Raspbee fail to connect on my PI4
I’ve tied 2 times with 2 different (RASPBEE) boards initially on my CM4 using the official CM4 IO board and then I’ve tied on my Rapsberry pi 4, but i get the same error, the addon didnt connect to the device. I’ve checked many times the configuration but i cant’ find a solution.
What can I do to solve this problem?
Regards
Antonio
Moved this from device requests to general support.
I am not sure what you mean by addon. I assume it’s the home assistant one.
Can you please be more clear and also provide some logs on APS, aps2, error, error 2, info and info2.
