Q: Problems with Aqara Temp sensor below zero?
Quick question to others who have an Aqara temp/humidity/pressure sensor in the fridge: did you also experience an issue where the api does not report value <0 degrees after the upgrade to deconz 2.15?
I use 2 sensors like that, and both are “stuck” just above 0 C, while the real temperature is about -18 C (visible when I check the cluster from deconz), and I see the values for Humidity updating regularly:
There’s already a bug report open :slight_smile:
