Puzzled about HA integration
Hi there!
I’m new to the deConz ecosystem, and I’m trying to set things up with a HA installation. I’m struggling with how the pieces fit together, so I hope you’ll forgive me some confused questions.
I’m using a ConBee III plugged into the device HA is running on, and have installed the deConz app. I’m not getting a discovered Integrations, but if I “Add a hub”, I get an internal IP for a Phoscon gateway. I can then add devices to the Phoscon gateway, which subsequently show up in HA.
Is this how it’s supposed to work, or is there a way to add devices more directly in HA?
(The app also has a button to VNC-connect me to “deConz”, and I don’t have the slightest clue as to do with the system that shows up there.)
Regards,
Mike
