I have many of these Tuya plugs, and it looks like the issue usually occurs in 1 or 2 specific locations in the house. And even when I swap plugs, so most likely not an issue with a specific plug, but more related to the location.
I still don’t understand why it gets disconnected for a while and then reconnects automatically after a while (no power cycle or deconz restart). Also the plug now seems to have connections again and looked OK, but on/off did not work?
![image](https://forum.phoscon.de/uploads/default/original/2X/3/33a786a454305212247e0e7b3cb80b5e99e1530a.png)
I then did a read on the basic cluster from deconz, and after that it worked fine.
BTW: It’s an empty plug for now, so nothing is connected to it.
Does this logging hold a clue (0xA4C138FE374472AD)?
07:36:11:447 ZCL attribute report 0x00158D00054D0553 for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:11:470 ZCL attribute report 0x00158D00054D0553 for cluster: 0x0406, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:12:312 Skip idle timer callback, too early: elapsed 860 msec
07:36:12:725 ZCL attribute report 0xA4C138E35F5B0868 for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:14:059 ZCL attribute report 0x04CF8CDF3C78C39E for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:14:207 ZCL attribute report 0xA4C1383602BE8319 for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:14:568 ZCL attribute report 0xA4C1383602BE8319 for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:15:457 ZCL attribute report 0x04CF8CDF3C7B50D0 for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:15:458 Skip idle timer callback, too early: elapsed 886 msec
07:36:16:301 ZCL attribute report 0x04CF8CDF3C7D1330 for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:17:147 ZCL attribute report 0xA4C138FE374472AD for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:19:253 ZCL attribute report 0xA4C1383602BE8319 for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:19:357 ZCL attribute report 0xA4C1383602BE8319 for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:19:732 ZCL attribute report 0xA4C138E35F5B0868 for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:20:642 ZCL attribute report 0x04CF8CDF3C7B50D0 for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:24:310 ZCL attribute report 0xA4C1383602BE8319 for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:24:588 ZCL attribute report 0xA4C1383602BE8319 for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:24:650 ZCL attribute report 0xA4C138E35F5B0868 for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:25:811 SC tick --> StateCallFunction
07:36:25:812 SC_SetOnOff()
07:36:25:906 ZCL attribute report 0xA4C138FE374472AD for cluster: 0x0006, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:25:907 SC state/on: synced
07:36:25:907 SC --> StateFinished
07:36:25:908 SC state change finished: a4:c1:38:fe:37:44:72:ad-01
07:36:26:049 ZCL attribute report 0xA4C138FE374472AD for cluster: 0x0006, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:26:206 ZCL attribute report 0xEC1BBDFFFEB181D9 for cluster: 0x0006, ep: 0x01, frame control: 0x08, mfcode: 0x0000
07:36:26:233 ZCL attribute report 0x04CF8CDF3C7D1330 for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:26:244 ZCL attribute report 0xEC1BBDFFFEB181D9 for cluster: 0x0008, ep: 0x01, frame control: 0x08, mfcode: 0x0000
07:36:29:117 ZCL attribute report 0xA4C1383602BE8319 for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:29:544 ZCL attribute report 0xA4C138E35F5B0868 for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:31:858 ZCL attribute report 0xA4C1383602BE8319 for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:33:345 Device TTL 5099 s flags: 0x7
07:36:33:837 ZCL attribute report 0x04CF8CDF3C78C39E for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:34:115 ZCL attribute report 0xA4C1383602BE8319 for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:34:183 ZCL attribute report 0xA4C1383602BE8319 for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:35:098 ZCL attribute report 0x84BA20FFFEAD21C2 for cluster: 0x0300, ep: 0x01, frame control: 0x08, mfcode: 0x0000
07:36:35:144 ZCL attribute report 0x00158D000461F3E0 for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:35:155 ZCL attribute report 0x00158D000461F3E0 for cluster: 0x0406, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:35:255 ZCL attribute report 0xA4C138FE374472AD for cluster: 0x0006, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:35:551 ZCL attribute report 0xA4C138E35F5B0868 for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:36:141 ZCL attribute report 0x04CF8CDF3C7D1330 for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:36:152 ZCL attribute report 0x04CF8CDF3C7D1330 for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:38:600 ZCL attribute report 0xEC1BBDFFFE547491 for cluster: 0x0300, ep: 0x01, frame control: 0x08, mfcode: 0x0000
07:36:38:675 ZCL attribute report 0x84BA20FFFEAD21C2 for cluster: 0x0006, ep: 0x01, frame control: 0x08, mfcode: 0x0000
07:36:38:685 ZCL attribute report 0x84BA20FFFEAD21C2 for cluster: 0x0008, ep: 0x01, frame control: 0x08, mfcode: 0x0000
07:36:38:898 0xec1bbdfffeb88896 found group 0x0003
07:36:40:302 ZCL attribute report 0xA4C1383602BE8319 for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:40:320 Skip idle timer callback, too early: elapsed 16 msec
07:36:40:548 ZCL attribute report 0xA4C138E35F5B0868 for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:41:108 ZCL attribute report 0xA4C1383602BE8319 for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:44:110 ZCL attribute report 0xA4C1383602BE8319 for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:45:123 ZCL attribute report 0x04CF8CDF3C7B50D0 for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:45:559 ZCL attribute report 0xA4C138E35F5B0868 for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:46:115 ZCL attribute report 0xA4C1383602BE8319 for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:46:143 ZCL attribute report 0x04CF8CDF3C7D1330 for cluster: 0x0400, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:48:548 remove link for (277, 313D)
07:36:49:065 ZCL attribute report 0x00158D0004AB3C58 for cluster: 0x0406, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:49:251 ZCL attribute report 0xA4C1383602BE8319 for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:50:019 ZCL attribute report 0x00158D00058A26A4 for cluster: 0x0402, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:50:145 ZCL attribute report 0x00158D00058A26A4 for cluster: 0x0405, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:50:250 ZCL attribute report 0x00158D00058A26A4 for cluster: 0x0403, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:50:684 ZCL attribute report 0xA4C138E35F5B0868 for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:51:334 ZCL attribute report 0xA4C1383602BE8319 for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:51:795 emit event/tick: 0xa4c138fe374472ad
07:36:51:837 0xA4C138FE374472AD force poll (2)
07:36:51:863 ZCL attribute report 0xA4C138FE374472AD for cluster: 0x0006, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:51:864 SC state/on: synced
07:36:51:865 SC --> StateFinished
07:36:51:865 SC state change finished: a4:c1:38:fe:37:44:72:ad-01
07:36:52:006 ZCL attribute report 0xA4C138FE374472AD for cluster: 0x0006, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:52:268 emit event/tick: 0xa4c138fe374472ad
07:36:52:311 0xA4C138FE374472AD force poll (2)
07:36:52:511 sensor 55 (lumi.sensor_motion.aq2): disable presence
07:36:53:016 ZCL attribute report 0xA4C138FE374472AD for cluster: 0x0006, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:53:017 SC state/on: synced
07:36:53:017 SC --> StateFinished
07:36:53:017 SC state change finished: a4:c1:38:fe:37:44:72:ad-01
07:36:53:654 ZCL attribute report 0xA4C138C783B59014 for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:54:237 ZCL attribute report 0xA4C1383602BE8319 for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:54:695 ZCL attribute report 0xA4C138E35F5B0868 for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:54:699 emit event/tick: 0xa4c138fe374472ad
07:36:54:745 0xA4C138FE374472AD force poll (2)
07:36:54:776 ZCL attribute report 0xA4C138FE374472AD for cluster: 0x0006, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:54:777 SC state/on: synced
07:36:54:778 SC --> StateFinished
07:36:54:778 SC state change finished: a4:c1:38:fe:37:44:72:ad-01
07:36:55:056 ZCL attribute report 0xA4C138FE374472AD for cluster: 0x0006, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:55:806 emit event/tick: 0xa4c138fe374472ad
07:36:55:847 0xA4C138FE374472AD force poll (2)
07:36:55:872 ZCL attribute report 0xA4C138FE374472AD for cluster: 0x0006, ep: 0x01, frame control: 0x18, mfcode: 0x0000
07:36:55:873 SC state/on: synced
