Hi everyone, I’m noticing a problem, I’ll start by saying that it worked fine before. suddenly my rapbee2 stopped working, gcfflasher doesn’t find any device. How can I check if the RPI side is seen correctly?
Hello , the device have 2 LED nope ?
But I don’t remmeber the meaning …
I don’t see any Led. How can I see if the hardware is seen by the raspi?
Can you please check that the serial port configuration is still valid, sometimes it gets scrambled after OS updates.
https://phoscon.de/en/raspbee2/install#raspbian
Here it’s Step 1)
sudo raspi-config ....
the serial port is correct
Hmm strange, can you try following command:
GCFFlasher_internal -c -d /dev/serial0
If the connection works this should print a packet like packet: 8 bytes, 0702000800A20000
every 10 seconds.
this the result
Looks good this is the normal communication.
I think found a bug in GCFFlasher which doesn’t list the RaspBee will be fixed asap.
Specifying the path on the commandline however works anyway (/dev/serial0
or /dev/ttyS0
