
17:33:59:552 APS-DATA.confirm id: 19, status: 0x00 SUCCESS
17:33:59:552 APS-DATA.confirm request id: 19 -> confirmed, timeout 0
17:33:59:569 APS-DATA.indication srcAddr: 0x0000, srcEp: 0x00 dstAddrMode: 2, profile: 0x0000, cluster: 0x8031, lqi: 221, rssi: 30
17:33:59:569 asdu: 0700000000
17:33:59:569 APS-DATA.indication request id: 19 -> finished
17:33:59:569 APS-DATA.request id: 19 erase from queue
17:33:59:569 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 8, node: 0x0000
17:34:01:866 DEV Tick.Init: booted after 8000 seconds
17:34:01:927 APS-DATA.request id: 21, addrmode: 0x03, addr: 0x00212effff08b871, profile: 0x0000, cluster: 0x0031, ep: 0x00 -> 0x00 queue: 0 len: 2 tx.options 0x00
17:34:01:927 asdu (length: 2): 0800
17:34:01:953 APS-DATA.confirm id: 21, status: 0x00 SUCCESS
17:34:01:953 APS-DATA.confirm request id: 21 -> confirmed, timeout 0
17:34:01:969 APS-DATA.indication srcAddr: 0x0000, srcEp: 0x00 dstAddrMode: 2, profile: 0x0000, cluster: 0x8031, lqi: 221, rssi: 30
17:34:01:969 asdu: 0800000000
17:34:01:969 APS-DATA.indication request id: 21 -> finished
17:34:01:969 APS-DATA.request id: 21 erase from queue
17:34:01:969 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 8, node: 0x0000
17:34:02:670 API error 1, /, unauthorized user
17:34:03:867 Daylight now: nauticalDusk, status: 220, daylight: 0, dark: 1
17:34:04:327 APS-DATA.request id: 23, addrmode: 0x03, addr: 0x00212effff08b871, profile: 0x0000, cluster: 0x0031, ep: 0x00 -> 0x00 queue: 0 len: 2 tx.options 0x00
17:34:04:327 asdu (length: 2): 0900
17:34:04:352 APS-DATA.confirm id: 23, status: 0x00 SUCCESS
17:34:04:352 APS-DATA.confirm request id: 23 -> confirmed, timeout 0
17:34:04:369 APS-DATA.indication srcAddr: 0x0000, srcEp: 0x00 dstAddrMode: 2, profile: 0x0000, cluster: 0x8031, lqi: 221, rssi: 30
17:34:04:369 asdu: 0900000000
17:34:04:369 APS-DATA.indication request id: 23 -> finished
17:34:04:369 APS-DATA.request id: 23 erase from queue
17:34:04:369 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 8, node: 0x0000
17:34:06:727 APS-DATA.request id: 25, addrmode: 0x03, addr: 0x00212effff08b871, profile: 0x0000, cluster: 0x0031, ep: 0x00 -> 0x00 queue: 0 len: 2 tx.options 0x00
17:34:06:727 asdu (length: 2): 0a00
17:34:06:752 APS-DATA.confirm id: 25, status: 0x00 SUCCESS
17:34:06:752 APS-DATA.confirm request id: 25 -> confirmed, timeout 0
17:34:06:769 APS-DATA.indication srcAddr: 0x0000, srcEp: 0x00 dstAddrMode: 2, profile: 0x0000, cluster: 0x8031, lqi: 221, rssi: 30
17:34:06:769 asdu: 0a00000000
17:34:06:769 APS-DATA.indication request id: 25 -> finished
17:34:06:769 APS-DATA.request id: 25 erase from queue
17:34:06:769 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 8, node: 0x0000
17:34:08:867 GW firmware version: 0x26690700
17:34:09:127 APS-DATA.request id: 27, addrmode: 0x03, addr: 0x00212effff08b871, profile: 0x0000, cluster: 0x0031, ep: 0x00 -> 0x00 queue: 0 len: 2 tx.options 0x00
17:34:09:127 asdu (length: 2): 0b00
17:34:09:153 APS-DATA.confirm id: 27, status: 0x00 SUCCESS
17:34:09:153 APS-DATA.confirm request id: 27 -> confirmed, timeout 0
17:34:09:170 APS-DATA.indication srcAddr: 0x0000, srcEp: 0x00 dstAddrMode: 2, profile: 0x0000, cluster: 0x8031, lqi: 221, rssi: 30
17:34:09:170 asdu: 0b00000000
17:34:09:170 APS-DATA.indication request id: 27 -> finished
17:34:09:170 APS-DATA.request id: 27 erase from queue
17:34:09:170 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 8, node: 0x0000
17:34:11:528 APS-DATA.request id: 29, addrmode: 0x03, addr: 0x00212effff08b871, profile: 0x0000, cluster: 0x0031, ep: 0x00 -> 0x00 queue: 0 len: 2 tx.options 0x00
17:34:11:528 asdu (length: 2): 0c00
17:34:11:554 APS-DATA.confirm id: 29, status: 0x00 SUCCESS
17:34:11:554 APS-DATA.confirm request id: 29 -> confirmed, timeout 0
17:34:11:571 APS-DATA.indication srcAddr: 0x0000, srcEp: 0x00 dstAddrMode: 2, profile: 0x0000, cluster: 0x8031, lqi: 221, rssi: 30
17:34:11:571 asdu: 0c00000000
17:34:11:571 APS-DATA.indication request id: 29 -> finished
17:34:11:571 APS-DATA.request id: 29 erase from queue
17:34:11:571 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 8, node: 0x0000
17:34:12:674 API error 1, /, unauthorized user
17:34:13:867 Daylight now: nauticalDusk, status: 220, daylight: 0, dark: 1
17:34:13:927 APS-DATA.request id: 31, addrmode: 0x03, addr: 0x00212effff08b871, profile: 0x0000, cluster: 0x0031, ep: 0x00 -> 0x00 queue: 0 len: 2 tx.options 0x00
17:34:13:927 asdu (length: 2): 0d00
17:34:13:952 APS-DATA.confirm id: 31, status: 0x00 SUCCESS
17:34:13:952 APS-DATA.confirm request id: 31 -> confirmed, timeout 0
17:34:13:969 APS-DATA.indication srcAddr: 0x0000, srcEp: 0x00 dstAddrMode: 2, profile: 0x0000, cluster: 0x8031, lqi: 221, rssi: 30
17:34:13:969 asdu: 0d00000000
17:34:13:969 APS-DATA.indication request id: 31 -> finished
17:34:13:969 APS-DATA.request id: 31 erase from queue
17:34:13:969 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 8, node: 0x0000
17:34:15:368 sql exec SELECT conf FROM zbconf ORDER BY rowid desc limit 1
17:34:15:368 Idle timer triggered
17:34:16:327 APS-DATA.request id: 33, addrmode: 0x03, addr: 0x00212effff08b871, profile: 0x0000, cluster: 0x0031, ep: 0x00 -> 0x00 queue: 0 len: 2 tx.options 0x00
17:34:16:327 asdu (length: 2): 0e00
17:34:16:353 APS-DATA.confirm id: 33, status: 0x00 SUCCESS
17:34:16:353 APS-DATA.confirm request id: 33 -> confirmed, timeout 0
17:34:16:370 APS-DATA.indication srcAddr: 0x0000, srcEp: 0x00 dstAddrMode: 2, profile: 0x0000, cluster: 0x8031, lqi: 221, rssi: 30
