Rasbee II not working after firmware upgrade
Tried to upgrade the firmware on my rpi4 running phoscon and the update consistently fails with the following.
sudo GCFFlasher_internal -t 60 -f deCONZ_RaspBeeII_0x26720700.bin.GCF
deCONZ firmware version 26720700
Bootloader version 0x00030003, app crc: 0x01BB96DC
flashing 164227 bytes: |================|Reboot device RaspBee (RaspBee)
flashing 164227 bytes: |================|retry, failed
WEb interface shows
2.13.00 / 06/10/2021
Firmware
26720700
Command line shows
/dev/ttyS0 | 0x0000 | 0x0000 | | RaspBee
And nothing works, no devices can be operated :frowning:
Have tried various previous firmware along with updating to latest deconz beta and using GCFFFlasher V4. Still nothing.
Using -x 3 flag final output is as follows
23:20:05:748 bootloader v3 finished all data
|23:20:06:798 verify application is running
23:20:06:799 query deCONZ firmware version
23:20:08:801 failed to query application
retry, failed
The output of GCFFlasher indicates a problem but I think the flashing of the firmware could be successfull though. Because when the App shows the firmware version the Raspbee is connected and working. You could also validate that when you have deCONZ running in GUI mode on your desktop and it shows the network map.
There could be other problems when devices are not operable.
was it operable before the firmware upgrage?
Problems could be other devices connected to the USB3 port on your rasberry pi or a power adapter with less than 5.1V.
May I ask how exactly the “devices are not working” ? Not controllable, not reachable or not pairable?
Thanks for response.
Am using deconz in headless mode so could not at the time check the network map.
By ‘not working’ meant not able to control lights and no feedback from switches or sensors. Some lights were greyed out in the phoscon app, some not.
Sequence for failure was
-Worked ok
-SD card holder failed
-Imaged SD to USB3 stick
-Rebooted using USB3 stick
-Firmware upgrade (yes, I know)
-Cannot control anything as above
Tried various things
-Booted with old SD card (held in place by hand)- no difference
-Upgraded deconz to latest beta
-Downgraded deconz to latest stable
-Upgraded and downgraded firmware
-Installed USB remotely via usb extension cable
-Fixed vnc on the server to check deconz guy
-Upgraded raspbee ii using downloaded latests GCFFlasher
Wasn’t paying too much attention and just tried things as random. At some point sensors started responding and then lights became operational al be it badly at first.
Now it just works ok. USB3 stick installed in rpi4. Latest raspbee ii firmware via bundled GCFFlasher. Latest deconz stable. Really not sure what they key point was here.
The flash process still doesn’t seem quite right. Still returns what appears to be a failure. But it works…
Possible that the devices were not responsible because of interferences that are caused by USB3 adapters. To prevent those interferences it is recommended to use an USB extension cable or use the USB2 port.
And for the flashing I can’t say if it was a GCFFlasher bug but it seems the flashing was successfull despite the console output. Make sure to stop deCONZ before flashing (sudo systemctl stop deconz).
the thing with the raspbee is that its harder to do so.
I mean the USB Stick or portable hdd/ssd’s
Having the same problem.
I am using:
Raspbee II/deconz 2.12.6 stable
RPi 4B/4GB RAM
No USB devices, original power supply
Firmware-Upgrade to the latest stable Firmware produce the same messages/behavior as above mentioned by rutteger.
Downgrade to the initial Firmware provides these logs:
sudo GCFFlasher_internal -t 60 -f deCONZ_R21_0x26520700.bin.GCF -x 3
23:07:15:874 using firmware file: deCONZ_R21_0x26520700.bin.GCF
23:07:15:959 ls dev: /dev/ttyAMA0 (0x0000/0x0000) sn:
23:07:15:959 check symlink /dev/ttyAMA0 (/dev/ttyS0)
23:07:15:959 ls dev: /dev/ttyS0 (0x0000/0x0000) sn:
23:07:15:959 check symlink /dev/ttyS0 (/dev/ttyS0)
23:07:15:959 dev /dev/ttyS0 (/dev/ttyS0)
23:07:15:960 query bootloader v1 ID after 0 ms
23:07:17:462 query bootloader v1 ID after 1501 ms
23:07:17:963 query deCONZ firmware version
23:07:19:049 SLIP RX frame length: 10
23:07:19:049 ignore command: 0x81, length: 55834574858 (expected command: 0xBEF83A58)
23:07:20:051 uart reset failed, try RaspBee reset
action: reset device RaspBee
wiringPi 2.52 initialized
23:07:20:254 query bootloader v1 ID after 0 ms
23:07:20:747 RX 15 bytes ASCII �� after 493 ms
23:07:20:747 RX c08182030003003ecfe743dbdcfcc0 after 493 ms
23:07:20:747 SLIP RX frame length: 10
23:07:20:747 check magic: 0x81 cmd: 0x82 after 493 ms
Bootloader version 0x00030003, app crc: 0x43E7CF3E
23:07:20:748 GCF_ResetDeviceDone
23:07:20:750 bootloader v3 update firmware request size: 161378, addr: 0x00005000, type: 1, crc-32: 0xAAAAAAAA
23:07:20:750 TX c08103627602000050000001aaaaaaaaa9fbc0
23:07:20:757 SLIP RX frame length: 3
23:07:20:757 retry, elapsed 4 seconds
23:07:20:853 parse commands: /usr/bin/GCFFlasher_internal.bin -t 60 -f deCONZ_R21_0x26520700.bin.GCF -x 3
23:07:20:853 using firmware file: deCONZ_R21_0x26520700.bin.GCF
23:07:20:958 ls dev: /dev/ttyAMA0 (0x0000/0x0000) sn:
23:07:20:958 check symlink /dev/ttyAMA0 (/dev/ttyS0)
23:07:20:958 ls dev: /dev/ttyS0 (0x0000/0x0000) sn:
23:07:20:958 check symlink /dev/ttyS0 (/dev/ttyS0)
23:07:20:958 dev /dev/ttyS0 (/dev/ttyS0)
23:07:20:960 query bootloader v1 ID after 0 ms
23:07:22:461 query bootloader v1 ID after 1501 ms
23:07:22:962 query deCONZ firmware version
23:07:24:965 uart reset failed, try RaspBee reset
23:07:25:167 query bootloader v1 ID after 0 ms
23:07:25:659 RX 15 bytes ASCII �� after 493 ms
23:07:25:659 RX c08182030003003ecfe743dbdcfcc0 after 493 ms
23:07:25:659 SLIP RX frame length: 10
23:07:25:659 check magic: 0x81 cmd: 0x82 after 493 ms
23:07:25:661 GCF_ResetDeviceDone
23:07:25:662 bootloader v3 update firmware request size: 161378, addr: 0x00005000, type: 1, crc-32: 0xAAAAAAAA
23:07:25:662 TX c08103627602000050000001aaaaaaaaa9fbc0
23:07:25:669 SLIP RX frame length: 3
23:07:25:670 retry, elapsed 9 seconds
23:07:25:775 parse commands: /usr/bin/GCFFlasher_internal.bin -t 60 -f deCONZ_R21_0x26520700.bin.GCF -x 3
23:07:25:775 using firmware file: deCONZ_R21_0x26520700.bin.GCF
23:07:25:894 ls dev: /dev/ttyAMA0 (0x0000/0x0000) sn:
23:07:25:894 check symlink /dev/ttyAMA0 (/dev/ttyS0)
23:07:25:894 ls dev: /dev/ttyS0 (0x0000/0x0000) sn:
23:07:25:894 check symlink /dev/ttyS0 (/dev/ttyS0)
23:07:25:894 dev /dev/ttyS0 (/dev/ttyS0)
23:07:25:895 query bootloader v1 ID after 0 ms
23:07:27:397 query bootloader v1 ID after 1501 ms
23:07:27:898 query deCONZ firmware version
23:07:29:900 uart reset failed, try RaspBee reset
23:07:30:102 query bootloader v1 ID after 0 ms
23:07:30:594 RX 15 bytes ASCII �� after 493 ms
23:07:30:594 RX c08182030003003ecfe743dbdcfcc0 after 493 ms
23:07:30:594 SLIP RX frame length: 10
23:07:30:595 check magic: 0x81 cmd: 0x82 after 493 ms
23:07:30:596 GCF_ResetDeviceDone
23:07:30:597 bootloader v3 update firmware request size: 161378, addr: 0x00005000, type: 1, crc-32: 0xAAAAAAAA
23:07:30:597 TX c08103627602000050000001aaaaaaaaa9fbc0
23:07:30:604 SLIP RX frame length: 3
23:07:30:605 retry, elapsed 14 seconds
23:07:30:710 parse commands: /usr/bin/GCFFlasher_internal.bin -t 60 -f deCONZ_R21_0x26520700.bin.GCF -x 3
23:07:30:710 using firmware file: deCONZ_R21_0x26520700.bin.GCF
23:07:30:816 ls dev: /dev/ttyAMA0 (0x0000/0x0000) sn:
23:07:30:816 check symlink /dev/ttyAMA0 (/dev/ttyS0)
23:07:30:816 ls dev: /dev/ttyS0 (0x0000/0x0000) sn:
23:07:30:816 check symlink /dev/ttyS0 (/dev/ttyS0)
23:07:30:817 dev /dev/ttyS0 (/dev/ttyS0)
23:07:30:818 query bootloader v1 ID after 0 ms
23:07:32:320 query bootloader v1 ID after 1501 ms
23:07:32:820 query deCONZ firmware version
23:07:34:823 uart reset failed, try RaspBee reset
23:07:35:025 query bootloader v1 ID after 0 ms
23:07:35:517 RX 15 bytes ASCII �� after 493 ms
23:07:35:517 RX c08182030003003ecfe743dbdcfcc0 after 493 ms
23:07:35:518 SLIP RX frame length: 10
23:07:35:518 check magic: 0x81 cmd: 0x82 after 493 ms
23:07:35:519 GCF_ResetDeviceDone
23:07:35:520 bootloader v3 update firmware request size: 161378, addr: 0x00005000, type: 1, crc-32: 0xAAAAAAAA
23:07:35:520 TX c08103627602000050000001aaaaaaaaa9fbc0
23:07:35:528 SLIP RX frame length: 3
23:07:35:528 retry, elapsed 19 seconds
23:07:35:624 parse commands: /usr/bin/GCFFlasher_internal.bin -t 60 -f deCONZ_R21_0x26520700.bin.GCF -x 3
23:07:35:624 using firmware file: deCONZ_R21_0x26520700.bin.GCF
23:07:35:715 ls dev: /dev/ttyAMA0 (0x0000/0x0000) sn:
23:07:35:715 check symlink /dev/ttyAMA0 (/dev/ttyS0)
23:07:35:715 ls dev: /dev/ttyS0 (0x0000/0x0000) sn:
23:07:35:716 check symlink /dev/ttyS0 (/dev/ttyS0)
23:07:35:716 dev /dev/ttyS0 (/dev/ttyS0)
23:07:35:717 query bootloader v1 ID after 0 ms
23:07:37:218 query bootloader v1 ID after 1501 ms
23:07:37:719 query deCONZ firmware version
23:07:39:721 uart reset failed, try RaspBee reset
23:07:39:923 query bootloader v1 ID after 0 ms
23:07:40:416 RX 15 bytes ASCII �� after 493 ms
23:07:40:416 RX c08182030003003ecfe743dbdcfcc0 after 493 ms
23:07:40:416 SLIP RX frame length: 10
23:07:40:416 check magic: 0x81 cmd: 0x82 after 493 ms
23:07:40:417 GCF_ResetDeviceDone
23:07:40:419 bootloader v3 update firmware request size: 161378, addr: 0x00005000, type: 1, crc-32: 0xAAAAAAAA
23:07:40:419 TX c08103627602000050000001aaaaaaaaa9fbc0
23:07:40:426 SLIP RX frame length: 3
23:07:40:426 retry, elapsed 24 seconds
23:07:40:522 parse commands: /usr/bin/GCFFlasher_internal.bin -t 60 -f deCONZ_R21_0x26520700.bin.GCF -x 3
23:07:40:522 using firmware file: deCONZ_R21_0x26520700.bin.GCF
23:07:40:620 ls dev: /dev/ttyAMA0 (0x0000/0x0000) sn:
23:07:40:620 check symlink /dev/ttyAMA0 (/dev/ttyS0)
23:07:40:620 ls dev: /dev/ttyS0 (0x0000/0x0000) sn:
23:07:40:620 check symlink /dev/ttyS0 (/dev/ttyS0)
23:07:40:620 dev /dev/ttyS0 (/dev/ttyS0)
23:07:40:621 query bootloader v1 ID after 0 ms
23:07:42:123 query bootloader v1 ID after 1501 ms
23:07:42:624 query deCONZ firmware version
23:07:44:627 uart reset failed, try RaspBee reset
23:07:44:828 query bootloader v1 ID after 0 ms
23:07:45:321 RX 15 bytes ASCII �� after 493 ms
23:07:45:321 RX c08182030003003ecfe743dbdcfcc0 after 493 ms
23:07:45:321 SLIP RX frame length: 10
23:07:45:321 check magic: 0x81 cmd: 0x82 after 493 ms
23:07:45:322 GCF_ResetDeviceDone
23:07:45:324 bootloader v3 update firmware request size: 161378, addr: 0x00005000, type: 1, crc-32: 0xAAAAAAAA
23:07:45:324 TX c08103627602000050000001aaaaaaaaa9fbc0
23:07:45:331 SLIP RX frame length: 3
23:07:45:331 retry, elapsed 29 seconds
23:07:45:427 parse commands: /usr/bin/GCFFlasher_internal.bin -t 60 -f deCONZ_R21_0x26520700.bin.GCF -x 3
23:07:45:427 using firmware file: deCONZ_R21_0x26520700.bin.GCF
23:07:45:519 ls dev: /dev/ttyAMA0 (0x0000/0x0000) sn:
23:07:45:519 check symlink /dev/ttyAMA0 (/dev/ttyS0)
23:07:45:519 ls dev: /dev/ttyS0 (0x0000/0x0000) sn:
23:07:45:519 check symlink /dev/ttyS0 (/dev/ttyS0)
23:07:45:519 dev /dev/ttyS0 (/dev/ttyS0)
23:07:45:520 query bootloader v1 ID after 0 ms
23:07:47:022 query bootloader v1 ID after 1501 ms
23:07:47:522 query deCONZ firmware version
23:07:49:525 uart reset failed, try RaspBee reset
23:07:49:727 query bootloader v1 ID after 1 ms
23:07:50:219 RX 15 bytes ASCII �� after 493 ms
23:07:50:219 RX c08182030003003ecfe743dbdcfcc0 after 493 ms
23:07:50:219 SLIP RX frame length: 10
23:07:50:219 check magic: 0x81 cmd: 0x82 after 493 ms
23:07:50:221 GCF_ResetDeviceDone
23:07:50:222 bootloader v3 update firmware request size: 161378, addr: 0x00005000, type: 1, crc-32: 0xAAAAAAAA
23:07:50:222 TX c08103627602000050000001aaaaaaaaa9fbc0
23:07:50:229 SLIP RX frame length: 3
23:07:50:230 retry, elapsed 34 seconds
23:07:50:325 parse commands: /usr/bin/GCFFlasher_internal.bin -t 60 -f deCONZ_R21_0x26520700.bin.GCF -x 3
23:07:50:326 using firmware file: deCONZ_R21_0x26520700.bin.GCF
23:07:50:420 ls dev: /dev/ttyAMA0 (0x0000/0x0000) sn:
23:07:50:420 check symlink /dev/ttyAMA0 (/dev/ttyS0)
23:07:50:420 ls dev: /dev/ttyS0 (0x0000/0x0000) sn:
23:07:50:420 check symlink /dev/ttyS0 (/dev/ttyS0)
23:07:50:420 dev /dev/ttyS0 (/dev/ttyS0)
23:07:50:421 query bootloader v1 ID after 0 ms
23:07:51:923 query bootloader v1 ID after 1501 ms
23:07:52:423 query deCONZ firmware version
23:07:54:426 uart reset failed, try RaspBee reset
23:07:54:628 query bootloader v1 ID after 0 ms
23:07:55:120 RX 15 bytes ASCII �� after 493 ms
23:07:55:120 RX c08182030003003ecfe743dbdcfcc0 after 493 ms
23:07:55:120 SLIP RX frame length: 10
23:07:55:120 check magic: 0x81 cmd: 0x82 after 493 ms
23:07:55:122 GCF_ResetDeviceDone
23:07:55:123 bootloader v3 update firmware request size: 161378, addr: 0x00005000, type: 1, crc-32: 0xAAAAAAAA
23:07:55:123 TX c08103627602000050000001aaaaaaaaa9fbc0
23:07:55:130 SLIP RX frame length: 3
23:07:55:131 retry, elapsed 39 seconds
23:07:55:226 parse commands: /usr/bin/GCFFlasher_internal.bin -t 60 -f deCONZ_R21_0x26520700.bin.GCF -x 3
23:07:55:227 using firmware file: deCONZ_R21_0x26520700.bin.GCF
23:07:55:318 ls dev: /dev/ttyAMA0 (0x0000/0x0000) sn:
23:07:55:318 check symlink /dev/ttyAMA0 (/dev/ttyS0)
23:07:55:318 ls dev: /dev/ttyS0 (0x0000/0x0000) sn:
23:07:55:318 check symlink /dev/ttyS0 (/dev/ttyS0)
23:07:55:318 dev /dev/ttyS0 (/dev/ttyS0)
23:07:55:319 query bootloader v1 ID after 0 ms
23:07:56:821 query bootloader v1 ID after 1501 ms
23:07:57:322 query deCONZ firmware version
23:07:59:324 uart reset failed, try RaspBee reset
23:07:59:526 query bootloader v1 ID after 0 ms
23:08:00:019 RX 15 bytes ASCII �� after 493 ms
23:08:00:019 RX c08182030003003ecfe743dbdcfcc0 after 493 ms
23:08:00:019 SLIP RX frame length: 10
23:08:00:019 check magic: 0x81 cmd: 0x82 after 493 ms
23:08:00:020 GCF_ResetDeviceDone
23:08:00:022 bootloader v3 update firmware request size: 161378, addr: 0x00005000, type: 1, crc-32: 0xAAAAAAAA
23:08:00:022 TX c08103627602000050000001aaaaaaaaa9fbc0
23:08:00:029 SLIP RX frame length: 3
23:08:00:029 retry, elapsed 44 seconds
23:08:00:125 parse commands: /usr/bin/GCFFlasher_internal.bin -t 60 -f deCONZ_R21_0x26520700.bin.GCF -x 3
23:08:00:125 using firmware file: deCONZ_R21_0x26520700.bin.GCF
23:08:00:228 ls dev: /dev/ttyAMA0 (0x0000/0x0000) sn:
23:08:00:228 check symlink /dev/ttyAMA0 (/dev/ttyS0)
23:08:00:228 ls dev: /dev/ttyS0 (0x0000/0x0000) sn:
23:08:00:228 check symlink /dev/ttyS0 (/dev/ttyS0)
23:08:00:229 dev /dev/ttyS0 (/dev/ttyS0)
23:08:00:230 query bootloader v1 ID after 0 ms
23:08:01:732 query bootloader v1 ID after 1501 ms
23:08:02:232 query deCONZ firmware version
23:08:04:235 uart reset failed, try RaspBee reset
23:08:04:437 query bootloader v1 ID after 0 ms
23:08:04:929 RX 15 bytes ASCII �� after 493 ms
23:08:04:929 RX c08182030003003ecfe743dbdcfcc0 after 493 ms
23:08:04:929 SLIP RX frame length: 10
23:08:04:930 check magic: 0x81 cmd: 0x82 after 493 ms
23:08:04:931 GCF_ResetDeviceDone
23:08:04:932 bootloader v3 update firmware request size: 161378, addr: 0x00005000, type: 1, crc-32: 0xAAAAAAAA
23:08:04:933 TX c08103627602000050000001aaaaaaaaa9fbc0
23:08:04:940 SLIP RX frame length: 3
23:08:04:940 retry, elapsed 49 seconds
23:08:05:036 parse commands: /usr/bin/GCFFlasher_internal.bin -t 60 -f deCONZ_R21_0x26520700.bin.GCF -x 3
23:08:05:036 using firmware file: deCONZ_R21_0x26520700.bin.GCF
23:08:05:134 ls dev: /dev/ttyAMA0 (0x0000/0x0000) sn:
23:08:05:134 check symlink /dev/ttyAMA0 (/dev/ttyS0)
23:08:05:135 ls dev: /dev/ttyS0 (0x0000/0x0000) sn:
23:08:05:135 check symlink /dev/ttyS0 (/dev/ttyS0)
23:08:05:135 dev /dev/ttyS0 (/dev/ttyS0)
23:08:05:136 query bootloader v1 ID after 0 ms
23:08:06:640 query bootloader v1 ID after 1503 ms
23:08:07:141 query deCONZ firmware version
23:08:09:143 uart reset failed, try RaspBee reset
23:08:09:345 query bootloader v1 ID after 0 ms
23:08:09:838 RX 15 bytes ASCII �� after 493 ms
23:08:09:838 RX c08182030003003ecfe743dbdcfcc0 after 493 ms
23:08:09:838 SLIP RX frame length: 10
23:08:09:838 check magic: 0x81 cmd: 0x82 after 493 ms
23:08:09:839 GCF_ResetDeviceDone
23:08:09:841 bootloader v3 update firmware request size: 161378, addr: 0x00005000, type: 1, crc-32: 0xAAAAAAAA
23:08:09:841 TX c08103627602000050000001aaaaaaaaa9fbc0
23:08:09:848 SLIP RX frame length: 3
23:08:09:848 retry, elapsed 53 seconds
23:08:09:944 parse commands: /usr/bin/GCFFlasher_internal.bin -t 60 -f deCONZ_R21_0x26520700.bin.GCF -x 3
23:08:09:944 using firmware file: deCONZ_R21_0x26520700.bin.GCF
23:08:10:030 ls dev: /dev/ttyAMA0 (0x0000/0x0000) sn:
23:08:10:030 check symlink /dev/ttyAMA0 (/dev/ttyS0)
23:08:10:031 ls dev: /dev/ttyS0 (0x0000/0x0000) sn:
23:08:10:031 check symlink /dev/ttyS0 (/dev/ttyS0)
23:08:10:031 dev /dev/ttyS0 (/dev/ttyS0)
23:08:10:032 query bootloader v1 ID after 0 ms
23:08:11:534 query bootloader v1 ID after 1501 ms
23:08:12:035 query deCONZ firmware version
23:08:14:037 uart reset failed, try RaspBee reset
23:08:14:239 query bootloader v1 ID after 0 ms
23:08:14:731 RX 15 bytes ASCII �� after 493 ms
23:08:14:731 RX c08182030003003ecfe743dbdcfcc0 after 493 ms
23:08:14:731 SLIP RX frame length: 10
23:08:14:732 check magic: 0x81 cmd: 0x82 after 493 ms
23:08:14:733 GCF_ResetDeviceDone
23:08:14:734 bootloader v3 update firmware request size: 161378, addr: 0x00005000, type: 1, crc-32: 0xAAAAAAAA
23:08:14:734 TX c08103627602000050000001aaaaaaaaa9fbc0
23:08:14:742 SLIP RX frame length: 3
23:08:14:742 retry, elapsed 58 seconds
23:08:14:837 parse commands: /usr/bin/GCFFlasher_internal.bin -t 60 -f deCONZ_R21_0x26520700.bin.GCF -x 3
23:08:14:837 using firmware file: deCONZ_R21_0x26520700.bin.GCF
23:08:14:924 ls dev: /dev/ttyAMA0 (0x0000/0x0000) sn:
23:08:14:924 check symlink /dev/ttyAMA0 (/dev/ttyS0)
23:08:14:924 ls dev: /dev/ttyS0 (0x0000/0x0000) sn:
23:08:14:924 check symlink /dev/ttyS0 (/dev/ttyS0)
23:08:14:924 dev /dev/ttyS0 (/dev/ttyS0)
23:08:14:925 query bootloader v1 ID after 0 ms
23:08:16:427 query bootloader v1 ID after 1501 ms
23:08:16:928 query deCONZ firmware version
23:08:18:930 uart reset failed, try RaspBee reset
23:08:19:132 query bootloader v1 ID after 0 ms
23:08:19:624 RX 15 bytes ASCII �� after 493 ms
23:08:19:625 RX c08182030003003ecfe743dbdcfcc0 after 493 ms
23:08:19:625 SLIP RX frame length: 10
23:08:19:625 check magic: 0x81 cmd: 0x82 after 493 ms
23:08:19:626 GCF_ResetDeviceDone
23:08:19:628 bootloader v3 update firmware request size: 161378, addr: 0x00005000, type: 1, crc-32: 0xAAAAAAAA
23:08:19:628 TX c08103627602000050000001aaaaaaaaa9fbc0
23:08:19:635 SLIP RX frame length: 3
retry, failed
Upgrade to latest possible firmware provides the messages:
sudo GCFFlasher_internal -t 60 -f deCONZ_RaspBeeII_0x26690700.bin.GCF
deCONZ firmware version 26690700
Bootloader version 0x00030003, app crc: 0x93C2CD88
flashing 164241 bytes: |================|deCONZ firmware version 26690700
But no devices can be operated within the Phoscon Web App. Also the update to the latest deconz beta version doesn’t work.
deconz logs:
deCONZ --dbg-info=2 --dbg-zdp=1 --dbg-zcl=1 --db-aps=1 --dbg-http=1
produces a lot of stuff like these
23:59:44:696 Node 0xF0D1B8000011BD4D is known by 0 neighbors, last seen 27973600 s
23:59:45:176 Node 0xF0D1B8000011BE7F is known by 0 neighbors, last seen 28051816 s
23:59:45:656 Node 0xF0D1B8000013BC65 is known by 0 neighbors, last seen 28274544 s
The upload with the latest GCFFlasher produces:
sudo ./GCFFlasher -t 60 -d /dev/ttyS0 -f deCONZ_RaspBeeII_0x26720700.bin.GCF
read file success: deCONZ_RaspBeeII_0x26720700.bin.GCF (164241 bytes)
flash firmware
command reset timeout
RaspBee reset done
query bootloader id
query bootloader id
bootloader version 0x00030003, app crc 0x01BB96DC
uploading ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓ 100 %pi@sepia-home:~/gcfflasher $ 0028100, length: 131
No pairing to the existing devices. Network Map is shown within the GUI. Any advice?
Can you add logs with:
deCONZ --dbg-info=2 ----db-aps=2 --dbg-error=2
And just wondering: What Case do you have with the raspbee?
Thanks for the response. I’m sorry for not making myself clear.
I carried out a firmware upgrade, obtaining the same message as mentioned above rutteger. I get exact the same behaviour as rutteger described at October 12th.
After the firmware update, that seem to fail I see the new firmware with the Phoscon Web App, but having a look into the GUI the network map is shown but no mesh is established. As a result I am not able to control anything.
I will provide the log this evening. Thanks for getting in touch.
There are the logs. Thanks in advance.
21:41:01:056 Sqlite sensors: sid = 62
21:41:01:056 Sqlite sensors: name = Temperaturregler Wohnzimmer West
21:41:01:056 Sqlite sensors: type = ZHAThermostat
21:41:01:056 Sqlite sensors: modelid = SPZB0001
21:41:01:056 Sqlite sensors: manufacturername = Eurotronic
21:41:01:056 Sqlite sensors: uniqueid = 00:15:8d:00:07:06:3f:0e-01-0201
21:41:01:056 Sqlite sensors: swversion = 18181120
21:41:01:056 Sqlite sensors: state = {“lastupdated”:“2021-11-15T19:28:38.688”,“on”:false,“temperature”:1849,“valve”:0}
21:41:01:056 Sqlite sensors: config = {“battery”:100,“displayflipped”:false,“heatsetpoint”:1849,“hostflags”:1,“locked”:false,“mode”:“auto”,“offset”:0,“on”:true,“reachable”:false}
21:41:01:056 Sqlite sensors: fingerprint = {“d”:769,“ep”:1,“in”:[1,513],“p”:260}
21:41:01:056 Sqlite sensors: deletedState = normal
21:41:01:056 Sqlite sensors: mode = 1
21:41:01:056 Sqlite sensors: lastseen = 2021-11-15T19:41Z
21:41:01:056 Sqlite sensors: lastannounced = 2021-11-12T16:29:04Z
21:41:01:056 DB found sensor Temperaturregler Wohnzimmer West 62
21:41:01:060 Sqlite sensors: fingerprint = {“d”:769,“ep”:1,“in”:[1,513],“p”:260}
21:41:01:060 Sqlite sensors: deletedState = normal
21:41:01:060 Sqlite sensors: mode = 1
21:41:01:060 Sqlite sensors: lastseen = 2021-11-16T20:40Z
21:41:01:061 Sqlite sensors: lastannounced = 2021-11-04T11:39:20Z
21:41:01:061 DB found sensor Temperaturregler Bad 53
21:41:01:062 sql exec SELECT * FROM gateways
21:41:01:064 Daylight now: nightStart, status: 230, daylight: 0, dark: 1
21:41:01:064 failed to start websocket server on port 443. error: The bound address is already in use
21:41:03:283 Node: id: 16, 00:15:8d:00:05:49:b7:dc (0x00158D000549B7DC) scene: 654,029448, 32,064016
21:41:03:283 Node: id: 30, f0:d1:b8:00:00:11:ba:1d (0xF0D1B8000011BA1D) scene: 494,199385, -396,015803
21:41:03:287 Node: id: 35, f0:d1:b8:00:00:11:ba:68 (0xF0D1B8000011BA68) scene: 988,025428, -169,906271
21:41:03:289 Node: id: 11, f0:d1:b8:00:00:13:c3:55 (0xF0D1B8000013C355) scene: -1016,350787, -220,887171
21:41:03:290 Node: id: 27, f0:d1:b8:00:00:11:be:2b (0xF0D1B8000011BE2B) scene: -1015,865279, -49,495645
21:41:03:292 Node: id: 37, f0:d1:b8:00:00:11:9d:f4 (0xF0D1B80000119DF4) scene: -1424,144792, -352,236777
21:41:03:293 Node: id: 24, f0:d1:b8:00:00:11:b8:87 (0xF0D1B8000011B887) scene: 920,550971, -278,717062
21:41:03:295 Node: id: 40, 00:0d:6f:00:14:17:fc:d4 (0x000D6F001417FCD4) scene: -912,880201, -444,838605
21:41:03:296 Node: id: 20, 7c:b0:3e:aa:00:ad:77:0c (0x7CB03EAA00AD770C) scene: 261,237109, -438,528774
21:41:03:298 Node: id: 62, 00:15:8d:00:07:74:34:d7 (0x00158D00077434D7) scene: -1480,584060, 0,639870
21:41:03:305 Node: id: 31, f0:d1:b8:00:00:11:99:ed (0xF0D1B800001199ED) scene: 486,331193, -445,378589
21:41:03:306 Node: id: 72, 00:15:8d:00:07:06:3f:cc (0x00158D0007063FCC) scene: 79,000000, 29,000000
21:41:03:308 Node: id: 42, 00:0d:6f:00:14:17:94:e7 (0x000D6F00141794E7) scene: -571,977947, 260,400964
21:41:03:310 Node: id: 28, f0:d1:b8:00:00:11:ab:13 (0xF0D1B8000011AB13) scene: -653,209331, 50,510479
21:41:03:312 Node: id: 69, 00:15:8d:00:07:06:3f:0e (0x00158D0007063F0E) scene: -62,000000, 61,000000
21:41:03:313 Node: id: 15, 58:8e:81:ff:fe:0b:f6:85 (0x588E81FFFE0BF685) scene: -290,073893, 79,779593
21:41:03:313 Node: id: 44, f0:d1:b8:00:00:15:52:be (0xF0D1B800001552BE) scene: -1017,748637, 68,154180
21:41:03:314 Node: id: 73, 00:15:8d:00:07:06:3e:95 (0x00158D0007063E95) scene: 71,000000, -138,000000
21:41:03:315 Node: id: 4, 00:0b:57:ff:fe:be:ec:6c (0x000B57FFFEBEEC6C) scene: -1428,117770, -404,660366
21:41:03:315 Node: id: 7, 68:0a:e2:ff:fe:a1:a7:61 (0x680AE2FFFEA1A761) scene: -154,263546, -587,959644
21:41:03:317 Node: id: 21, 5c:02:72:ff:fe:86:d9:63 (0x5C0272FFFE86D963) scene: -221,650554, -40,454297
21:41:03:318 Node: id: 39, 00:0d:6f:00:14:17:93:3a (0x000D6F001417933A) scene: -834,160603, -611,188001
21:41:03:319 Node: id: 19, f0:d1:b8:00:00:14:28:bf (0xF0D1B800001428BF) scene: 242,682242, -138,599939
21:41:03:321 Node: id: 5, 00:15:8d:00:04:4d:1b:65 (0x00158D00044D1B65) scene: -837,076619, -550,324063
21:41:03:321 Node: id: 17, 00:15:8d:00:05:78:e6:57 (0x00158D000578E657) scene: 207,798633, -47,847482
21:41:03:322 Node: id: 41, 68:0a:e2:ff:fe:4c:6e:c6 (0x680AE2FFFE4C6EC6) scene: -512,400737, -713,265414
21:41:03:334 Node: id: 74, 00:15:8d:00:07:74:34:dd (0x00158D00077434DD) scene: -176,543718, -448,579374
21:41:03:335 Node: id: 43, 00:15:8d:00:03:2c:8a:e5 (0x00158D00032C8AE5) scene: 501,659873, 185,291892
21:41:03:336 Node: id: 34, f0:d1:b8:00:00:11:bb:d2 (0xF0D1B8000011BBD2) scene: 1026,412526, -79,425435
21:41:03:338 Node: id: 23, f0:d1:b8:00:00:15:3f:5c (0xF0D1B80000153F5C) scene: 554,209605, -277,976586
21:41:03:338 Node: id: 33, f0:d1:b8:00:00:15:0f:3e (0xF0D1B80000150F3E) scene: 206,188121, -294,321474
21:41:03:339 Node: id: 38, 00:0b:57:ff:fe:af:9b:5d (0x000B57FFFEAF9B5D) scene: 542,418935, -204,216408
21:41:03:341 Node: id: 36, f0:d1:b8:00:00:10:9d:0e (0xF0D1B80000109D0E) scene: 997,513895, -125,527178
21:41:03:343 Node: id: 8, f0:d1:b8:00:00:13:10:81 (0xF0D1B80000131081) scene: -1015,667043, -167,807164
21:41:03:343 Node: id: 13, 58:8e:81:ff:fe:11:bd:de (0x588E81FFFE11BDDE) scene: -999,848558, 135,011559
21:41:03:344 Node: id: 18, f0:d1:b8:00:00:14:9b:a9 (0xF0D1B80000149BA9) scene: -540,851176, 165,291167
21:41:03:355 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 3, node: 0x0000
21:41:03:359 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 7, node: 0x0000
21:41:03:359 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 5, node: 0x0000
21:41:03:360 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 3, node: 0x0000
21:41:03:364 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 5, node: 0x1194
21:41:03:375 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 3, node: 0x0000
21:41:03:378 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 7, node: 0x12BC
21:41:03:378 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 5, node: 0x12BC
21:41:03:380 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 3, node: 0x0000
21:41:03:384 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 7, node: 0x16B2
21:41:03:384 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 5, node: 0x16B2
21:41:03:385 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 3, node: 0x0000
21:41:03:389 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 7, node: 0x17A2
21:41:03:389 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 5, node: 0x17A2
21:41:03:390 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 3, node: 0x0000
21:41:03:393 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 3, node: 0x0000
21:41:03:396 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 7, node: 0x2935
21:41:03:396 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 5, node: 0x2935
21:41:03:398 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 3, node: 0x0000
21:41:03:401 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 7, node: 0x297E
21:41:03:401 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 5, node: 0x297E
21:41:03:403 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 3, node: 0x0000
21:41:03:406 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 7, node: 0x3053
21:41:03:406 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 5, node: 0x3053
21:41:03:408 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 3, node: 0x0000
21:41:03:412 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 7, node: 0x311C
21:41:03:412 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 5, node: 0x311C
21:41:03:413 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 3, node: 0x0000
21:41:03:417 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 7, node: 0x35CE
21:41:03:417 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 5, node: 0x35CE
21:41:03:419 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 3, node: 0x0000
21:41:03:422 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 7, node: 0x37C2
21:41:03:422 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 5, node: 0x37C2
21:41:03:423 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 3, node: 0x0000
21:41:03:433 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 3, node: 0x0000
21:41:03:435 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 7, node: 0x4A4D
21:41:03:435 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 5, node: 0x4A4D
21:41:03:436 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 3, node: 0x0000
21:41:03:439 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 3, node: 0x0000
21:41:03:443 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 7, node: 0x50AB
21:41:03:443 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 5, node: 0x50AB
21:41:03:444 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 3, node: 0x0000
21:41:03:448 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 3, node: 0x0000
21:41:03:458 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 3, node: 0x0000
21:41:03:461 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 7, node: 0x58AF
21:41:03:461 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 5, node: 0x58AF
21:41:03:463 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 3, node: 0x0000
21:41:03:466 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 3, node: 0x0000
21:41:03:470 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 3, node: 0x0000
21:41:03:472 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 7, node: 0x67AE
21:41:03:472 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 5, node: 0x67AE
21:41:03:474 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 3, node: 0x0000
21:41:03:478 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 3, node: 0x0000
21:41:03:481 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 3, node: 0x0000
21:41:03:485 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 7, node: 0x7EF2
21:41:03:485 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 5, node: 0x7EF2
21:41:03:487 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 3, node: 0x0000
21:41:03:489 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 7, node: 0x8158
21:41:03:489 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 5, node: 0x8158
21:41:03:490 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 3, node: 0x0000
21:41:03:500 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 3, node: 0x0000
21:41:03:504 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 7, node: 0x952C
21:41:03:504 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 5, node: 0x952C
21:41:03:505 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 3, node: 0x0000
21:41:03:530 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 3, node: 0x0000
21:41:03:533 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 7, node: 0xD2B0
21:41:03:533 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 5, node: 0xD2B0
21:41:03:534 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 3, node: 0x0000
21:41:03:537 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 7, node: 0xE3C3
21:41:03:537 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 5, node: 0xE3C3
21:41:03:539 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 3, node: 0x0000
21:41:03:543 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 7, node: 0xE45B
21:41:03:543 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 5, node: 0xE45B
21:41:03:545 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 3, node: 0x0000
21:41:03:549 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 7, node: 0xE667
21:41:03:549 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 5, node: 0xE667
21:41:03:550 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 3, node: 0x0000
21:41:03:553 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 7, node: 0xEE91
21:41:03:553 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 5, node: 0xEE91
21:41:03:554 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 3, node: 0x0000
21:41:03:558 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 3, node: 0x0000
21:41:03:562 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 7, node: 0xFC66
21:41:03:562 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 5, node: 0xFC66
21:41:03:563 sql exec SELECT * FROM nodes WHERE mac=‘00:21:2e:ff:ff:05:bf:26-01’ COLLATE NOCASE AND state != ‘deleted’
21:41:03:564 LightNode 1: Configuration tool 1 added
21:41:03:564 DB pushZdpDescriptorDb()
21:41:03:564 DB save zll database items 0x00000880
21:41:03:565 DB sql exec REPLACE INTO sensors (sid, name, type, modelid, manufacturername, uniqueid, swversion, state, config, fingerprint, deletedState, mode, lastseen, lastannounced) VALUES (‘1’, ‘Daylight’, ‘Daylight’, ‘PHDL00’, ‘Philips’, ‘00:21:2e:ff:ff:05:bf:26-01’, ‘1.0’, ‘{“dark”:true,“daylight”:false,“lastupdated”:“2021-11-16T20:41:01.064”,“status”:230,“sunrise”:“2021-11-16T06:31:20”,“sunset”:“2021-11-16T15:13:49”}’, ‘{“configured”:true,“lat”:“52.520007”,“long”:“13.404954”,“on”:true,“sunriseoffset”:30,“sunsetoffset”:-30}’, ‘’, ‘normal’, ‘1’, ‘’, ‘’)
21:41:03:565 DB sql exec UPDATE devices SET nwk = 0 WHERE mac = ‘00:21:2e:ff:ff:05:bf:26’;INSERT INTO devices (mac,nwk,timestamp) SELECT ‘00:21:2e:ff:ff:05:bf:26’, 0, strftime(’%s’,‘now’) WHERE (SELECT changes() = 0);
21:41:03:578 DB saved in 13 ms
21:41:03:579 DB pushZdpDescriptorDb()
21:41:03:580 sql exec SELECT * FROM nodes WHERE mac=‘f0:d1:b8:00:00:13:c3:46-01’ COLLATE NOCASE AND state != ‘deleted’
21:41:03:581 LightNode 7: Wohnzimmer Fernseher added
21:41:03:581 DB pushZdpDescriptorDb()
21:41:03:581 DB save zll database items 0x00000800
21:41:03:581 DB sql exec UPDATE devices SET nwk = 2748 WHERE mac = ‘f0:d1:b8:00:00:13:c3:46’;INSERT INTO devices (mac,nwk,timestamp) SELECT ‘f0:d1:b8:00:00:13:c3:46’, 2748, strftime(’%s’,‘now’) WHERE (SELECT changes() = 0);
21:41:03:581 DB saved in 0 ms
21:41:03:582 DB pushZdpDescriptorDb()
21:41:03:589 DB pushZdpDescriptorDb()
21:41:03:590 SensorNode 53 set node 0x00158d0007743498
21:41:03:590 DB pushZdpDescriptorDb()
21:41:03:590 DB save zll database items 0x00000800
21:41:03:590 DB sql exec UPDATE devices SET nwk = 3394 WHERE mac = ‘00:15:8d:00:07:74:34:98’;INSERT INTO devices (mac,nwk,timestamp) SELECT ‘00:15:8d:00:07:74:34:98’, 3394, strftime(’%s’,‘now’) WHERE (SELECT changes() = 0);
21:41:03:590 DB saved in 0 ms
21:41:03:591 DB pushZdpDescriptorDb()
21:41:03:591 sql exec SELECT * FROM nodes WHERE mac=‘f0:d1:b8:00:00:11:bd:4d-01’ COLLATE NOCASE AND state != ‘deleted’
21:41:03:592 LightNode 16: Deckenlicht West Wohnzimmer added
21:41:03:593 DB pushZdpDescriptorDb()
21:41:03:593 DB save zll database items 0x00000800
21:41:03:593 DB sql exec UPDATE devices SET nwk = 4500 WHERE mac = ‘f0:d1:b8:00:00:11:bd:4d’;INSERT INTO devices (mac,nwk,timestamp) SELECT ‘f0:d1:b8:00:00:11:bd:4d’, 4500, strftime(’%s’,‘now’) WHERE (SELECT changes() = 0);
21:41:03:593 DB saved in 0 ms
21:41:03:594 DB pushZdpDescriptorDb()
21:41:03:594 sql exec SELECT * FROM nodes WHERE mac=‘f0:d1:b8:00:00:11:be:7f-01’ COLLATE NOCASE AND state != ‘deleted’
21:41:03:600 DB pushZdpDescriptorDb()
21:41:03:601 DB pushZdpDescriptorDb()
21:41:03:601 SensorNode 16 set node 0x00158d000549b7dc
21:41:03:601 SensorNode 10 set node 0x00158d000549b7dc
21:41:03:602 SensorNode 11 set node 0x00158d000549b7dc
21:41:03:602 DB pushZdpDescriptorDb()
21:41:03:602 DB save zll database items 0x00000800
21:41:03:602 DB sql exec UPDATE devices SET nwk = 7339 WHERE mac = ‘00:15:8d:00:05:49:b7:dc’;INSERT INTO devices (mac,nwk,timestamp) SELECT ‘00:15:8d:00:05:49:b7:dc’, 7339, strftime(’%s’,‘now’) WHERE (SELECT changes() = 0);
21:41:03:602 DB saved in 0 ms
21:41:03:603 DB pushZdpDescriptorDb()
21:41:03:603 sql exec SELECT * FROM nodes WHERE mac=‘f0:d1:b8:00:00:11:ba:1d-01’ COLLATE NOCASE AND state != ‘deleted’
21:41:03:604 LightNode 20: Deckenlicht Mitte Schlafzimmer added
21:41:03:604 DB pushZdpDescriptorDb()
21:41:03:604 DB save zll database items 0x00000800
21:41:03:604 DB sql exec UPDATE devices SET nwk = 10549 WHERE mac = ‘f0:d1:b8:00:00:11:ba:1d’;INSERT INTO devices (mac,nwk,timestamp) SELECT ‘f0:d1:b8:00:00:11:ba:1d’, 10549, strftime(’%s’,‘now’) WHERE (SELECT changes() = 0);
21:41:03:604 DB saved in 0 ms
21:41:03:605 DB pushZdpDescriptorDb()
21:41:03:605 sql exec SELECT * FROM nodes WHERE mac=‘f0:d1:b8:00:00:11:ba:68-01’ COLLATE NOCASE AND state != ‘deleted’
21:41:03:606 LightNode 23: Deckenlicht Mitte Arbeitszimmer added
21:41:03:606 DB pushZdpDescriptorDb()
21:41:03:606 DB save zll database items 0x00000800
21:41:03:606 DB sql exec UPDATE devices SET nwk = 10622 WHERE mac = ‘f0:d1:b8:00:00:11:ba:68’;INSERT INTO devices (mac,nwk,timestamp) SELECT ‘f0:d1:b8:00:00:11:ba:68’, 10622, strftime(’%s’,‘now’) WHERE (SELECT changes() = 0);
21:41:03:607 DB saved in 0 ms
21:41:03:607 DB pushZdpDescriptorDb()
21:41:03:608 sql exec SELECT * FROM nodes WHERE mac=‘f0:d1:b8:00:00:13:c3:55-01’ COLLATE NOCASE AND state != ‘deleted’
21:41:03:609 LightNode 6: Wohnzimmer Regal added
21:41:03:609 DB pushZdpDescriptorDb()
21:41:03:609 DB save zll database items 0x00000800
21:41:03:609 DB sql exec UPDATE devices SET nwk = 12371 WHERE mac = ‘f0:d1:b8:00:00:13:c3:55’;INSERT INTO devices (mac,nwk,timestamp) SELECT ‘f0:d1:b8:00:00:13:c3:55’, 12371, strftime(’%s’,‘now’) WHERE (SELECT changes() = 0);
21:41:03:609 DB saved in 0 ms
21:41:03:610 DB pushZdpDescriptorDb()
21:41:03:610 sql exec SELECT * FROM nodes WHERE mac=‘f0:d1:b8:00:00:11:be:2b-01’ COLLATE NOCASE AND state != ‘deleted’
21:41:03:611 LightNode 17: Deckenlicht Mitte Wohnzimmer added
21:41:03:611 DB pushZdpDescriptorDb()
21:41:03:611 DB save zll database items 0x00000800
21:41:03:611 DB sql exec UPDATE devices SET nwk = 12572 WHERE mac = ‘f0:d1:b8:00:00:11:be:2b’;INSERT INTO devices (mac,nwk,timestamp) SELECT ‘f0:d1:b8:00:00:11:be:2b’, 12572, strftime(’%s’,‘now’) WHERE (SELECT changes() = 0);
21:41:03:612 DB saved in 0 ms
21:41:03:612 DB pushZdpDescriptorDb()
21:41:03:613 sql exec SELECT * FROM nodes WHERE mac=‘f0:d1:b8:00:00:11:9d:f4-01’ COLLATE NOCASE AND state != ‘deleted’
21:41:03:614 LightNode 25: Deckenlicht Vorraum added
21:41:03:614 DB pushZdpDescriptorDb()
21:41:03:614 DB save zll database items 0x00000800
21:41:03:614 DB sql exec UPDATE devices SET nwk = 13774 WHERE mac = ‘f0:d1:b8:00:00:11:9d:f4’;INSERT INTO devices (mac,nwk,timestamp) SELECT ‘f0:d1:b8:00:00:11:9d:f4’, 13774, strftime(’%s’,‘now’) WHERE (SELECT changes() = 0);
21:41:03:614 DB saved in 0 ms
21:41:03:615 DB pushZdpDescriptorDb()
21:41:03:615 sql exec SELECT * FROM nodes WHERE mac=‘f0:d1:b8:00:00:11:b8:87-01’ COLLATE NOCASE AND state != ‘deleted’
21:41:03:616 LightNode 14: Gaestebad Sued added
21:41:03:616 DB pushZdpDescriptorDb()
21:41:03:616 DB save zll database items 0x00000800
21:41:03:616 DB sql exec UPDATE devices SET nwk = 14274 WHERE mac = ‘f0:d1:b8:00:00:11:b8:87’;INSERT INTO devices (mac,nwk,timestamp) SELECT ‘f0:d1:b8:00:00:11:b8:87’, 14274, strftime(’%s’,‘now’) WHERE (SELECT changes() = 0);
21:41:03:617 DB saved in 0 ms
21:41:03:617 DB pushZdpDescriptorDb()
21:41:03:618 SensorNode 23 set node 0x000d6f001417fcd4
21:41:03:618 DB pushZdpDescriptorDb()
21:41:03:618 DB save zll database items 0x00000800
21:41:03:618 DB sql exec UPDATE devices SET nwk = 16842 WHERE mac = ‘00:0d:6f:00:14:17:fc:d4’;INSERT INTO devices (mac,nwk,timestamp) SELECT ‘00:0d:6f:00:14:17:fc:d4’, 16842, strftime(’%s’,‘now’) WHERE (SELECT changes() = 0);
21:41:03:618 DB saved in 0 ms
21:41:03:619 DB pushZdpDescriptorDb()
21:41:03:620 sql exec SELECT * FROM nodes WHERE mac=‘7c:b0:3e:aa:00:ad:77:0c-03’ COLLATE NOCASE AND state != ‘deleted’
21:41:03:621 LightNode 9: Deckenlicht Bad added
21:41:03:621 DB pushZdpDescriptorDb()
21:41:03:621 DB save zll database items 0x00000800
21:41:03:621 DB sql exec UPDATE devices SET nwk = 19021 WHERE mac = ‘7c:b0:3e:aa:00:ad:77:0c’;INSERT INTO devices (mac,nwk,timestamp) SELECT ‘7c:b0:3e:aa:00:ad:77:0c’, 19021, strftime(’%s’,‘now’) WHERE (SELECT changes() = 0);
21:41:03:621 DB saved in 0 ms
21:41:03:622 SensorNode 54 set node 0x00158d00077434d7
21:41:03:622 DB pushZdpDescriptorDb()
21:41:03:622 DB save zll database items 0x00000800
21:41:03:622 DB sql exec UPDATE devices SET nwk = 20055 WHERE mac = ‘00:15:8d:00:07:74:34:d7’;INSERT INTO devices (mac,nwk,timestamp) SELECT ‘00:15:8d:00:07:74:34:d7’, 20055, strftime(’%s’,‘now’) WHERE (SELECT changes() = 0);
21:41:03:622 DB saved in 0 ms
21:41:03:623 DB pushZdpDescriptorDb()
21:41:03:623 sql exec SELECT * FROM nodes WHERE mac=‘f0:d1:b8:00:00:11:99:ed-01’ COLLATE NOCASE AND state != ‘deleted’
21:41:03:624 LightNode 21: Deckenlicht Ost Schlafzimmer added
21:41:03:624 DB pushZdpDescriptorDb()
21:41:03:624 DB save zll database items 0x00000800
21:41:03:624 DB sql exec UPDATE devices SET nwk = 20651 WHERE mac = ‘f0:d1:b8:00:00:11:99:ed’;INSERT INTO devices (mac,nwk,timestamp) SELECT ‘f0:d1:b8:00:00:11:99:ed’, 20651, strftime(’%s’,‘now’) WHERE (SELECT changes() = 0);
21:41:03:625 DB saved in 0 ms
21:41:03:625 DB pushZdpDescriptorDb()
21:41:03:626 SensorNode 72 set node 0x00158d0007063fcc
21:41:03:647 DB pushZdpDescriptorDb()
21:41:03:647 DB save zll database items 0x00000800
21:41:03:647 DB sql exec UPDATE devices SET nwk = 38188 WHERE mac = ‘f0:d1:b8:00:00:14:28:bf’;INSERT INTO devices (mac,nwk,timestamp) SELECT ‘f0:d1:b8:00:00:14:28:bf’, 38188, strftime(’%s’,‘now’) WHERE (SELECT changes() = 0);
21:41:03:648 DB saved in 0 ms
21:41:03:648 DB pushZdpDescriptorDb()
21:41:03:649 SensorNode 8 set node 0x00158d00044d1b65
21:41:03:649 SensorNode 6 set node 0x00158d00044d1b65
21:41:03:649 SensorNode 7 set node 0x00158d00044d1b65
21:41:03:649 DB pushZdpDescriptorDb()
21:41:03:649 DB save zll database items 0x00000800
21:41:03:649 DB sql exec UPDATE devices SET nwk = 38335 WHERE mac = ‘00:15:8d:00:04:4d:1b:65’;INSERT INTO devices (mac,nwk,timestamp) SELECT ‘00:15:8d:00:04:4d:1b:65’, 38335, strftime(’%s’,‘now’) WHERE (SELECT changes() = 0);
21:41:03:650 DB saved in 0 ms
21:41:03:650 DB pushZdpDescriptorDb()
21:41:03:651 SensorNode 17 set node 0x00158d000578e657
21:41:03:651 SensorNode 18 set node 0x00158d000578e657
21:41:03:651 SensorNode 19 set node 0x00158d000578e657
21:41:03:651 DB pushZdpDescriptorDb()
21:41:03:651 DB save zll database items 0x00000800
21:41:03:651 DB sql exec UPDATE devices SET nwk = 42694 WHERE mac = ‘00:15:8d:00:05:78:e6:57’;INSERT INTO devices (mac,nwk,timestamp) SELECT ‘00:15:8d:00:05:78:e6:57’, 42694, strftime(’%s’,‘now’) WHERE (SELECT changes() = 0);
21:41:03:652 DB saved in 0 ms
21:41:03:652 DB pushZdpDescriptorDb()
21:41:03:653 SensorNode 24 set node 0x680ae2fffe4c6ec6
21:41:03:653 DB pushZdpDescriptorDb()
21:41:03:653 DB save zll database items 0x00000800
21:41:03:653 DB sql exec UPDATE devices SET nwk = 43895 WHERE mac = ‘68:0a:e2:ff:fe:4c:6e:c6’;INSERT INTO devices (mac,nwk,timestamp) SELECT ‘68:0a:e2:ff:fe:4c:6e:c6’, 43895, strftime(’%s’,‘now’) WHERE (SELECT changes() = 0);
21:41:03:653 DB saved in 0 ms
21:41:03:654 DB pushZdpDescriptorDb()
21:41:03:654 SensorNode 76 set node 0x00158d00077434dd
21:41:03:654 DB save zll database items 0x00000800
21:41:03:654 DB sql exec UPDATE devices SET nwk = 45638 WHERE mac = ‘00:15:8d:00:07:74:34:dd’;INSERT INTO devices (mac,nwk,timestamp) SELECT ‘00:15:8d:00:07:74:34:dd’, 45638, strftime(’%s’,‘now’) WHERE (SELECT changes() = 0);
21:41:03:655 DB saved in 0 ms
21:41:03:655 DB pushZdpDescriptorDb()
21:41:03:656 SensorNode 26 set node 0x00158d00032c8ae5
21:41:03:656 SensorNode 27 set node 0x00158d00032c8ae5
21:41:03:656 DB pushZdpDescriptorDb()
21:41:03:656 DB save zll database items 0x00000800
21:41:03:656 DB sql exec UPDATE devices SET nwk = 50517 WHERE mac = ‘00:15:8d:00:03:2c:8a:e5’;INSERT INTO devices (mac,nwk,timestamp) SELECT ‘00:15:8d:00:03:2c:8a:e5’, 50517, strftime(’%s’,‘now’) WHERE (SELECT changes() = 0);
21:41:03:657 DB saved in 0 ms
21:41:03:657 DB pushZdpDescriptorDb()
21:41:03:658 DB pushZdpDescriptorDb()
21:41:03:659 DB pushZdpDescriptorDb()
21:41:03:659 sql exec SELECT * FROM nodes WHERE mac=‘f0:d1:b8:00:00:11:bb:d2-01’ COLLATE NOCASE AND state != ‘deleted’
21:41:03:660 LightNode 12: Deckenlicht Sued Arbeitszimmer added
21:41:03:660 DB pushZdpDescriptorDb()
21:41:03:660 DB save zll database items 0x00000800
21:41:03:660 DB sql exec UPDATE devices SET nwk = 51389 WHERE mac = ‘f0:d1:b8:00:00:11:bb:d2’;INSERT INTO devices (mac,nwk,timestamp) SELECT ‘f0:d1:b8:00:00:11:bb:d2’, 51389, strftime(’%s’,‘now’) WHERE (SELECT changes() = 0);
21:41:03:661 DB saved in 0 ms
21:41:03:661 DB pushZdpDescriptorDb()
21:41:03:661 sql exec SELECT * FROM nodes WHERE mac=‘f0:d1:b8:00:00:15:3f:5c-01’ COLLATE NOCASE AND state != ‘deleted’
21:41:03:662 LightNode 13: Dachboden Stehlampe added
21:41:03:662 DB pushZdpDescriptorDb()
21:41:03:662 DB save zll database items 0x00000800
21:41:03:662 DB sql exec UPDATE devices SET nwk = 53936 WHERE mac = ‘f0:d1:b8:00:00:15:3f:5c’;INSERT INTO devices (mac,nwk,timestamp) SELECT ‘f0:d1:b8:00:00:15:3f:5c’, 53936, strftime(’%s’,‘now’) WHERE (SELECT changes() = 0);
21:41:03:663 DB saved in 0 ms
21:41:03:663 DB pushZdpDescriptorDb()
21:41:03:664 sql exec SELECT * FROM nodes WHERE mac=‘f0:d1:b8:00:00:15:0f:3e-01’ COLLATE NOCASE AND state != ‘deleted’
21:41:03:665 LightNode 22: Licht Arbeitsflaeche added
21:41:03:665 DB pushZdpDescriptorDb()
21:41:03:665 DB save zll database items 0x00000800
21:41:03:665 DB sql exec UPDATE devices SET nwk = 58307 WHERE mac = ‘f0:d1:b8:00:00:15:0f:3e’;INSERT INTO devices (mac,nwk,timestamp) SELECT ‘f0:d1:b8:00:00:15:0f:3e’, 58307, strftime(’%s’,‘now’) WHERE (SELECT changes() = 0);
21:41:03:665 DB saved in 0 ms
21:41:03:666 DB pushZdpDescriptorDb()
21:41:03:666 sql exec SELECT * FROM nodes WHERE mac=‘00:0b:57:ff:fe:af:9b:5d-01’ COLLATE NOCASE AND state != ‘deleted’
21:41:03:667 LightNode 26: Deckenlicht Dachboden added
21:41:03:668 DB pushZdpDescriptorDb()
21:41:03:668 DB save zll database items 0x00000800
21:41:03:668 DB sql exec UPDATE devices SET nwk = 58459 WHERE mac = ‘00:0b:57:ff:fe:af:9b:5d’;INSERT INTO devices (mac,nwk,timestamp) SELECT ‘00:0b:57:ff:fe:af:9b:5d’, 58459, strftime(’%s’,‘now’) WHERE (SELECT changes() = 0);
21:41:03:668 DB saved in 0 ms
21:41:03:669 sql exec SELECT * FROM nodes WHERE mac=‘f0:d1:b8:00:00:10:9d:0e-01’ COLLATE NOCASE AND state != ‘deleted’
21:41:03:670 LightNode 24: Deckenlicht Nord Arbeitszimmer added
21:41:03:670 DB pushZdpDescriptorDb()
21:41:03:670 DB save zll database items 0x00000800
21:41:03:670 DB sql exec UPDATE devices SET nwk = 58983 WHERE mac = ‘f0:d1:b8:00:00:10:9d:0e’;INSERT INTO devices (mac,nwk,timestamp) SELECT ‘f0:d1:b8:00:00:10:9d:0e’, 58983, strftime(’%s’,‘now’) WHERE (SELECT changes() = 0);
21:41:03:670 DB saved in 0 ms
21:41:03:671 DB pushZdpDescriptorDb()
21:41:03:671 sql exec SELECT * FROM nodes WHERE mac=‘f0:d1:b8:00:00:13:10:81-01’ COLLATE NOCASE AND state != ‘deleted’
21:41:03:672 LightNode 4: Stehlampe Wohnzimmer added
21:41:03:672 DB pushZdpDescriptorDb()
21:41:03:672 DB save zll database items 0x00000800
21:41:03:672 DB sql exec UPDATE devices SET nwk = 61073 WHERE mac = ‘f0:d1:b8:00:00:13:10:81’;INSERT INTO devices (mac,nwk,timestamp) SELECT ‘f0:d1:b8:00:00:13:10:81’, 61073, strftime(’%s’,‘now’) WHERE (SELECT changes() = 0);
21:41:03:673 DB saved in 0 ms
21:41:03:673 DB pushZdpDescriptorDb()
21:41:03:674 SensorNode 12 set node 0x588e81fffe11bdde
21:41:03:674 DB pushZdpDescriptorDb()
21:41:03:674 DB save zll database items 0x00000800
21:41:03:674 DB sql exec UPDATE devices SET nwk = 63602 WHERE mac = ‘58:8e:81:ff:fe:11:bd:de’;INSERT INTO devices (mac,nwk,timestamp) SELECT ‘58:8e:81:ff:fe:11:bd:de’, 63602, strftime(’%s’,‘now’) WHERE (SELECT changes() = 0);
21:41:03:674 DB saved in 0 ms
21:41:03:675 DB pushZdpDescriptorDb()
21:41:03:675 sql exec SELECT * FROM nodes WHERE mac=‘f0:d1:b8:00:00:14:9b:a9-01’ COLLATE NOCASE AND state != ‘deleted’
21:41:03:676 LightNode 8: Deckenlicht Küche added
21:41:03:676 DB pushZdpDescriptorDb()
21:41:03:676 DB save zll database items 0x00000800
21:41:03:676 DB sql exec UPDATE devices SET nwk = 64614 WHERE mac = ‘f0:d1:b8:00:00:14:9b:a9’;INSERT INTO devices (mac,nwk,timestamp) SELECT ‘f0:d1:b8:00:00:14:9b:a9’, 64614, strftime(’%s’,‘now’) WHERE (SELECT changes() = 0);
21:41:03:677 DB saved in 0 ms
21:41:03:677 DB pushZdpDescriptorDb()
21:41:03:846 UPNP socket not bound, state: 0
21:41:04:728 COM: /dev/ttyAMA0 : (0x0000/0x0000)
21:41:04:729 COM: /dev/ttyS0 : (0x0000/0x0000)
21:41:04:730 dev /dev/ttyS0 (/dev/ttyS0)
21:41:04:731 auto connect com /dev/ttyS0
21:41:06:307 Serial com connected
21:41:06:364 Master: read param with arg 0x18
21:41:06:365 Master: read param with arg 0x13
21:41:06:367 Master: read param with arg 0x13
21:41:06:370 Master: read param with arg 0x18
21:41:06:371 Master: read param with arg 0x13
21:41:06:372 Master: read param with arg 0x13
21:41:06:514 command queue EVENT_TIMEOUT, cmd: CMD_VERSION, seq: 1
21:41:06:616 Device firmware version 0x26720700 RaspBee II
21:41:06:618 GW update firmware found: /usr/share/deCONZ/firmware/deCONZ_ConBeeII_0x26660700.bin.GCF
21:41:06:618 GW firmware version: 0x26720700
21:41:06:625 Device firmware version 0x26720700 RaspBee II
21:41:06:633 unlocked max nodes: 512
21:41:06:634 has feature: max nodes (0x11), status: 0x00
21:41:06:641 has feature: std security (0x01), status: 0x04
21:41:06:648 has feature: link security (0x02), status: 0x00
21:41:06:655 has feature: high security (0x03), status: 0x04
21:41:06:663 has feature: ethernet (0x04), status: 0x04
21:41:06:670 has feature: mass storage device (MSD) (0x05), status: 0x04
21:41:06:679 has feature: device firmware upgrade (DFU) (0x06), status: 0x04
21:41:06:686 has feature: ZigBee Light Link (ZLL) (0x07), status: 0x04
21:41:06:693 has feature: interpan (0x08), status: 0x04
21:41:06:700 has feature: button 1 (0x09), status: 0x04
21:41:06:708 has feature: button 1 (0x0A), status: 0x04
21:41:06:715 has feature: LED 1 (0x0B), status: 0x00
21:41:06:722 has feature: LED 2 (0x0C), status: 0x00
21:41:06:729 has feature: LED 3 (0x0D), status: 0x04
21:41:06:732 Announced to internet https://phoscon.de/discover
21:41:06:732 discovery server date: Tue, 16 Nov 2021 20:41:06 GMT
21:41:06:733 local time seems to be ok
21:41:06:737 has feature: LED 4 (0x0E), status: 0x04
21:41:06:744 has feature: LED 5 (0x0F), status: 0x04
21:41:06:751 has feature: LED RGB (0x10), status: 0x04
21:41:06:752 APS request version 1
21:41:06:760 has feature: max nodes (0x11), status: 0x04
21:41:06:767 Device protocol version: 0x010E
21:41:06:788 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 2, node: 0x0000
21:41:06:863 Master: read param with arg 0x19
21:41:06:900 Current channel 15
21:41:06:928 CTRL ANT_CTRL 0x03
21:41:06:935 CTRL ZDP_RESPONSE handler 0x0001
21:41:07:003 Device protocol version: 0x010E
21:41:07:011 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 1, node: 0x0000
21:41:07:020 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 2, node: 0x0000
21:41:07:071 Master: read param with arg 0x19
21:41:07:135 CTRL ANT_CTRL 0x03
21:41:07:143 CTRL ZDP_RESPONSE handler 0x0001
21:41:07:285 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 8, node: 0x0000
21:41:09:438 SensorNode id: 53 (Temperaturregler Bad) available
21:41:10:159 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 8, node: 0x0000
21:41:11:388 Daylight now: nightStart, status: 230, daylight: 0, dark: 1
21:41:14:259 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 3, node: 0x0000
21:41:14:259 DB pushZdpDescriptorDb()
21:41:14:309 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 7, node: 0x0000
21:41:16:388 GW firmware version: 0x26720700
21:41:21:389 Daylight now: nightStart, status: 230, daylight: 0, dark: 1
21:41:21:881 DB pushZdpDescriptorDb()
21:41:22:889 sql exec SELECT conf FROM zbconf ORDER BY rowid desc limit 1
21:41:22:890 Wait 2s till query finished
21:41:23:889 Wait 1s till query finished
21:41:24:889 poll node 00:21:2e:ff:ff:05:bf:26-01
21:41:24:890 Poll light node Configuration tool 1
21:41:24:890 Idle timer triggered
21:41:24:892 Force read attributes for ZHAThermostat SensorNode Temperaturregler Bad
21:41:26:389 GW firmware version: 0x26720700
21:41:29:066 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 5, node: 0x0000
21:41:29:067 DB pushZdpDescriptorDb()
21:41:29:888 Idle timer triggered
21:41:29:889 Force binding of attribute reporting for node Configuration tool 1
21:41:31:388 Daylight now: nightStart, status: 230, daylight: 0, dark: 1
21:41:33:679 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 8, node: 0x0000
21:41:34:888 Idle timer triggered
21:41:36:388 GW firmware version: 0x26720700
21:41:41:388 Daylight now: nightStart, status: 230, daylight: 0, dark: 1
21:41:46:389 GW firmware version: 0x26720700
21:41:51:388 Daylight now: nightStart, status: 230, daylight: 0, dark: 1
21:41:53:793 Incr. ZDP retry count 111 on item 1
21:41:56:388 GW firmware version: 0x26720700
21:41:57:199 void deCONZ::zmNode::setFetched(deCONZ::RequestId, bool) fetched item: 8, node: 0x0000
21:42:00:405 Master: read param with arg 0x19
21:42:00:435 Device TTL 3114 s flags: 0x7
21:42:01:388 Daylight now: nightStart, status: 230, daylight: 0, dark: 1
21:42:03:388 DB save zll database items 0x00000081
21:42:03:389 DB sql exec REPLACE INTO nodes (id, state, mac, name, groups, endpoint, modelid, manufacturername, swbuildid, ritems) VALUES (‘1’, ‘normal’, ‘00:21:2e:ff:ff:05:bf:26-01’, ‘Configuration tool 1’, ‘65520’, ‘1’, ‘RaspBee’, ‘dresden elektronik’, ‘0x26610700’, ‘{“attr/id”:“1”,“attr/lastannounced”:null,“attr/lastseen”:“2021-11-16T20:41Z”,“attr/manufacturername”:“dresden elektronik”,“attr/modelid”:“RaspBee”,“attr/name”:“Configuration tool 1”,“attr/swversion”:“0x26610700”,“attr/type”:“Configuration tool”,“attr/uniqueid”:“00:21:2e:ff:ff:05:bf:26-01”,“state/reachable”:true}’)
21:42:03:404 DB saved in 16 ms
21:42:04:888 Idle timer triggered
21:42:06:388 GW firmware version: 0x26720700
21:42:11:388 Daylight now: nightStart, status: 230, daylight: 0, dark: 1
21:42:13:888 Skip idle timer callback, too early: elapsed 945 msec
This starting log seem fine.
and after you have the disconnect error ?
(BTW try to use third site like pastebon to share log)
I dont see any APS logs there.
Can you please use Pastebin for new logs?
On yesterday I tried to start from the scratch with a fresh image. Then I recognized, that a pairing is possible after a reset of devices/nodes. So I started beginning reseting the 45 devices. Till now no problems. Thanks for getting in touch.
I’m currently experiencing sort of the same problem, but I think it can’t be narrowed down to the firmware update…
I ran an apt upgrade on my RPi with Raspbian image on 15.11.21 (something I haven’t done for a long time before then). After that deCONZ was updated to version 2.12.06 and additionally all my temperature sensors (Aquara) stopped updating. At first I just noticed the missing values in my Home assistant instance and so I thought the problem must lay there. But yesterday I realised that the sensors where shown offline in PWA.
After some fumbling I decided to run a manual firmware update on the Raspbee II and had the same experience as stated above (retry, failed) but seemingly the update was applied as PWA now shows 26720700 as version number.
As a result all lights in my installation went offline (IKEA and Osram) and I was left with my switches (IKEA) and one single PIR (Aquara).
I could successfully “repair” one of the temperature sensors, but that just worked temporarely I think. I did not do an explicit pairing but removed the battery and put it back in. After that the sensor came back online. Now the sensor is shown as if it’s online but on the detail page it says “not available”:
Logs can be found here: Log@Pastebin
I don’t see any suspicious things tbh. Might a firmware downgrade be helpful? Can I do that just by flashing an older version?
Any help would be greatly appreciated.
Many thanks in advance!
EDIT: I just tried to join a factory resetted light bulp to a factory resetted (via PWA) gateway and the bulp isn’t found…
Nothing special in logs after the starting procedure ?
Can you show your network config from deconz ?
The Log I supplied was taken at startup. What do you mean by network config?
Yep, it s for that I m asking for logs some time after, with “info” “info_l2” “error” and “error_l2”
Something to compare with that Network lost and configuration restore does not help · dresden-elektronik/deconz-rest-plugin Wiki · GitHub (if you can access to the GUI ?)
We also want aps and APS 2 logs.
The last log snippet was already with info2 and error2… Here’s another snippet with error2, info2 and aps2: 17:28:01:494 HTTP Server listen on address 0.0.0.0, port: 80, root: /usr/share/d - Pastebin.com
The log was captured at deCONZ startup and I tried to pair some of the lost lights afterwards.
Here’s the desired screenshot. I can’t see anything unusual tbh :confused:
