I’m interested in buying Xiaomi AW300 Outdoor Cameras. They are not listed as compatible with Raspbee 2. Is there chance those camera would work with the Raspbee 2 ? Or is there a workaround ?
Thanks !
Thanks !
I struggle to believe that a zigbee camera exists. It takes more over 10 minutes to upload a 200kb firmware on a zigbee lamp, it can’t work with video streaming.
I see, I didn’t know about that. I’ll take the motion sensor route then. I also see there arent’t any radiator thermostat listed in the compatibility list… As I need some, that’s not a good news.
there are many, I use bosch radiator thermostat 2 but they are a little tricky to set up
Does that mean you can basically make any zigbee devices work with the raspbee 2 ? I’m very interested in the product but I’m worried with compatibility issues.
Yes. As long as they adhere to the zigbee standard. If a device is unsupported, you can request device support on GitHub.
Ok, nice. This way I feel less limited on the zigbee devices I can choose. I will see how things work when I receive everything. I hope phoscon team will be quick to add support for new devices ;).
Thats not the phoscon team, mostly volunteer devs ![]()
With the DDF’s, it has been easier to add devices and no need to wait for new versions to get devices supported.
Well, I’m taking the Raspbee’s route I guess ! I’ll pay a visit to the GitHub once I will have received my hardware. The devs seems to be quite reactive, I hope it will be the same for me as as most of the devices I want aren’t on the supported devices list.
A lot of devices arent on the list. This list is better in the regard: Supported Devices - deCONZ REST-API as its automatically compiled based on the DDF’s in the codebase.
A general note:
It’s very reassuring, plus I see a dedicated team in case of problem. My fears about the compatibility problems have disapeared ;). Also, thanks for the alternative list, it will be a great indicator for the future !
