Describe the bug
- Cannot find devices to pair when using in homeassistant.
- It looks like it’s a raspbee and not raspbee 2 in GCFflasher -1
- I cannot firmware update it manually, retry failed
Followed the manually update guide on both regular rasbian image and the premade with deconz installed
Expected behavior
Not updating firmare, retry failed.
pi@phoscon:~ $ sudo GCFFlasher_internal -d /dev/ttyS0 -t 120 -f deCONZ_RaspBeeII_0x26710700.bin.GCF
Reboot device /dev/ttyS0 (RaspBee)
action: reset device RaspBee
wiringPi 2.52 initialized
Bootloader version 0x00030003, app crc: 0x93C2CD88
flashing 164180 bytes: |=Reboot device /dev/ttyS0 (RaspBee)
flashing 164180 bytes: |=retry, failed
Screenshots
Environment
2.12.01 / 14.6.2021
Raspberry pi3
Raspbee2
deCONZ Logs
pi@phoscon:~ $ GCFFlasher_internal -l
/dev/ttyS0 | 0x0000 | 0x0000 | | RaspBee
pi@phoscon:~ $ sudo GCFFlasher_internal -d /dev/ttyS0 -t 120 -f deCONZ_RaspBeeII_0x26710700.bin.GCF -x 3
09:52:55:795 using firmware file: deCONZ_RaspBeeII_0x26710700.bin.GCF
09:52:55:946 ls dev: /dev/ttyAMA0 (0x0000/0x0000) sn:
09:52:55:946 ls dev: /dev/ttyS0 (0x0000/0x0000) sn:
09:52:55:946 dev /dev/ttyS0
09:52:55:949 query bootloader v1 ID after 0 ms
09:52:57:452 query bootloader v1 ID after 1502 ms
09:52:57:953 query deCONZ firmware version
09:53:00:101 uart reset failed, try RaspBee reset
09:53:00:306 query bootloader v1 ID after 1 ms
09:53:00:794 RX 14 bytes ASCII ▒▒ after 489 ms
09:53:00:794 RX c081820300030088cdc2934dfcc0 after 489 ms
09:53:00:794 SLIP RX frame length: 10
09:53:00:794 check magic: 0x81 cmd: 0x82 after 489 ms
09:53:00:796 GCF_ResetDeviceDone
09:53:00:797 bootloader v3 update firmware request size: 164180, addr: 0x00005000, type: 31, crc-32: 0xAAAAAAAA
09:53:00:797 TX c0810354810200005000001faaaaaaaa8efbc0
09:53:00:804 SLIP RX frame length: 3
flashing 164180 bytes: |=09:53:00:809 SLIP RX frame length: 8
09:53:00:809 updateFirmwareV3DataRsp()
09:53:00:809 bootloader v3 data request, offset: 0, length: 256
09:53:00:809 bootloader v3 send data response, status: 0, offset: 0, length: 256
09:53:00:810 TX c08184000000000000017e1b800892caa2413fe59bd4827360627b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af1065c0
09:53:00:889 SLIP RX frame length: 8
09:53:00:889 updateFirmwareV3DataRsp()
09:53:00:889 bootloader v3 data request, offset: 256, length: 256
09:53:00:889 bootloader v3 send data response, status: 0, offset: 256, length: 256
09:53:00:890 TX c08184000001000000017b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6aff962c0
09:53:20:891 retry, elapsed 25 seconds
09:53:20:997 parse commands: /usr/bin/GCFFlasher_internal.bin -d /dev/ttyS0 -t 120 -f deCONZ_RaspBeeII_0x26710700.bin.GCF -x 3
09:53:20:998 using firmware file: deCONZ_RaspBeeII_0x26710700.bin.GCF
09:53:21:131 ls dev: /dev/ttyAMA0 (0x0000/0x0000) sn:
09:53:21:131 ls dev: /dev/ttyS0 (0x0000/0x0000) sn:
09:53:21:131 dev /dev/ttyS0
09:53:21:133 query bootloader v1 ID after 0 ms
09:53:22:635 query bootloader v1 ID after 1502 ms
09:53:23:136 query deCONZ firmware version
09:53:25:140 uart reset failed, try RaspBee reset
09:53:25:342 query bootloader v1 ID after 1 ms
09:53:25:830 RX 14 bytes ASCII ▒▒ after 489 ms
09:53:25:830 RX c081820300030088cdc2934dfcc0 after 489 ms
09:53:25:830 SLIP RX frame length: 10
09:53:25:830 check magic: 0x81 cmd: 0x82 after 489 ms
09:53:25:832 GCF_ResetDeviceDone
09:53:25:834 bootloader v3 update firmware request size: 164180, addr: 0x00005000, type: 31, crc-32: 0xAAAAAAAA
09:53:25:835 TX c0810354810200005000001faaaaaaaa8efbc0
09:53:25:843 SLIP RX frame length: 3
flashing 164180 bytes: |=09:53:25:848 SLIP RX frame length: 8
09:53:25:849 updateFirmwareV3DataRsp()
09:53:25:849 bootloader v3 data request, offset: 0, length: 256
09:53:25:850 bootloader v3 send data response, status: 0, offset: 0, length: 256
09:53:25:851 TX c08184000000000000017e1b800892caa2413fe59bd4827360627b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af1065c0
09:53:25:932 SLIP RX frame length: 8
09:53:25:933 updateFirmwareV3DataRsp()
09:53:25:934 bootloader v3 data request, offset: 256, length: 256
09:53:25:935 bootloader v3 send data response, status: 0, offset: 256, length: 256
09:53:25:936 TX c08184000001000000017b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6aff962c0
09:53:26:017 SLIP RX frame length: 8
09:53:26:017 updateFirmwareV3DataRsp()
09:53:26:017 bootloader v3 data request, offset: 512, length: 256
09:53:26:017 bootloader v3 send data response, status: 0, offset: 512, length: 256
09:53:26:017 TX c08184000002000000017b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6aff862c0
09:53:46:034 retry, elapsed 50 seconds
09:53:46:139 parse commands: /usr/bin/GCFFlasher_internal.bin -d /dev/ttyS0 -t 120 -f deCONZ_RaspBeeII_0x26710700.bin.GCF -x 3
09:53:46:139 using firmware file: deCONZ_RaspBeeII_0x26710700.bin.GCF
09:53:46:254 ls dev: /dev/ttyAMA0 (0x0000/0x0000) sn:
09:53:46:254 ls dev: /dev/ttyS0 (0x0000/0x0000) sn:
09:53:46:255 dev /dev/ttyS0
09:53:46:256 query bootloader v1 ID after 0 ms
09:53:47:758 query bootloader v1 ID after 1501 ms
09:53:48:259 query deCONZ firmware version
09:53:50:262 uart reset failed, try RaspBee reset
09:53:50:464 query bootloader v1 ID after 1 ms
09:53:50:953 RX 9 bytes ASCII ▒ after 489 ms
09:53:50:953 RX 188a0001922dd5f3f8 after 489 ms
09:53:51:955 query bootloader v1 ID after 1491 ms
09:53:53:457 query bootloader v3 ID after 2993 ms
09:53:53:457 TX c081027dffc0
09:53:53:958 retry, elapsed 58 seconds
09:53:54:053 parse commands: /usr/bin/GCFFlasher_internal.bin -d /dev/ttyS0 -t 120 -f deCONZ_RaspBeeII_0x26710700.bin.GCF -x 3
09:53:54:054 using firmware file: deCONZ_RaspBeeII_0x26710700.bin.GCF
09:53:54:169 ls dev: /dev/ttyAMA0 (0x0000/0x0000) sn:
09:53:54:169 ls dev: /dev/ttyS0 (0x0000/0x0000) sn:
09:53:54:169 dev /dev/ttyS0
09:53:54:170 query bootloader v1 ID after 0 ms
09:53:55:672 query bootloader v1 ID after 1501 ms
09:53:56:173 query deCONZ firmware version
09:53:58:177 uart reset failed, try RaspBee reset
09:53:58:379 query bootloader v1 ID after 1 ms
09:53:58:867 RX 9 bytes ASCII ▒ after 489 ms
09:53:58:867 RX 188a0001922d95f3f8 after 489 ms
09:53:59:869 query bootloader v1 ID after 1490 ms
09:54:01:371 query bootloader v3 ID after 2992 ms
09:54:01:371 TX c081027dffc0
09:54:01:872 retry, elapsed 66 seconds
09:54:01:968 parse commands: /usr/bin/GCFFlasher_internal.bin -d /dev/ttyS0 -t 120 -f deCONZ_RaspBeeII_0x26710700.bin.GCF -x 3
09:54:01:969 using firmware file: deCONZ_RaspBeeII_0x26710700.bin.GCF
09:54:02:114 ls dev: /dev/ttyAMA0 (0x0000/0x0000) sn:
09:54:02:114 ls dev: /dev/ttyS0 (0x0000/0x0000) sn:
09:54:02:114 dev /dev/ttyS0
09:54:02:116 query bootloader v1 ID after 0 ms
09:54:03:618 query bootloader v1 ID after 1502 ms
09:54:04:119 query deCONZ firmware version
09:54:06:122 uart reset failed, try RaspBee reset
09:54:06:324 query bootloader v1 ID after 1 ms
09:54:06:813 RX 9 bytes ASCII ▒ after 489 ms
09:54:06:813 RX 188a0001922d95f3f8 after 489 ms
09:54:07:814 query bootloader v1 ID after 1490 ms
09:54:09:316 query bootloader v3 ID after 2992 ms
09:54:09:316 TX c081027dffc0
09:54:09:818 retry, elapsed 74 seconds
09:54:09:924 parse commands: /usr/bin/GCFFlasher_internal.bin -d /dev/ttyS0 -t 120 -f deCONZ_RaspBeeII_0x26710700.bin.GCF -x 3
09:54:09:924 using firmware file: deCONZ_RaspBeeII_0x26710700.bin.GCF
09:54:10:047 ls dev: /dev/ttyAMA0 (0x0000/0x0000) sn:
09:54:10:050 ls dev: /dev/ttyS0 (0x0000/0x0000) sn:
09:54:10:051 dev /dev/ttyS0
09:54:10:054 query bootloader v1 ID after 0 ms
09:54:11:558 query bootloader v1 ID after 1503 ms
09:54:12:059 query deCONZ firmware version
09:54:14:062 uart reset failed, try RaspBee reset
09:54:14:264 query bootloader v1 ID after 1 ms
09:54:14:752 RX 9 bytes ASCII ▒ after 489 ms
09:54:14:753 RX 188a0001922dd5f3f8 after 489 ms
09:54:15:755 query bootloader v1 ID after 1491 ms
09:54:17:257 query bootloader v3 ID after 2993 ms
09:54:17:257 TX c081027dffc0
09:54:17:759 retry, elapsed 81 seconds
09:54:17:855 parse commands: /usr/bin/GCFFlasher_internal.bin -d /dev/ttyS0 -t 120 -f deCONZ_RaspBeeII_0x26710700.bin.GCF -x 3
09:54:17:855 using firmware file: deCONZ_RaspBeeII_0x26710700.bin.GCF
09:54:17:973 ls dev: /dev/ttyAMA0 (0x0000/0x0000) sn:
09:54:17:974 ls dev: /dev/ttyS0 (0x0000/0x0000) sn:
09:54:17:975 dev /dev/ttyS0
09:54:17:977 query bootloader v1 ID after 0 ms
09:54:19:480 query bootloader v1 ID after 1502 ms
09:54:19:981 query deCONZ firmware version
09:54:21:984 uart reset failed, try RaspBee reset
09:54:22:186 query bootloader v1 ID after 1 ms
09:54:22:676 RX 9 bytes ASCII X▒ after 491 ms
09:54:22:676 RX 588a0001922dd5f3f8 after 491 ms
09:54:23:678 query bootloader v1 ID after 1492 ms
09:54:25:180 query bootloader v3 ID after 2994 ms
09:54:25:180 TX c081027dffc0
09:54:25:681 retry, elapsed 89 seconds
09:54:25:777 parse commands: /usr/bin/GCFFlasher_internal.bin -d /dev/ttyS0 -t 120 -f deCONZ_RaspBeeII_0x26710700.bin.GCF -x 3
09:54:25:778 using firmware file: deCONZ_RaspBeeII_0x26710700.bin.GCF
09:54:25:893 ls dev: /dev/ttyAMA0 (0x0000/0x0000) sn:
09:54:25:893 ls dev: /dev/ttyS0 (0x0000/0x0000) sn:
09:54:25:893 dev /dev/ttyS0
09:54:25:895 query bootloader v1 ID after 0 ms
09:54:27:397 query bootloader v1 ID after 1501 ms
09:54:27:898 query deCONZ firmware version
09:54:29:901 uart reset failed, try RaspBee reset
09:54:30:103 query bootloader v1 ID after 1 ms
09:54:30:592 RX 9 bytes ASCII X▒ after 489 ms
09:54:30:592 RX 588a0001922d95f3f8 after 489 ms
09:54:31:593 query bootloader v1 ID after 1491 ms
09:54:33:095 query bootloader v3 ID after 2993 ms
09:54:33:095 TX c081027dffc0
09:54:33:597 retry, elapsed 97 seconds
09:54:33:703 parse commands: /usr/bin/GCFFlasher_internal.bin -d /dev/ttyS0 -t 120 -f deCONZ_RaspBeeII_0x26710700.bin.GCF -x 3
09:54:33:703 using firmware file: deCONZ_RaspBeeII_0x26710700.bin.GCF
09:54:33:816 ls dev: /dev/ttyAMA0 (0x0000/0x0000) sn:
09:54:33:817 ls dev: /dev/ttyS0 (0x0000/0x0000) sn:
09:54:33:817 dev /dev/ttyS0
09:54:33:820 query bootloader v1 ID after 0 ms
09:54:35:323 query bootloader v1 ID after 1502 ms
09:54:35:823 query deCONZ firmware version
09:54:37:827 uart reset failed, try RaspBee reset
09:54:38:029 query bootloader v1 ID after 1 ms
09:54:38:517 RX 9 bytes ASCII X▒ after 489 ms
09:54:38:518 RX 588a0001922dd5f3f8 after 489 ms
09:54:39:519 query bootloader v1 ID after 1490 ms
09:54:41:021 query bootloader v3 ID after 2993 ms
09:54:41:021 TX c081027dffc0
09:54:41:523 retry, elapsed 105 seconds
09:54:41:629 parse commands: /usr/bin/GCFFlasher_internal.bin -d /dev/ttyS0 -t 120 -f deCONZ_RaspBeeII_0x26710700.bin.GCF -x 3
09:54:41:629 using firmware file: deCONZ_RaspBeeII_0x26710700.bin.GCF
09:54:41:777 ls dev: /dev/ttyAMA0 (0x0000/0x0000) sn:
09:54:41:777 ls dev: /dev/ttyS0 (0x0000/0x0000) sn:
09:54:41:777 dev /dev/ttyS0
09:54:41:779 query bootloader v1 ID after 0 ms
09:54:43:281 query bootloader v1 ID after 1502 ms
09:54:43:782 query deCONZ firmware version
09:54:45:786 uart reset failed, try RaspBee reset
09:54:45:988 query bootloader v1 ID after 1 ms
09:54:46:476 RX 9 bytes ASCII X▒ after 489 ms
09:54:46:476 RX 588a0001922d95f3f8 after 489 ms
09:54:47:477 query bootloader v1 ID after 1490 ms
09:54:48:980 query bootloader v3 ID after 2992 ms
09:54:48:980 TX c081027dffc0
09:54:48:992 RX 14 bytes ASCII ▒▒ after 3005 ms
09:54:48:992 RX c081820300030088cdc2934dfcc0 after 3005 ms
09:54:48:992 SLIP RX frame length: 10
09:54:48:992 check magic: 0x81 cmd: 0x82 after 3005 ms
09:54:48:994 GCF_ResetDeviceDone
09:54:48:995 bootloader v3 update firmware request size: 164180, addr: 0x00005000, type: 31, crc-32: 0xAAAAAAAA
09:54:48:996 TX c0810354810200005000001faaaaaaaa8efbc0
09:54:49:003 SLIP RX frame length: 3
flashing 164180 bytes: |=09:54:49:008 SLIP RX frame length: 8
09:54:49:009 updateFirmwareV3DataRsp()
09:54:49:009 bootloader v3 data request, offset: 0, length: 256
09:54:49:010 bootloader v3 send data response, status: 0, offset: 0, length: 256
09:54:49:011 TX c08184000000000000017e1b800892caa2413fe59bd4827360627b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af1065c0
09:54:49:091 SLIP RX frame length: 8
09:54:49:092 updateFirmwareV3DataRsp()
09:54:49:093 bootloader v3 data request, offset: 256, length: 256
09:54:49:094 bootloader v3 send data response, status: 0, offset: 256, length: 256
09:54:49:095 TX c08184000001000000017b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6aff962c0
retry, failed
