BB2297
October 20, 2022, 12:54pm
1
I habe a Rasberry4 with a rasbee2 onboard.
I have some Hue outdoor lamps connected and everything works fine.
Now I will pair new Innr E29 lamps and after some tries they paired.
On the next day I could controll the lamps with Phoscon and they were grey as they were offline but they were powered and on.
I erased then in Phoscon and tried to pair them again and this will fail.
I resetted the lamp by six times on/off and they blink whenever I power them on.
Any ideas what I can do?
Thanks in advance
Peter
Mimiix
October 20, 2022, 1:29pm
2
Hi Peter,
Can you please share some logs from deconz while pairing?
You can find out how to make logs in #deconz
BB2297
October 20, 2022, 1:45pm
3
so I should try to pair them again and then send the log of thus timeframe?
How can I stop the logging to make a copy of the logged data?
Currently it‘s running …
Best
Peter
BB2297
October 25, 2022, 8:57am
7
here the log outcome.
Peter
18:31:38:328 wait reconnect 5 seconds
18:31:38:412 COM: /dev/ttyAMA0 : (0x0000/0x0000)
18:31:38:414 COM: /dev/ttyS0 : (0x0000/0x0000)
18:31:38:415 dev /dev/ttyS0 (/dev/ttyS0)
18:31:38:441 APS-DATA.request id: 81, addrmode: 0x03, addr: 0x001788010649f4f0, profile: 0x0000, cluster: 0x0033, ep: 0x00 → 0x00 queue: 0 len: 2 tx.options 0x04
18:31:38:443 asdu (length: 2): ac00
18:31:38:661 API error 950, /sensors, Not connected
18:31:38:823 rule event /config/localtime: 18:31:37.824 → 18:31:38.823 (999ms)
18:31:39:169 API error 950, /sensors, Not connected
18:31:39:323 wait reconnect 4 seconds
18:31:39:823 rule event /config/localtime: 18:31:38.823 → 18:31:39.823 (1000ms)
18:31:40:327 wait reconnect 3 seconds
18:31:40:823 rule event /config/localtime: 18:31:39.823 → 18:31:40.823 (1000ms)
18:31:41:323 Daylight now: sunsetStart, status: 190, daylight: 0, dark: 0
18:31:41:324 APS-DATA.request id: 82, addrmode: 0x03, addr: 0x001788010647f678, profile: 0x0104, cluster: 0x0000, ep: 0x01 → 0x02 queue: 0 len: 7 tx.options 0x00
18:31:41:325 asdu (length: 7): 140b10a3003200
18:31:41:326 failed to reconnect to network try=4
18:31:41:326 wait reconnect 2 seconds
18:31:41:823 rule event /config/localtime: 18:31:40.823 → 18:31:41.823 (1000ms)
18:31:42:323 wait reconnect 1 seconds
18:31:42:365 COM: /dev/ttyAMA0 : (0x0000/0x0000)
18:31:42:366 COM: /dev/ttyS0 : (0x0000/0x0000)
18:31:42:367 dev /dev/ttyS0 (/dev/ttyS0)
18:31:42:368 failed open com status: (-3), path: /dev/ttyS0
18:31:42:378 APS-DATA.request id: 83, addrmode: 0x03, addr: 0x001788010647f678, profile: 0x0000, cluster: 0x0033, ep: 0x00 → 0x00 queue: 0 len: 2 tx.options 0x04
18:31:42:379 asdu (length: 2): ad00
18:31:42:823 rule event /config/localtime: 18:31:41.823 → 18:31:42.823 (1000ms)
18:31:43:323 wait reconnect 5 seconds
18:31:43:365 COM: /dev/ttyAMA0 : (0x0000/0x0000)
18:31:43:366 COM: /dev/ttyS0 : (0x0000/0x0000)
18:31:43:367 dev /dev/ttyS0 (/dev/ttyS0)
18:31:43:824 rule event /config/localtime: 18:31:42.823 → 18:31:43.824 (1001ms)
18:31:44:323 wait reconnect 4 seconds
18:31:44:823 rule event /config/localtime: 18:31:43.824 → 18:31:44.823 (999ms)
18:31:45:323 wait reconnect 3 seconds
18:31:45:824 rule event /config/localtime: 18:31:44.823 → 18:31:45.823 (1000ms)
18:31:46:323 failed to reconnect to network try=5
18:31:46:325 wait reconnect 2 seconds
18:31:46:386 COM: /dev/ttyAMA0 : (0x0000/0x0000)
18:31:46:387 COM: /dev/ttyS0 : (0x0000/0x0000)
18:31:46:388 dev /dev/ttyS0 (/dev/ttyS0)
18:31:46:388 GW firmware update select /dev/ttyS0 device
18:31:46:396 GW update firmware not found:
18:31:46:824 rule event /config/localtime: 18:31:45.823 → 18:31:46.824 (1001ms)
18:31:47:323 wait reconnect 1 seconds
18:31:47:365 COM: /dev/ttyAMA0 : (0x0000/0x0000)
18:31:47:366 COM: /dev/ttyS0 : (0x0000/0x0000)
18:31:47:367 dev /dev/ttyS0 (/dev/ttyS0)
18:31:47:368 failed open com status: (-3), path: /dev/ttyS0
18:31:47:823 rule event /config/localtime: 18:31:46.824 → 18:31:47.823 (999ms)
18:31:48:323 wait reconnect 5 seconds
18:31:48:366 COM: /dev/ttyAMA0 : (0x0000/0x0000)
18:31:48:367 COM: /dev/ttyS0 : (0x0000/0x0000)
18:31:48:368 dev /dev/ttyS0 (/dev/ttyS0)
18:31:48:824 rule event /config/localtime: 18:31:47.823 → 18:31:48.823 (1000ms)
18:31:49:323 wait reconnect 4 seconds
18:31:49:823 rule event /config/localtime: 18:31:48.823 → 18:31:49.823 (1000ms)
18:31:50:324 wait reconnect 3 seconds
Mimiix
October 25, 2022, 9:15am
8
It can’t mount the stick. So it can’t access the network. For some reason it drops out.
How did you install deconz?
BB2297
October 25, 2022, 12:17pm
9
there is no stick. It‘s a rasbee2 onboard on the pins of the rasberry.
I have 7 Hue outdoor lamps attached to deconz and they work without any issue.
Hope this make it clearer.
Peter
Mimiix
October 25, 2022, 1:05pm
10
The reconnect means the Raspbee is not connected.
Can you show some longer logs?
Additionally, what debug flags did you use?
BB2297
October 26, 2022, 4:06pm
11
I used the flags you told me.
I will create a longer log with pairing on Friday or Saturday.
Sorry. Currently I‘m very busy.
Peter
