I was having trouble with my Raspbee II after moving it to a Pi4, which I think was really down to me using a USB3 SSD with it. Anyway, I thought I’d updated the firmware as an attempt to fix it. It’s in use in Home Assistant.
First I used Raspian to update the firmware but that didn’t work, I got the message repeatedly:
There was no progress bar.
So I used the Phoscon image and things appeared to be more positive, i.e. there was a progress bar, but it ended with a failure message. So I ran it again with verbose logging, and it does look positive to me until the very end.
retry, failed
When I booted again into Home Assistant, all my devices are unavailable.
I’ve cut out the repetitive parts of the log. Any help appreciated!
pi@phoscon:/tmp $ sudo systemctl stop deconz
pi@phoscon:/tmp $ wget https://deconz.dresden-elektronik.de/deconz-firmware/deCONZ_RaspBeeII_0x26780700.bin.GCF
--2022-08-19 04:50:48-- https://deconz.dresden-elektronik.de/deconz-firmware/deCONZ_RaspBeeII_0x26780700.bin.GCF
Resolving deconz.dresden-elektronik.de (deconz.dresden-elektronik.de)... 144.76.96.194
Connecting to deconz.dresden-elektronik.de (deconz.dresden-elektronik.de)|144.76.96.194|:443...
connected.
HTTP request sent, awaiting response... 200 OK
Length: 163244 (159K) [application/octet-stream]
Saving to: ‘deCONZ_RaspBeeII_0x26780700.bin.GCF’
deCONZ_RaspBeeII_0x26780700.bin.GCF 100%[==========================================================================>] 159.42K 455KB/s in 0.4s
2022-08-19 04:50:49 (455 KB/s) - ‘deCONZ_RaspBeeII_0x26780700.bin.GCF’ saved [163244/163244]
pi@phoscon:/tmp $ sudo systemctl stop ModemManager
Failed to stop ModemManager.service: Unit ModemManager.service not loaded.
pi@phoscon:/tmp $ sudo GCFFlasher_internal -t 60 -f deCONZ_RaspBeeII_0x26780700.bin.GCF -x 3
04:51:12:575 using firmware file: deCONZ_RaspBeeII_0x26780700.bin.GCF
04:51:12:660 ls dev: /dev/ttyAMA0 (0x0000/0x0000) sn:
04:51:12:660 check symlink /dev/ttyAMA0 (/dev/ttyS0)
04:51:12:660 ls dev: /dev/ttyS0 (0x0000/0x0000) sn:
04:51:12:660 check symlink /dev/ttyS0 (/dev/ttyS0)
04:51:12:660 dev /dev/ttyS0 (/dev/ttyS0)
04:51:12:662 query bootloader v1 ID after 0 ms
04:51:14:164 query bootloader v1 ID after 1501 ms
04:51:14:664 query deCONZ firmware version
04:51:14:672 SLIP RX frame length: 9
deCONZ firmware version 26780700
04:51:14:672 send watchdog reset 2 seconds
04:51:14:672 TX c00b02000c0005002602000000baffc0
04:51:14:812 uart reset failed, try RaspBee reset
action: reset device RaspBee
wiringPi 2.52 initialized
04:51:15:023 query bootloader v1 ID after 0 ms
04:51:15:511 RX 14 bytes ASCII ??? after 488 ms
04:51:15:511 RX c081820300030085a1628fe0fcc0 after 488 ms
04:51:15:511 SLIP RX frame length: 10
04:51:15:511 check magic: 0x81 cmd: 0x82 after 488 ms
Bootloader version 0x00030003, app crc: 0x8F62A185
04:51:15:512 GCF_ResetDeviceDone
04:51:15:513 bootloader v3 update firmware request size: 163230, addr: 0x00005000, type: 31, crc-32: 0xAAAAAAAA
04:51:15:514 TX c081039e7d0200005000001faaaaaaaa48fbc0
04:51:15:521 SLIP RX frame length: 3
flashing 163230 bytes: |=04:51:15:526 SLIP RX frame length: 8
04:51:15:526 updateFirmwareV3DataRsp()
04:51:15:526 bootloader v3 data request, offset: 0, length: 256
04:51:15:526 bootloader v3 send data response, status: 0, offset: 0, length: 256
04:51:15:527 TX c08184000000000000013087c6882eac14f5e1471e1c5f9938057b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af3b66c0
04:51:15:606 SLIP RX frame length: 8
04:52:06:929 updateFirmwareV3DataRsp()
04:52:06:929 bootloader v3 data request, offset: 163072, length: 158
04:52:06:929 bootloader v3 send data response, status: 0, offset: 163072, length: 158
04:52:06:930 TX c0818400007d02009e007cdc9f7ebb3d63780e92215ad3d71cbae1cbdbdd4d695c98449099d07f513e094826dcf9ace5459007a91c5c9997a1eee63f3fc6d2ba364c507b64084902b644e5990ba33fb4dbdd7a61ddd8a0e6820912f8adef00d1bfb43f353cae1760e2e7c6bf21bd39dbddd21de96be6c5e83139ba4d0d2d288efdf5f0a7902e720cb9b7f275da4e0cc3cc86c4a57453338a9ab65b8141a2dbddc3025f73d3a20100ffc5022ca6acc0
04:52:06:930 bootloader v3 finished all data
|04:52:07:981 verify application is running
04:52:07:982 query deCONZ firmware version
04:52:09:984 failed to query application
04:52:09:985 retry, elapsed 57 seconds
04:52:10:080 parse commands: /usr/bin/GCFFlasher_internal.bin -t 60 -f deCONZ_RaspBeeII_0x26780700.bin.GCF -x 3
04:52:10:081 using firmware file: deCONZ_RaspBeeII_0x26780700.bin.GCF
04:52:10:175 ls dev: /dev/ttyAMA0 (0x0000/0x0000) sn:
04:52:10:175 check symlink /dev/ttyAMA0 (/dev/ttyS0)
04:52:10:175 ls dev: /dev/ttyS0 (0x0000/0x0000) sn:
04:52:10:175 check symlink /dev/ttyS0 (/dev/ttyS0)
04:52:10:176 dev /dev/ttyS0 (/dev/ttyS0)
04:52:10:177 query bootloader v1 ID after 0 ms
04:52:11:679 query bootloader v1 ID after 1501 ms
04:52:12:179 query deCONZ firmware version
04:52:12:186 SLIP RX frame length: 9
04:52:12:186 send watchdog reset 2 seconds
04:52:12:186 TX c00b03000c0005002602000000b9ffc0
04:52:12:230 set watchdog ttl status: 0x00
04:52:12:230 wait reboot: 2100 ms
04:52:14:331 query bootloader v1 ID after 0 ms
04:52:15:122 RX 14 bytes ASCII ??? after 791 ms
04:52:15:122 RX c081820300030085a1628fe0fcc0 after 791 ms
04:52:15:122 SLIP RX frame length: 10
04:52:15:122 check magic: 0x81 cmd: 0x82 after 791 ms
04:52:15:124 GCF_ResetDeviceDone
04:52:15:125 bootloader v3 update firmware request size: 163230, addr: 0x00005000, type: 31, crc-32: 0xAAAAAAAA
04:52:15:125 TX c081039e7d0200005000001faaaaaaaa48fbc0
04:52:15:132 SLIP RX frame length: 3
flashing 163230 bytes: |=04:52:15:137 SLIP RX frame length: 8
04:52:15:137 updateFirmwareV3DataRsp()
04:52:15:138 bootloader v3 data request, offset: 0, length: 256
04:52:15:138 bootloader v3 send data response, status: 0, offset: 0, length: 256
04:52:15:138 TX c08184000000000000013087c6882eac14f5e1471e1c5f9938057b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af3b66c0
04:52:15:218 SLIP RX frame length: 8
04:53:06:493 updateFirmwareV3DataRsp()
04:53:06:493 bootloader v3 data request, offset: 163072, length: 158
04:53:06:493 bootloader v3 send data response, status: 0, offset: 163072, length: 158
04:53:06:493 TX c0818400007d02009e007cdc9f7ebb3d63780e92215ad3d71cbae1cbdbdd4d695c98449099d07f513e094826dcf9ace5459007a91c5c9997a1eee63f3fc6d2ba364c507b64084902b644e5990ba33fb4dbdd7a61ddd8a0e6820912f8adef00d1bfb43f353cae1760e2e7c6bf21bd39dbddd21de96be6c5e83139ba4d0d2d288efdf5f0a7902e720cb9b7f275da4e0cc3cc86c4a57453338a9ab65b8141a2dbddc3025f73d3a20100ffc5022ca6acc0
04:53:06:493 bootloader v3 finished all data
|04:53:07:544 verify application is running
04:53:07:544 query deCONZ firmware version
04:53:09:547 failed to query application
retry, failed
pi@phoscon:/tmp $ GCFFlasher_internal -l
/dev/ttyS0 | 0x0000 | 0x0000 | | RaspBee
