I have problems after updating from the RPi3b+ to the RPi4. I am using the “Official” Phoscon Image with stable deCONZ version and desktop based on Raspberry Pi OS - Raspbian GNU/Linux 11 (bullseye).
RaspBee II - Firmware 26780700, Gateway 2.28.1.
Pi OS is running from an SSD connected through USB. When I switch the RaspBee II and SSD from the RPi3b+ to the RPi4, Pi OS boots normally. I can log in to Phoscon or through VNC to the desktop and check the deCONZ app. The issue is that on the RPi4, most of the nodes are not connected. I can see only 4 or 5 links instead of the 50+ I had on the RPi3b+.
Any idea where the problem could be or what to check? Any advice is much appreciated.
Screen from RPi3 where nodes are normaly connected and working
Hello, the migration to Rpi4 involved reconnecting the SSD, which means the entire Pi OS and its settings were not changed. I can see all nodes, but only a few of them are linked/working. Should I try the backup/restore in Phoscon?
And it’s working ?
Because there is a setting to show or not “link” according to level, perhpas it’s just a “lower connection” issue (as device name are not yet grayed, so not yet off line)?
Ths a lot :).
I don’t think it’s from arm_64bit or arm_boost but for otg_mode
otg_mode (Raspberry Pi 4 only)
USB On-The-Go (often abbreviated to OTG) is a feature that allows supporting USB devices with an appropriate OTG cable to configure themselves as USB hosts. On older Raspberry Pis, a single USB 2 controller was used in both USB host and device mode.
Raspberry Pi 4B and Raspberry Pi 400 (not CM4 or CM4IO) add a high performance USB 3 controller, attached via PCIe, to drive the main USB ports. The legacy USB 2 controller is still available on the USB-C power connector for use as a device (otg_mode=0, the default).
otg_mode=1 requests that a more capable XHCI USB 2 controller is used as another host controller on that USB-C connector.
Note Because CM4 and CM4IO don’t include the external USB 3 controller, Raspberry Pi OS images set otg_mode=1 on CM4 for better performance.
